Forum Index : Microcontroller and PC projects : MicroMite Extreme
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1145 |
Perhaps one for Peter, Are there any plans to bring the MMExtreme reference design (144 or 100 pin boards) and/or the firmware version up to V6 or V7? I have both the 144 pin board and the 100 pin Navigator board and could run any testing on either. Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 310 |
144 pin MMeXtreme; my absolute favourite chip! Several in operation; five chips in stock awaiting board build. Alas, as a full-time carer, my time to implement is rather limited. |
| athlon1900 Regular Member Joined: 10/10/2019 Location: AustriaPosts: 51 |
I’m also waiting for an update. I use all three types of the MMX (64, 100, and 144-pin) in various projects. They are my favorites, too. |
| hhtg1968 Guru Joined: 25/05/2023 Location: GermanyPosts: 317 |
silly question: geoffg lists on his website: standard micromite and micromite plus. what is the definition of "micromite extreme"? |
It's for the PIC32MZ2048 series ( 64 , 100 or 144 ) pins. ( Other Downloads on Geoffs Website ) Judging by the features, I’d say this is the precursor to the CMM2. ![]() Edited 2026-10-29 16:57 by athlon1900 |
@athlon1900: thanks a lot. there I found the downloadable firmware. Is in the forum an post with the tech specs? the mz is the fastest chip with mips cpu I think. how fast is it in comparision to cmm1 and so on. |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2149 |
This is prior to the compiler so not up-to-date. The thread Edited 2026-10-29 17:46 by PhenixRising |
thanks |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6252 |
PicoMite V7.00 at 252MHz is average as fast as V5.08 at 378MHz. That is a 50% speed increase since 5.08 Now need someone to run the PC3 at 378MHz. Might come close to CMM2. BM1 BM2 BM3 BM4 BM5 BM6 BM7 BM8 ABC 800 single 0.9 1.8 6.0 5.9 6.3 11.6 19.6 2.9 ABC 800 double 1.2 2.2 10.0 10.6 11.0 17.8 26.4 14.4 IBM PC 1.5 5.2 12.1 12.6 13.6 23.5 37.4 3.5 Apple III 1.7 7.2 13.5 14.5 16.0 27.0 42.5 7.5 VIC-20 1.4 8.3 15.5 17.1 18.3 27.2 42.7 9.9 ZX81 "fastmode" 4.5 6.9 16.4 15.8 18.6 49.7 68.5 22.9 Maximite 0.016 0.144 0.196 0.205 0.354 0.512 0.721 0.310 Maximite w. #s 0.016 0.131 0.193 0.194 0.245 0.393 0.582 0.241 Maximite w/o #s 0.016 0.111 0.173 0.173 0.192 0.336 0.525 0.220 MicroMite 40MHz 0.028 0.18 0.285 0.289 0.644 0.892 1.346 0.376 MicroMite 48MHz 0.023 0.15 0.237 0.24 0.536 0.744 1.121 0.313 MM+ MX470 120MHz 0.013 0.082 0.135 0.135 0.265 0.380 0.597 0.174 MMX 198MHz 0.006 0.045 0.07 0.08 0.141 0.201 0.287 0.126 Picromite ZeroW 0.014 0.058 0.093 0.102 0.184 0.298 0.354 0.127 Armmite H7 0.003 0.023 0.038 0.042 0.067 0.098 0.146 0.065 ArmMite F4 0.011 0.079 0.14 0.149 0.249 0.354 0.528 0.257 MMBASIC DOS 0.0002 0.0017 0.0028 0.0028 0.0073 0.0092 0.0117 0.0058 CMM2 0.00176 0.0118 0.01903 0.01728 0.03611 0.05062 0.07582 0.02851 PicoMite 0.0166 0.1096 0.1800 0.1840 0.3325 0.4715 0.6688 0.3193 PicoMite V50800 0.0132 0.0969 0.1636 0.1641 