Local Time 00:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : inverting the maximite screen
BobDevries
Posted: 02:55am 08 Jun 2011
I just wrote a few lines of BASIC to invert the screen using Geoff's new pixel() command. It takes over two minutes to do it this way:
10 PRINT TIME$
20 FOR x=0 TO 480
30 FOR y=0 TO 432
40 z=PIXEL(x,y)
50 IF z=0 THEN z=1 ELSE z=0
60 PIXEL(x,y)=z
70 NEXT y,x
80 PRINT TIME$
Rearranging the order of the FOR-NEXT loops actually makes it slower!
Bob Devries
Dalby, QLD, Australia
RossW
Posted: 07:49am 08 Jun 2011
  BobDevries said   I just wrote a few lines of BASIC to invert the screen using Geoff's new pixel() command. It takes over two minutes to do it this way:
I don't (yet) have one of these beasties, and it's a LONG time since I was forced to endure BASIC, but surely the if-then-else test is hideously inefficient. Doesn't the basic include an XOR?
replace lines 40, 50 and 60 with
pixel(x,y)=pixel(x,y) XOR 1
Edited by RossW 2011-06-09
BobDevries
Posted: 07:54am 08 Jun 2011
As far as I can see in the manual, the only XOR is a logical operator. I'll try that to see if it's suitable.
Bob Devries
BobDevries
Posted: 07:59am 08 Jun 2011
Indeed, the XOR example works (thanks, RossW) and reduces the execution time to just over 1 minute; better, but still painfully slow.
Bob Devries
Posted: 08:19am 08 Jun 2011
Another way is
pixel(x,y)=not(pixel(x,y))
testing and writing to each pixel is a lot of work ( 207360 pixels all up ), and I doubt the Maximite MMBasic is optimised for fast video processing, plus its a interpreted language, so thats a lot of processing. A fill
line (0,0)-(480,432),1,"BF"
takes 141 milliseconds, cause its a single command that is run once, but thats not what you want.
BobDevries
Posted: 08:47am 08 Jun 2011
Yes, the NOT function works too (thanks, Gizmo), and its time is 1 minute 10 secs.
Bob Devries
RossW
Posted: 10:11am 08 Jun 2011
  BobDevries said   Yes, the NOT function works too (thanks, Gizmo), and its time is 1 minute 10 secs.
Does that mean the XOR is faster ("slightly over 1 minute") than NOT ("1 minute 10 sec")?
Can you read the video memory a byte-at-a-time, XOR with 255 (0xFF), write it back, and step a byte? That'd reduce the for-next loop 8-fold which should be almost an order of magnitude faster. (We're still talking about many seconds though).
BobDevries
Posted: 09:31pm 08 Jun 2011
The NOT version is slightly faster.
No only one pixel is accessible at a time using the pixel() function. There's no other way to access the screen RAM (or any other RAM).
Bob Devries
stuarts
Posted: 01:00pm 15 Jun 2011
Sounds like its time for Peek() and Poke()
BobDevries
Posted: 10:17pm 16 Jun 2011
I'd be happy to see the following additions:
DRAW
GET
PUT
LOADBMP
Bob Devries
