Local Time 23:55 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite USB Keyboard issues when using KVM switch
fred777
Posted: 03:40pm 19 Jul 2026
Hi, again.
I tried to use hdmi/usb version of the Picomite with a KVM Switch. The keyboard does not work reliably and often drops some characters or suddenly repeats a key endlessly.  The same keyboard is working fine when attached to the picomite directly and the KVM switch is fine under Windows&Linux. Also tried different keyboards, but no change.
Data:
Original Pi Pico2 V6.03.00 - but the error happened with older versions as well
KVM: ATEN CS1794 Cubiq
Is there anything that might explain or even fix this?
Cheers,
Fred
Martin H.
Posted: 05:16pm 19 Jul 2026
Hi Fred,
With the KVM switch, it seems you don’t have a permanent connection between the Pico and the Keyboard.
I don’t think the devices are meant to be unplugged and plugged back in whilst in use. After all, that’s all the KVM switch does.
It’s an interesting problem, but unfortunately I’ve got no other solution than to use a separate keyboard with the Pico.
Martin
'no comment
Amnesie
Posted: 06:51pm 19 Jul 2026
Hi
"... or suddenly repeats a key endlessly." same here. I also have to use it without a KVM switch.
Greetings
Daniel
fred777
Posted: 07:17pm 19 Jul 2026
No, this is not a cheap kvm, the clients don’t know
if you’re switching, usb stays connected and monitor as well (edid emulation)
Footnote added 2026-07-20 16:59 by fred777
I was referring to “ it seems you don’t have a permanent connection between the Pico and the Keyboard.
I don’t think the devices are meant to be unplugged and plugged back in whilst in use. After all, that’s all the KVM switch does.” … just to avoid confusion
Posted: 07:49pm 19 Jul 2026
Bear in mind that this isn't a "full fat" USB stack like you find in Windows. It's TinyUSB - appreciably cut down to be shoehorned into the available storage and, particularly, RAM. What you are seeing may not be a fault, merely something that was never included.
fred777
Posted: 09:38pm 19 Jul 2026
Understood, I’ll have a look on the TinyUsb GitHub
for similar issues
fred777
Posted: 07:03am 20 Jul 2026
  Amnesie said  Hi
Greetings
Daniel
What make/type of kvm are you using?
I’m trying out different kvms to see if the problem can be reproduced
Amnesie
Posted: 08:13am 20 Jul 2026
I am using the
AIMOS AM-KVM201-CL
Greetings
Daniel