0.2866 0.4051 0.5821 0.2824 126MHz PicoMite V50800 0.0046 0.0338 0.0571 0.0574 0.0998 0.1410 0.2030 0.0974 378MHz PM VGA2040 V7.0 0.00348 0.03868 0.06417 0.06227 0.07088 0.10730 0.18059 0.08624 252MHz Linux 0.0000 0.0020 0.0040 0.0040 0.0080 0.0130 0.0190 0.0070 MMB4L 0.8 0.000 0.002 0.004 0.004 0.012 0.009 0.013 0.004 Other Recent Basics ByPic MX170 40M 0.001 0.010 0.023 0.020 0.027 0.041 0.080 0.043 BBC_V Pi Zero 0.0001 0.0007 0.0016 0.0014 0.0015 0.0030 0.0030 0.0036 C-Language Arduino UNO 0.010 0.010 0.058 0.043 0.043 0.043 0.045 0.284 Arduino DUE 0.003 0.003 0.006 0.007 0.007 0.007 0.106 0.014 ESP32S 0.00007 0.00007 0.00030 0.00011 0.00016 0.00016 0.00016 0.02413 Edited 2026-10-29 20:57 by Volhout PicomiteVGA PETSCII ROBOTS |
my mmbasic computers has to run an old program of me which is kind of a ecological simulation to test speed. pico computer 3 at 378 mhz: 3-3.5s per frame cmm2 4s! both with option compiled on |
Edited 2026-10-29 21:01 by Volhout PicomiteVGA PETSCII ROBOTS |
The HDMI and HDMIUSB versions run at 378MHz. BT and BTH versions run at 396MHz. I don't have a newer manual yet. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 753 |
PicoMitePC3 MMBasic USB RP2350B Edition V7.00.00RC6 @ 315000KHz COMPILE ON > run Benchmark tests Benchmark 1 0.000957 Benchmark 2 0.014878 Benchmark 3 0.016761 Benchmark 4 0.016734 Benchmark 5 0.021928 Benchmark 6 0.028555 Benchmark 7 0.037516 Benchmark 8 0.026492 |
RP2350B-DIL @420MHz |
| Bleep Guru Joined: 09/01/2022 Location: United KingdomPosts: 874 |
Hi Harm, For a laugh, here are the results for V7.00 RC5 HDMIUSBI2S @ 378MHz (PC3ish). Because the times were getting silly, these are for 1000000 iterations, so if you want a direct comparison divide the times by 1000. For completeness I also include the same program compiled automagically by peters mmb2csub script. Standard MMBasic with Option Compile On. > run "benchbas Maximite Benchmark tests * 1000 (so loops of 1 million) Benchmark 1 0.567078 1000001 Benchmark 2 13.392785 1000000 Benchmark 3 16.291831 1e+06 Benchmark 4 15.366952 1.499999e+06 Benchmark 5 15.367126 1.499999e+06 Benchmark 6 19.438309 1.499999e+06 6 Benchmark 7 24.475565 1.499999e+06 1.499999e+06 Benchmark 8 25.316544 1e+12 13.81551056 -0.3499935022 0.5671 13.3928 16.2918 15.3670 15.3671 19.4383 24.4756 25.3165 Standard Compiled MMBasic, this only uses the lowest optimisation level because, even though I tried to stop it the optimiser was making the time for test 2,3,4,5 0.0mS by optimising out the loop completely. > run "bench Maximite Benchmark tests * 1000 (so loops of 1 million) Benchmark 1 0.056725 1000001 Benchmark 2 0.023849 1000000 Benchmark 3 0.023848 1e+06 Benchmark 4 0.023849 1.499999e+06 Benchmark 5 0.023847 1.499999e+06 Benchmark 6 0.323315 1.499999e+06 6 Benchmark 7 1.064308 1.499999e+06 1.499999e+06 Benchmark 8 1.808312 1e+12 13.81551056 -0.3499935022 0.0567 0.0238 0.0238 0.0238 0.0238 0.3233 1.0643 1.8083 Regards Kevin. For completness the files as tested. benchbas.zip Edited 2026-11-06 08:41 by Bleep |
