Local Time 00:38 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : how to make programms in mmbasic faster...
hhtg1968
Posted: 02:14pm 07 Oct 2026
on my 40 year old amstrad cpc I am able to optimize speed and i know how to because i wrote the compiler itself.
with mmbasic version7 it is so wonderful to speed up the programs, but I want to do that more exactly.
on mmbasic I am not sure about the exact method to speed up.
Is this question already discussed here in the forum?
here my questions (some of many):
1. One command per line or more?
(a=b
b=c
c=d
or
a=b:b=c:c=d)
2. "for ... next" or loop?
(for i=0 to 9
next
or
i=0
do
 inc i
loop until i>9)
3. "next x" or "next"?
I already read: "next" without x
correct?
4. complicated expression or variable?
(for n=1 to a+b+c+sqr(x)...
or
m=a+b+c+sqr(x)...
for n=1 to m...
one question is whether the condition in the for-loop ist calculated every round)
5. constants or numbers?
(print 10
or
const p=10
print p
or
line 10,10,100,100,,,
or x=...
y=...
x1=...
y1=...
line x,y,x1,y1,,,
some parsers are slower by reading a number from the ascii text than getting the value of a var or constant...
6. I read the infos of mmbasic v7...b7:
call "subroutine" is faster than
"subroutine"?
7. long names of variables?
in my old basic dialects programs with long names of vars (etc) are slower because of the need of interpreting. that did not matter after compiling.
how in mmbasic (compiled and not compiled)?
and so on...
hhtg1968
Posted: 02:42pm 07 Oct 2026
ok. I tested it by a few lines:
for to is faster than do loop
do loop is faster than goto label
I will try further.
those who create mmbasic know that much more exact...
Posted: 03:57pm 07 Oct 2026
Here you go. This will be included in the next release package
MMBasic_Performance_Guide.pdf
hhtg1968
Posted: 04:52pm 07 Oct 2026
that is fine. thank you.
hhtg1968
Posted: 05:33pm 07 Oct 2026
The performance guide is great!
perhaps there will be a time when I will have time to understand mmb2csub.
PeteCotton
Posted: 07:00pm 07 Oct 2026
  matherp said  Here you go. This will be included in the next release package
That's a very interesting read thanks! I learned a lot.
Posted: 07:30am 08 Oct 2026
Thanks Peter,
That is useful, and I learned that a()=b() also works. Never knew that. Always used MATH ADD b(),0,a()
- Despite the numbers for RP2040 would look inferior to RP2350, the comparisson would have been better when both would run the same clock speed. Yes, I am aware I can run the speed test myself at my clock frequency.
- You did not mention the influence of audio (PWM/I2S/SPI) on the average speed when
 a- not using it, but it is configured in OPTIONS
 b- playing TONE/SOUND/WAV/FLAC/MP3(2350 only)
 This would make the report more complete. If you design game loops it is also nice to know how that speed reduction shows. i.e. 2ms blackout every 10ms, or 20ms every 100ms.
But outside that, it has been very informative.
Edited 2026-10-08 17:34 by Volhout
