Local Time 00:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : anolog pin set program
sparkey
Posted: 08:06pm 15 Jun 2011
ok heres another way to do it "i think" be able to set an anolog pin or maybe digital pin at a postive voltage of say 10v or 5 then next set it at 0 volts basiccally creating a positve pulse on the out put pin and allow its on time to be adjustable regards sparkey ..i am not that fimialar with the programme entry`s to use the correct statements or syntax...regards sparkey thanks to all that reply...
