Local Time 23:52 11 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Olimex RP2350PC now supported by PicoMitePC3 firmware
Posted: 07:33pm 10 Nov 2026
RP2350pc_Rev_A1.pdf
RP2350pc-user-manual.pdf
This is quite a nice little board at a sensible price. It has a few downsides.
First: the psram is on GPIO8 which means none of the existing USB firmware will load because the serial port on GPIO8 triggers the psram which bu....ers the flash reads.
Second: it doesn't have a port for a serial console without adding an external USB/UART
Third: the I2S DAC is mono only and needs configuring over I2C to work at all
Fourth: No real time clock
Other than that....
However, it is available and does include most things needed to run as a standalone computer (clue is in the name)
I therefore, after being asked and lent a board, decided to tailor the PicoMitePC3 build to also work with this board (and now also the Pico Computer 2).
It does this as follows:
RTC 32KHz clock on GP27 = PC3
no clock but psram on GP47 = PC2
no clock and psram on GP8 = RP2350PC
So there is nothing left for you to do, the board automatically configures itself when the firmware is loaded. Then just plug in a monitor and usb keyboard and you are away.
The board supports PWM audio as well as the  I2S DAC (bet they had a job lot of these because as a component choice it makes no sense) so I have configured PWM which works both on the headphone output and via the onboard amplifier.
Sdcard etc. all work as soon as the firmware is loaded.
You need V7.00.00RC8 or greater to support the board
Edited 2026-11-11 05:57 by matherp
hhtg1968
Posted: 08:00pm 10 Nov 2026
I looked at olimex.com. the board is really cheap.
Wölfi
Posted: 09:06am 11 Nov 2026
That’s a really great idea for anyone who wants or needs to get started without soldering.
This could make MMBasic much easier to get into.
The link to it:
https://www.olimex.com/Products/RaspberryPi/PICO/RP2350pc/
and I even found a case to print:
https://www.printables.com/model/1422403-olimex-rp2350pc-case
Edited 2026-11-11 19:07 by Wölfi
Posted: 09:36am 11 Nov 2026
Honestly, the olimex at 25 euro ex shipping is not a bad deal. The housing is also available from Olimex themselves (at 8 euro), look at BOX_PC2350.
I knew memory was expensive, but this seems a bit over the top.
Edited 2026-11-11 19:53 by Volhout
Wölfi
Posted: 09:50am 11 Nov 2026
  Volhout said  The housing is also available from Olimex themselves (at 8 euro), look at BOX_PC2350.
Right, I hadn’t noticed that and the pricing is reasonable, too.
That makes it even easier.
  Quote  I knew memory was expensive, but this seems a bit over the top.
180 Bucks    Wel l… that price is indeed not really reasonable.
