Local Time 23:53 11 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : NES emulator for PC3 hardware
javavi
Posted: 02:47pm 20 Aug 2026
PC3-piconesPlus_046.zip
Hello everyone,
I've adapted the pico-infonesPlus retro gaming console emulator project for the PICO COMPUTER 3 hardware.
pico-infonesPlus
Video output: DVI or HDMI
Sound output: I2S or HDMI
Controls: two NES/SNES controllers, Wii controller, USB keyboard or gamepads.
I've currently assigned the HEC controller connections to ports GP0...GP5
GP0 - CLK     GP3 - CLK
GP1 - DATA    GP4 - DATA
GP2 - LATCH   GP5 - LATCH
I would like to somehow decide on a standard connection for these game controllers to PC3
In general, I would like to know about your interest in porting this emulator?
I am sure the author of the project will not refuse to make a ready-made configuration for PC3 hardware.
Posted: 03:08pm 20 Aug 2026
Excellent
There may in the future be a series of articles on the pc3 and the various codebases available for it in Silicon Chip Magazine (and eventually Practical Electronics) so it would be great to add this as another firmware. Personally I would prefer you used GP34-GP39 for the HEC controller but this isn't a big deal
Edited 2026-08-21 01:08 by matherp
Posted: 03:13pm 20 Aug 2026
Although you don't need to in this case, it's quite possible to share the clock and latch lines for NES/SNES controllers. Each controller needs its own data pin. The number of controllers is limited by how many data channels you read. :)
Martin H.
Posted: 04:01pm 20 Aug 2026
The NES emulator is very cute
There was already a 128/200k Mac emulator on the RP2040.
For purely personal reasons, an Atari ST emulator for PC3 hardware would be very interesting
'no comment
Posted: 04:17pm 20 Aug 2026
I thought my Atari STFM was the bee's knees at the time. However, much more recently I tried an emulator and TBH I'm glad we've moved on from GEM. :) Having large amounts of RAM has made a huge difference - even if "large" is defined as 1GB.
javavi
Posted: 04:20pm 20 Aug 2026
  Martin H. said  For purely personal reasons, an Atari ST emulator for PC3 hardware would be very interesting
Atari ST is quite complicated, but Atari 400/800/XL/XE/GSXE/5200/2600 is easy
Emulators can also be easily ported:
Apple IIe
Apple Mac 128k
Amstrad CPC
Commodore 64
BBC Micro
MCX
ZX Spectrum
javavi
Posted: 05:31pm 20 Aug 2026
  Mixtel90 said  Although you don't need to in this case, it's quite possible to share the clock and latch lines for NES/SNES controllers. Each controller needs its own data pin.
Will connecting two NES controllers like this satisfy everyone?
Although in most cases, only one NES controller can be connected for single-player play.
Posted: 06:36pm 20 Aug 2026
Interesting project.
The 2350 version can be equipped with a bootloader. For the PiComputer3 it would be very nice when MMBasic can be selected, -or- NES emulation.
This may require a change in MMBasic, so it could run from a bootloader.
I am thinking about building a 2040 based NES system, just for fun. They have a PCB that supports a DVI breakout board (the one that Mick also uses), and an SD card breakout board and has connectors for 2 SNES controllers. Simple assembly.
Posted: 06:41pm 20 Aug 2026
  Quote  This may require a change in MMBasic,
No chance. It is so easy to flash a uf2 why destabilise everything?
javavi
Posted: 07:02pm 20 Aug 2026
  Volhout said  The 2350 version can be equipped with a bootloader. For the PiComputer3 it would be very nice when MMBasic can be selected, -or- NES emulation.
On the PICO COMPUTER 3 board, you can solder another identical chip onto the flash memory chip and install a chip selection switch. This allows for quick and easy firmware switching.
