Local Time 23:52 11 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite 7 BTH MMedit 5.4.3
guma1975
Posted: 12:26am 11 Nov 2026
mam pico2w wrzuciłem firmware rc08 sprawdzalem rc6 wersje 7 ale tak czy siak za pomoca mmedit 5.4.3 nie moge wyslac programuu niby sie wysyla jest ok aa list nic ...zeroooo jak napisze pirint w edytorze bezpisrednio jest ok....
eng wersion
307 / 5 000
I have pico2w, I uploaded the RC08 firmware, I checked RC6 version 7, but I can't send the program using mmedit 5.4.3. It seems to be sending, it's OK, but the letter shows nothing...zerooooo. If I type "pirint" in the editor directly, it's OK...
eng version, so it seems to have sent, but the letter shows nothing. Zero, the same in files...
ot tak chyba
Posted: 03:57am 11 Nov 2026
Using firmware PicoMiteRP2350BTHV7.00.00RC8, it works as normal
> OPTION LIST
PicoMiteBTH MMBasic RP2350A V7.00.00RC8
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 200000
> C:\Users\Jim\Documents\myapps\maximite\apps\untitled.bas
Uploading using:  'target port\COM5:115200 s\picomite
Upload started
NEW
AUTOSAVE N
Progress: 1/4
Upload completed 1
Saved 67 bytes
Time taken: 1049mS
RUN
1
Using firmware PicoMiteRP2350BTV7.00.00RC8, you have to connect using Bluetooth.
That needs a driver for Windows.
You might be able to configure a serial port as the console and use a TTL-USB adapter
guma1975
Posted: 08:26am 11 Nov 2026
Oh, my apologies, you're quite right... I might not be "old" yet, but I’m definitely getting on in years... hee hee... But thank you all—programming in MMBasic made me feel like a little kid again! Best regards to everyone!
