Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Computer 3 is not fully operational until it runs DOOM
javavi
Posted: 08:37pm 30 Oct 2026
PC3_DOOM.zip
Flash the firmware onto the Pico Computer 3,
and copy the `doom1.wad` file onto an SD card.
Now you're ready to play!
https://github.com/rh1tech/frank-doom
Why do we need AI when we still test hardware by running DOOM?
hhtg1968
Posted: 08:53pm 30 Oct 2026
cool!
we must do that in mmbasic.
I changed peters demo for ray to create a little fps shooter and I am working on it. the ray command does not have all the features of the doom1 engine but that does not matter...
hhtg1968
Posted: 08:57pm 30 Oct 2026
by the way:
ray is on my cmm2 much faster than on picomite. at the resolution 640x480 it is nearlay smooth.
Frank N. Furter
Posted: 12:59pm 05 Nov 2026
Can you also make a version for HERETIC? It runs on Chocolate DOOM, for example. HERETIC runs on the same engine as DOOM...
That would be great!
Frank
Posted: 01:52pm 05 Nov 2026
heretic is much nicer than doom
Posted: 03:15pm 05 Nov 2026
Heretic will be on the CMM2 launchable from Basic later today or tomorrow
Posted: 07:24am 06 Nov 2026
Hi javavi,
If you port this:
https://github.com/rh1tech/frank-idtech1
Then you have all the IDtech games.
Also look at :
duke nukem
Prince of....
Edited 2026-11-06 17:27 by Volhout
javavi
Posted: 08:06am 06 Nov 2026
  Volhout said  Hi javavi,
If you port this:
Hi Volhout,
Yes, I know Mikhail from Greece through the Murmulator group on Telegram. I actually got *Doom* from him for porting purposes. I also reached out to him regarding *Heretic* to add support for a USB mouse; he said he’d take a look. Once it’s ready, we’ll post it here.
And since I only have electricity for about 3 hours a day, I’ve been tinkering with PicoMite MMBasic in the meantime.
Posted: 08:36am 06 Nov 2026
I hope this war is over soon. You must be so tired of it.
Are you running of batteries during outages ? Pico can run quite a while from a power bank. But the monitor will draw much more.
I wish you and your people strength to keep living.
P.S. I think it is Eisenhower who said this: War is millions of people, who don't know each other, killing each other. Just because of 2 people that know each other, and who are not killing the other.
javavi
Posted: 09:18am 06 Nov 2026
  Volhout said  I hope this war is over soon. You must be so tired of it.
In this situation, people acquire a great many things that are unnecessary in ordinary, peacetime life.
Posted: 09:53am 06 Nov 2026
That's a meaty animal! :)
A lot of monitors and TVs use a power brick now, which often has a 12V output. That sort can be run directly from a battery (well, a fuse is a good idea...) and it's more energy efficient than using an inverter. It's not as impressive a solution though. :)
javavi
Posted: 09:18pm 06 Nov 2026
  Frank N. Furter said  Can you also make a version for HERETIC? It runs on Chocolate DOOM, for example. HERETIC runs on the same engine as DOOM...
Yes, that’s almost certainly possible; let’s see—maybe something can be done about it later...
In the meantime, go ahead and play Wolfenstein 3D.
Wolf_3D_PC3.zip
https://github.com/rh1tech/frank-wolf3d
Frank N. Furter
Posted: 05:13pm 07 Nov 2026
Thank you very much for your efforts!
Frank
