Local Time 01:34 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : random brief delays in PicoMiteBT
crez
Posted: 10:59pm 26 Jul 2026
Option nocheck on
Timer =0
For h=1 To 50000
 k=Timer
 k=Timer-k
 If k>.06 Then Print k,Timer
Next h
Option nocheck off
End
The above gives, on average, at least 1 result around 0.4 milliseconds per run.
Are there any other options (apart from 'nocheck') I can use to minimise
these brief interruptions? Some runs print no results, other runs can print 10.
All results printed are around 0.4 to 0.6 milliseconds.
running on RP2350
PhenixRising
Posted: 11:01am 27 Jul 2026
  Quote  > option list
PicoMite MMBasic RP2040 V6.02.01
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
This is all I have in front of me atm, and I ran it several dozen times with no delays.
crez
Posted: 12:14am 28 Jul 2026
Thanks for trying it. Maybe something to do with the bluetooth, an interrupt that can't be paused? I'm going to have a go at doing something with PIO. That way there can be no unexpected delays.
Posted: 05:31am 28 Jul 2026
Even if MMBasic seems single thread, thrre are background tasks. And these you see as 0.4ms delays. One obvious task is the console. You use a print statement. That can also scroll a screen, or in case USB or BT, needs cpu support.
P.S. some mmbasic commands avoid this, ADC run, and streaming bits from an array. But PIO is an obvious way to go. MMBasic has good support for it
Edited 2026-07-29 00:43 by Volhout
