Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PC3 - OpenWeather Forecasts
Andrew_G
Posted: 11:53pm 24 Oct 2026
Hi There,
I am trying to use my PC3 to access OpenWeather forecasts.
I'm using  version 7.000008 HDMIUSB.
I've done it before with my PicoW1 which reliably gets 8, 4-hr forecasts (using older firmware versions).
In the code below (only a test snippet), by varying the value of CNT,  I 'rarely' get 8, 'sometimes' 4, and 'usually' 2 forecast periods. It does vary!
When it fails it has omitted some of the lead-in text and text after "ground_lev".
I've previously used much smaller buffer for m%() but increasing it here 'appears' to help??
The PAUSEs dont seem to do anything?
Any suggestions/better code?
Cheers,
Andrew
'Get_Forecast Check v2.bas
OPTION EXPLICIT
OPTION DEFAULT NONE
Dim Integer   TZone = 10, DST = 1, II
DIM string    ID$ = "7932628"  'Kew East
Dim string    APIKEY$ = "****. . ."
dim integer   CNT = 8 'No of x4 hr time periods requested in forecast. 8 = 24hrs
Dim INTEGER   m%(2048*3)    'm% should be a multiple of 8
Dim string    b$
b$ = "GET /data/2.5/forecast?id="+ID$+"&APPID="+APIKEY$+"&units=metric"+"&cnt="+STR$(CNT)+Chr$(10)+Chr$(13)
longstring CLEAR m%()
WEB NTP Tzone+DST,"au.pool.ntp.org"
pause 1000
WEB OPEN TCP CLIENT "api.openweathermap.org", 80
WEB TCP CLIENT REQUEST b$,m%()
pause 1000
LongString print m%()
print
print "Site   ";JSON$(m%(),"city.name")
print "Sunset ";json$(m%(),"city.sunset")
print "CNT    ";json$(m%(),"CNT")
print
for II = 0 to 8
 print json$(m%(),"list["+str$(II)+"].wind.deg")
next II
WEB CLOSE TCP CLIENT
end
Edited 2026-10-25 10:16 by Andrew_G
Posted: 05:42am 25 Oct 2026
I get a json string 3534 bytes long.
If you take the last 1460 bytes and move them to the beginning of the string, you will have working json data
It looks like packets out of order or a ring buffer got lost.
Tested with WEBMITE and HDMIWEB V7 RC5
Andrew_G
Posted: 06:39am 25 Oct 2026
Hi Jim,
Thanks. Are you able to capture a LONGSTRING PRINT of a typical full lot of data.
(MMCC can help . . .)
I'm using similar hardware with RC8.
Cheers,
Andrew
Posted: 07:08am 25 Oct 2026
Yes , provided you have wordwrap on, MMCC can capture the full longstring.
Email sent.
First string is with the wrong sequence.
second string has it 'fixed' but not tested.
Posted: 07:22am 25 Oct 2026
OPTION EXPLICIT
OPTION DEFAULT NONE
Dim string    APIKEY$ = "xxxxxxxxxxxxxxxxx"
Dim INTEGER   m%(576*8)    'm% should be a multiple of 8
dim integer   k%(576*8)
Dim string    b$
pause 1000
'print b$
WEB TCP CLIENT REQUEST b$,m%() ',3000
pause 1000
print llen(m%())
print
longstring right k%(),m%(),1460
longstring concat k%(),m%()
print "Site   ";JSON$(k%(),"city.name")
print "Sunset ";json$(k%(),"city.sunset")
print "CNT    ";json$(k%(),"CNT")
print
for II = 0 to 8
print json$(k%(),"list["+str$(II)+"].wind.deg")
next II
memory
end
Crude fix to reorder the json string
Posted: 08:34pm 25 Oct 2026
Further information.
This morning every second run works as it should.
The next run through needs the adjustment to the json string.
Andrew_G
Posted: 09:26pm 25 Oct 2026
Hi Jim,
Don't waste precious sunshine but:
- I'm seeing inconsistencies too
- If you take my original code and change CNT to 2 it works every time
- I've played with the size of m%() - seems to not make any difference.
Added:
- The LLEN is consistently 3492
- On a standalone Webmite2 with older firmware it works as intended, ie with CNT = 8
Cheers,
Andrew
Edited 2026-10-26 08:16 by Andrew_G
Posted: 11:32pm 25 Oct 2026
With CNT = 2, the packet length is 1020 so it fits into one TCPIP packet. That is why it works every time.
Andrew_G
Posted: 03:56am 26 Oct 2026
OK Folks,
Thanks to Jim it appears that the following code works on a PC3.
BUT why is it happening?
(It works without the test on 2040 WebMite running  7.000007)
Cheers,
Andrew
 'Get_Forecast Check JH AGv2.bas
 'Works on "WebMite" v1 2040 v7.000007
 'Now works on PC3 using the test for "{"cod":200"
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 Dim string    b$
 longstring CLEAR k%() '+ANG
 pause 1000
 pause 1000
 print llen(m%())
 'Test for "{"cod":200"
 'r$ = LGETSTR$(array%(), start, length) Returns part of a long string as a normal string.
 if LGETSTR$(m%(),1,12) = "{"+chr$(34)+"cod"+chr$(34)+":"+chr$(34)+"200"+chr$(34) then
   ' i.e. it is OK as is
   print
   print "Copying m%()) to k%():"
   longstring copy k%(), m%()
 else  'Use Jim's approach
   print
   print "Concatinting last 1460 to the front"
 End if
 print
 print "Resulting k%():"
 longstring Print k%() '+ANG
 print
 for II = 0 to 8
 next II
 memory
end
Edited 2026-10-26 13:58 by Andrew_G
Andrew_G
Posted: 10:07pm 01 Nov 2026
Hi all,
Peter has now fixed this  here
Cheers,
Andrew
