Local Time 00:38 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : bootloader prob
sparkey
Posted: 11:56am 22 Jun 2011
i am running xp service pack2 as soon as i run bootloader it comes up with cannt enable device ...is my windows too old ..i only have dial up and am trying to up grade from 2point one to 2 point 4....regards and thanks to all who reply
stuarts
Posted: 12:00pm 22 Jun 2011
Sparkey, do you have the Maximite connected when you run bootloader, and is the power led flashing? I haven't tried XP, but its supposed to work. you have to have the maximite connected after powering it on with the firmware button pressed. the power led should be flashing. If the power led isn't flashing, its not in firmware upgrade mode and I wouldn't expect bootloader.exe to recognise the Maximite.
Stuart
Gadget
Posted: 12:18pm 22 Jun 2011
Hi Sparkey, I upgraded mine from 2.1 to 2.4 under XP. first i connected the device and loaded the silicon chip drivers. Then powered down maximite and powered up whilst holding the boot loader button, power led commenced flashing. ran bootloader and all worked fine.
Terry
stuarts
Posted: 12:21pm 22 Jun 2011
Thats a good point, have you installed the Silicon Chip drivers before you started. Make sure that you can connect to it using putty or some similar program before you try to do the upgrade.
Stuart
BobDevries
Posted: 09:29pm 22 Jun 2011
Guys,
you don't need the silicon chip drivers to *program* the Maximite.
What you *do* need is Microsoft's .NET Framework V2 or later.
I always program my Maximite on my laptop which has .NET, but no Silicon Chip drivers. Those drivers are only used to provide serial over USB support, to allow a terminal programme to talk to the Maximite when it is running normally.
Bob Devries
Dalby, QLD, Australia
stuarts
Posted: 10:16pm 22 Jun 2011
On dial up thats going to take ages to download.....
sparkey
Posted: 02:46am 23 Jun 2011
thaks guys i will go down to the net cafe and take a 2 gig usb stick would this be sufficent .....
donmck
Posted: 06:39am 23 Jun 2011
  sparkey said   thaks guys i will go down to the net cafe and take a 2 gig usb stick would this be sufficent .....
Brian, 3049 is Attwood or Westmeadows.
For those that don't know, this is right on the edge of the Tullamarine International Airport in Australia. You will be able to hear and see the planes from there.
I don't mean to criticize this at all, as I'm sure you have your reasons, but you are still running dial-up?
When you said dial-up, I thought you must have been in the bush somewhere.
Cheers Don...
https://www.dontronics.com
sparkey
Posted: 04:30am 25 Jun 2011
the application configureation is not correct this is the error message i get ...no i have not got the net upgrade yet..thanks ....
sparkey
Posted: 03:57pm 25 Jun 2011
i got xp sp3 and still cannot get this thing flashed i changed the hdd fresh clean and install xp and still the same problem....any answers app thasnks...
stuarts
Posted: 12:43am 26 Jun 2011
what version of .Net framework does XP SP3 include? I'm not sure, but I think it still needs downloading. I dont think it is included in SP3.
Stuart
PS: Just did a little search and it looks like its not included....Edited by stuarts 2011-06-27
sparkey
Posted: 01:55am 26 Jun 2011
thank you stuart
