Forum Index : Microcontroller and PC projects : cmm2.fun down?!
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 753 |
https://cmm2.fun/ Fatal error: Uncaught Error: Call to undefined function mysql_connect() in /data/web/virtuals/25758/virtual/www/domains/cmm2.fun/index.php:187 Stack trace: #0 {main} thrown in /data/web/virtuals/25758/virtual/www/domains/cmm2.fun/index.php on line 187 Does anyone know anything about this? Matthias |
| Wölfi Regular Member Joined: 14/10/2026 Location: GermanyPosts: 44 |
Apparently, the website uses outdated code that no longer works after upgrading to a newer version of PHP. The site owner may not have noticed yet and simply needs to be informed so they can update the code. |
I checked the source code, and the author is listed as “JirSoft.” You could try contacting them at jirsoft@cmm2.fun. It’s probably worth a shot. |
... and I found him here being a member, just look him up in the memberlist ... and on Github: https://github.com/jirsoft |
