Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Cheap touchscreen monitor with both hdmi and vga
Posted: 08:46am 27 Oct 2026
Found this , currently a great price in the UK, Tested on PC3 and also VGAUSBRP2350 code
Posted: 09:13am 27 Oct 2026
Ordered. :)
Thanks, I was looking for something like that.
homa
Posted: 12:00pm 27 Oct 2026
What about the price?
I can't see that from Germany.
Martin H.
Posted: 12:06pm 27 Oct 2026
  homa said  What about the price?
£66.39 (via VPN)
bei Ebay.de EUR 89,67 (used)
Edited 2026-10-27 22:14 by Martin H.
'no comment
twofingers
Posted: 12:23pm 27 Oct 2026
https://www.amazon.de/Kenowa-Touchscreen-Sichtschutz-Lautsprecher-Bildschirm/dp/B0DC5Z32X8/ref=sr_1_7?
109 € - 15 € Coupon
Edited 2026-10-27 22:24 by twofingers
homa
Posted: 12:32pm 27 Oct 2026
thx @all
Wölfi
Posted: 02:05pm 27 Oct 2026
How does it actually work.
Does it completely replace a mouse (on the Picomite)?
I never had such a device at all.
How is it connected?
Posted: 02:08pm 27 Oct 2026
Plugs into a usb host port on the Picomite (and soon the CMM2) and then can be read with the touch function. It can also be used for GUI controla and there is an on screen keyboard available
' tt.bas - USB touch screen test: touch the screen; the program stops after 5 minutes or Ctrl-C. The screen shows the
' touch on three fixed lines and a dot under each finger; PRINT goes to the serial console only (the log).
Option Explicit
Dim integer s, p, r, d, was, x, y, n, lastn
Dim g$, last$
Dim float t0 = Timer
Option Console Serial
CLS
Do While Timer - t0 < 295000
 d = Touch(Down) : x = Touch(X) : y = Touch(Y) : n = Touch(XN 0)
 Text 0, 0, "X " + Str$(x, 5) + "  Y " + Str$(y, 5) + "  DOWN " + Str$(d) + "  contacts " + Str$(n) + "    ", "LT"
 If n >= 2 Then
   Text 0, 14, "2nd contact X " + Str$(Touch(X2), 5) + "  Y " + Str$(Touch(Y2), 5) + "    ", "LT"
 Else
   Text 0, 14, Space$(40), "LT"
 EndIf
 If d Then Circle x, y, 3, , , RGB(yellow), RGB(yellow)
 If n >= 2 Then Circle Touch(X2), Touch(Y2), 3, , , RGB(cyan), RGB(cyan)
 If d And Not was Then Print "down"; x; y; " contacts"; n
 If was And Not d Then Print "up"
 If n <> lastn And n >= 2 Then Print "  contacts"; n; "  2nd at"; Touch(X2); Touch(Y2)
 lastn = n : was = d
 g$ = ""
 s = Touch(Swipe) : If s Then g$ = g$ + "swipe " + Choice(s = 1, "left ", Choice(s = 2, "right ", Choice(s = 3, "up ", "down ")))
 If Touch(Tap) Then g$ = g$ + "tap "
 If Touch(DTap) Then g$ = g$ + "double-tap "
 If Touch(Hold) Then g$ = g$ + "hold "
 p = Touch(Pinch) : If p Then g$ = g$ + Choice(p = 1, "expand ", "contract ")
 r = Touch(Rotate) : If r Then g$ = g$ + Choice(r = 1, "clockwise ", "anticlockwise ")
 If Touch(TTap) Then g$ = g$ + "two-finger-tap "
 If g$ <> "" Then last$ = g$ : Print "gesture: "; g$
 Text 0, 28, Left$("last gesture: " + last$ + Space$(50), 60), "LT"
 Pause 10
Loop
Option Console Both
Print "done"
Posted: 03:00pm 27 Oct 2026
PhenixRising
Posted: 03:19pm 27 Oct 2026
     Fandabidozi
Wölfi
Posted: 03:49pm 27 Oct 2026
Thanks for showing!
Something to keep in mind for the next steps down the line.
Posted: 12:12pm 31 Oct 2026
My PC3x has a new friend. :) V7.00.00RC6 picked it up straight away. Very nice little monitor.
I'm going to have to get a RM2 shortly. The PC3x Version 2 boards will be here soon.
Peter63
Posted: 12:39pm 31 Oct 2026
Hello
This is, very interesting.
If it works out just fine.
If possible, keep me updated on that
/ Peter63
