Local Time 00:38 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PM3.1 - Quick question about MP3 playback....
Posted: 01:50am 13 Oct 2026
Pico Computer 3.1 PCB, FW version 6.0301
Manual version for same FW version.
Manual, page 58, Utility PLAY commands.
I can't get PLAY NEXT or PLAY PREVIOUS to work.
Start a track playing with PLAY MP3 "01" - playback starts.
Try PLAY NEXT, and I get the message: "Last track is playing"
OK, so I then try PLAY PREVIOUS, and I get the message: "First track is playing"
So which is it?
I'm currently being told that the first AND the last track are playing.
Either way, I can't make MMBASIC play the next or previous track.
If I use PLAY STOP, that works - playback stops.
If I then try PLAY NEXT, I get the message: "Error : nothing to play"
Just for the purposes of experimentation, I tried PLAY VOLUME 50,50 and that works perfectly, so it is just the NEXT and PREVIOUS commands I can't get to work.
mozzie
Posted: 01:20pm 13 Oct 2026
G'day Grogster,
If you have your music in a directory "B:\Music" use:
> play mp3 "b:\music\"
It will play all the MP3 files in that directory, and PLAY NEXT / PREVIOUS work as well
Haven't yet found a way to select multiple files to play in File Manager, or how to select the folder to play either.
Regards, Lyle.
Posted: 11:30pm 13 Oct 2026
Ahhhhh!
Thanks!
Is that in the manual?
If so, I must have missed it.
I did not see anything about playing an entire folder, just the files themselves.
In any event, now I know, and I have tried that, and it works great.
