Local Time 00:59 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DIY Clock based on mains frequency
LeoNicolas
Posted: 04:24pm 12 Sep 2026
Ben Eater is releasing a series of videos building a clock using discrete componentes running on the mains frequency. As always, using breadboards
https://youtu.be/3XDH-fZKnQk?si=TVRP8ydjmcW_mwSK
Edited 2026-09-13 04:25 by LeoNicolas
Posted: 07:19pm 12 Sep 2026
Many moons ago there was a design in one of the UK magazines using, IIRC, digitrons driven by rotary switches and a geared synchronous motor to push them round every minute. The switches had their click stops removed and the shaft had a "star" of rods, one of which was bent to give a "carry" signal to the next digit's switch. Not a normal valve or transistor in it. :) It had a certain electro-mechanical charm but I bet the lifetime wasn't great.
