Local Time 00:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBASIC Tutorial
BobDevries
Posted: 02:03am 29 Jun 2011
Hi all,
I've just made a start to write an MMBASIC Tutorial, based on Geoff's manual. I'm of the opinion that examples are needed especially for some of the more esoteric commands. Some of us are probably quite rusty when it comes to programming in BASIC.
I would welcome your comments and input; short example code would be great.
I will make the end result available as PDF.
Bob Devries
Dalby, QLD, Australia
Nick
Posted: 02:37am 29 Jun 2011
Great idea Bob!
You could scan the little anatomic computer figures from the Color Computer manual and put them in too! :)
Keith @
Posted: 02:48am 29 Jun 2011
That's commendable Bob
... I'll certainly await your endeavors
The more we know, the more we know we don't know !
James_From_Canb
Posted: 09:14am 29 Jun 2011
Well, name a command or function and see what happens. I notice there was an innovative answer about using interrupts to create an on-off cycle on a pin.
There is obviously a lot of experience out there from a generation that doesn't mind giving time to help others.
I know I'm drooling over my zimmer frame about the fun to be had with this.
So name a command, any command....
BobDevries
Posted: 09:28pm 29 Jun 2011
Well, you could pick any of the MMBASIC functions from page 14 and following of the MM Manual. What I'd like is very short programme, say up to 10 lines to show how the function works.
regards,
Bob Devries
