Local Time 00:14 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : maxi mite
sparkey
Posted: 05:07pm 14 Jun 2011
there was a post on geoffs page that showe somebodys mods inclding a simple programme for a freq counter cant seem to find the page ..also showed heat sink on the 5 volt reg and a speaker connection any help pls thank you.sparkey..
mac46
Posted: 05:20pm 14 Jun 2011
Sparky,
Page 3 of Gizmo's post "the Maximite", is I believe what you'r looking for.
By the way, Welcome to the forum.
...Mac46
I'm just a farmer
sparkey
Posted: 05:47pm 14 Jun 2011
  sparkey said   there was a post on geoffs page that showe somebodys mods inclding a simple programme for a freq counter cant seem to find the page ..also showed heat sink on the 5 volt reg and a speaker connection any help pls thank you.sparkey..
i cannot seem to find the counter programme may be i am incorrect as to where it was posted it only had abot five lines and it was good for 200Hz
sparkey
Posted: 06:01pm 14 Jun 2011
i found the prog thanks all regards sparkey..
Posted: 11:26pm 14 Jun 2011
That program was not tested, I wrote it before I had a Maximite to play around with.
Posted: 11:29pm 14 Jun 2011
It does, just tried it.