Posted: 09:47pm 20 Aug 2026
The Pico is a *dedicated* controller costing peanuts. Why fart about with bootloaders, soldering extra chips etc? Just build a dedicated board. A lot less work. :)  The YD-RP2040 is currently £2.26 on AE Choice. WeAct do a similar board with a RP2350 for £3.04.
javavi
Posted: 09:27pm 22 Aug 2026
New test version 0.47 of the NES emulator for Pico Computer 3
PC3-piconesPlus_047.zip
Information about the project on GitHub
fhoedemakers/pico-infonesPlus
Debug information is on the UART console
Wii classic controller on SYSTEM I2C bus
USB keyboard & USB gamepads
Connecting NES controllers according to the diagram:
Edited 2026-08-23 16:55 by javavi
javavi
Posted: 05:22pm 02 Sep 2026
pico-infonesPlus v0.48
New USB drive mode: show the SD card on your computer over USB straight from the settings menu.
PC3-piconesPlus_048.zip
javavi
Posted: 06:06pm 06 Sep 2026
pico-infonesPlus v0.49 for PC3
PC3-piconesPlus_v049.zip
https://github.com/PicoPlus-devel/pico-infonesPlus/releases/tag/v0.49
Hello to all PC3 owners,
Since I don't have the original PC3 board, only the one assembled on a breadboard, please let me know if anyone has the original PC3 hardware and how this firmware works for you.
javavi
Posted: 04:07pm 03 Oct 2026
Release of pico-infonesPlus version 0.52, ported to Pico Computer 3 hardware.
piconesPlus_v052_PC3.zip
https://github.com/PicoPlus-devel/pico-infonesPlus/releases/tag/v0.52
Hello to all Pico Computer 3 owners,
javavi
Posted: 01:31pm 07 Oct 2026
Release of pico-infonesPlus version 0.53, ported to Pico Computer 3 hardware.
piconesPlus_v053_PC3.zip
More games now run, among them Famicom Jump II, Devil Man, Saint Seiya - Ougon Densetsu, the Datach games and Super Mario Bros. + Tetris + Nintendo World Cup.
Garbled backgrounds fixed in Kyonshiizu 2, Bible Buffet and several other games.
A color palette can now be chosen in the settings menu.
https://github.com/PicoPlus-devel/pico-infonesPlus/releases/tag/v0.53
javavi
Posted: 03:33pm 17 Oct 2026
pico-infonesPlus version 0.54, ported to Pico Computer 3 hardware (PC3)
piconesPlus_v054_PC3.zip
https://github.com/PicoPlus-devel/pico-infonesPlus/releases/tag/v0.54
Posted: 03:46pm 17 Oct 2026
Can you explain how this works. This code is a NES simulator but the user has to go and find legal (or otherwise) "game cartridges" to play on it?
Have you tried to get your PC3 port incorporated as a supported platform on the origin?
The reason I ask is that there will be (a) magazine article(s) on the PC3 and this could be incorporated into it if all above-board
javavi
Posted: 04:05pm 17 Oct 2026
  matherp said  Can you explain how this works. This code is a NES simulator but the user has to go and find legal (or otherwise) "game cartridges" to play on it?
Yes, this firmware acts as an emulator for the NES game console; to play games, you need to save cartridge images *.nes onto an SD card.
By the way, if you copy the metadata onto the memory card, the game covers and descriptions will be displayed.
Check out the description on the author's GitHub.
https://github.com/PicoPlus-devel/pico-infonesPlusа
I’m actually trying to gauge the demand for such a port, so that I can pass the information on to the author—someone I’ve already collaborated with on adapting firmware for other platforms.
For example, it is necessary to define a standard for connecting two NES/SNES game controllers to the PC3; so far, the approach used is the one shown previously, involving the controller's GP0...GP5 ports.
Edited 2026-10-18 02:15 by javavi
javavi
Posted: 11:40am 05 Nov 2026
pico-infonesPlus version 0.55, ported to Pico Computer 3 hardware (PC3)
piconesPlus_v055_PC3.zip
