Forum Index : Microcontroller and PC projects : Colour Maximite 2 G3
| Page 1 of 2 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12254 |
The Colour Maximite 2 with HDMI. Full details on https://mather.host/cmm2/g3/ The G3 is a G2 whose picture goes to an HDMI transmitter instead of VGA, and whose sound plays through the HDMI screen and the audio socket at the same time. Everything else is the G2's, so G2 programs and add-ons work on it unchanged. ![]() The final design files reference in the web page have a two pin header by the on/off switch do you can omit the switch if required and jumper the header or use it to connect a separate switch. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9387 |
Brilliant work yet again, Peter. :) You've even managed to make javavi happy. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| terekgabor Senior Member Joined: 02/01/2026 Location: HungaryPosts: 172 |
I ordered a G2 one hour before |
Of course. It always works out like that. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
I was lucky, they can't deliver to EU. I refunded the money. Go with G3. |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6276 |
Peter, When you move the CR2032, you can put the RM2 module on the G3 main board. Volhout PicomiteVGA PETSCII ROBOTS |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10142 |
Good point. I 2nd that idea..... ![]() Smoke makes things work. When the smoke gets out, it stops! |
| Wölfi Regular Member Joined: 14/10/2026 Location: GermanyPosts: 54 |
Is an ESP-01 still necessary when an RM2 is integrated, or has it just become obsolete? |
You could use it as well, if you wanted to. It's on COM2 so there is no conflict. You might want to access two different networks or maybe use it as a RF link to another one somewhere else on their own private RF link. What you can't do is use the same commands for the RM2 and ESP-01. They are completely different devices. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks, good to know! |
I will look at the wifi suggestion. In the meantime I suggest no-one gets any G3 boards made as the change needed is quite large and it will change pinouts on the edge connector |
Fully built @ 60USD each + shipping and any applicable taxes ![]() Edited 2026-11-19 03:53 by matherp |
| WhiteWizzard Guru Joined: 05/04/2013 Location: United KingdomPosts: 3002 |
This looks really good - just two questions (for now): 1) what’s the reasoning behind having a full size SD card that takes up more real-estate on the PCB 2) could you task Claude with generating a ‘comparison chart’ between this new G3 and the PC3. The reason for the second point is that I really don’t currently know which is the better of the two based on your continuous hardware improvements and new software features. With a comparison chart people would be better placed to make an informed decision. Just a few examples of my confusion which can hopefully be resolved is regarding whether MicroPython would be better on the G3 or the PC3. And can Doom (plus the other ‘games’) be run on both, likewise the emulators. I know the information is contained in multiple threads and posts, but by the time things are found, the beast has a new feature! Hopefully I’m not the only one that would benefit from a comparison……. Thanks - really liking this G3, and the PC3, but which to invest in first??!! |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 777 |
You need both ![]() Peter, thank you so much! So, does that mean version 1.2 has been released? Matthias |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2168 |
Still has provision for ESP-01? |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3454 |
Bottom left of PCB above. |
| toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 751 |
When I send the Gerbers, BOM and CPL to JLCPCB, I get this error message The BOM file doesn't match the CPL file, please check and re-upload the files. I tried three times, just in case I was inadvertently sending an incorrect file. I got the same error message each time. |
Hi Phil, That is what I was referring to but I thought it was being superseded by the RM2 module. |
https://mather.host/blog/pc3-or-cmm2-g3/ I don't post files for relatively expensive builds like this until I have had some made and tested them. I'm away for the next couple of weeks so I won't be making the V1.2 files with the onboard RM2 available until after that |
Is the following a correct statement and worth mentioning? Edited 2026-11-19 18:20 by PhenixRising |
| Page 1 of 2 |
