Local Time 00:22 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Altronics kit - front label
James_From_Canb
Posted: 04:54am 19 Jun 2011
Did anyone else have problems attaching the label to the front of the Altronics kit?
Mine didn't stick.
Ray B
Posted: 04:59am 19 Jun 2011
I had same problem - it seems to be an Avery label but the backing paper does not cleanly peel off unless you use something sharp
RayB from Perth WA
stuarts
Posted: 05:39am 19 Jun 2011
I'll keep this in mind. Still waiting for mine, apparently its in the mail
Stuart
BobDevries
Posted: 07:08am 19 Jun 2011
Hi gang,
I had the same problem with my label (also from Altronics).
When I started to peel it off the backing paper, it didn't appear right to me, so I started again at the other end, and very carefully peeled off the paper so that the sticky plastic was left.
I also found it hard to align it properly with the holes in the panel.
Bob Devries
Dalby, QLD, Australia
thetinkerer
Posted: 07:34am 19 Jun 2011
Me too guys! Also from Altronics
I thought that get the label off the backing paper and onto the Maximite was some sort of experiment into the patience and ingenuity of the hobbiest - very testing!
Marc
thetinkerer
Posted: 07:38am 19 Jun 2011
OOOPS - a Typo in the previous reply- try again!
I thought that getting the label off the backing paper and onto the Maximite was some sort of experiment into the patience and ingenuity of the hobbiest - very testing! He He!
Keith @
Posted: 08:12am 19 Jun 2011
Hi Guys
Altronics label was no problem .... just use a couple of sticks in the LED holes ... carefully peel off the backing paper ... slide the label down the sticks, line it up and carefully smooth it out ... no soapy water ... trimmed a little at one end with a box cutter ... perfect
The more we know, the more we know we don't know !
Posted: 09:55am 19 Jun 2011
Thats a good tip Keith
My label was OK, peeled off the backing paper easily. Maybe the later batches of labels are having a few issues.
