Local Time 00:37 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Stepper 50KHz pulse-rate
PhenixRising
Posted: 12:14pm 07 Oct 2026
  Quote  Changes STEPPER functionality to ensure steps cannot be missed by drivers that need a pause between step pulses. Note this limits the maximum pulse rate to 50KHz (100KHz interrupt rate). The code will warn you if you specify a maximum axis speed which when multiplied by the steps/unit exceeds this.
Industrial servo-drives can accept step/pulse & direction as position commands (counters). They then, internally close the loop on a servo-motor & encoder.
Question: Since these drives can handle much higher pulse-rates, do we have the horsepower available to bump-up the 50KHz?
The RP23CNC is claimed to achieve 300KHz
