Local Time 01:59 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Video player
Posted: 04:53pm 16 Jun 2026
Here
RGB332 at 30fps from SDcard - coming in RC21. Will also work with buffered TFT drivers
You can already play RGB121 videos with the current release - see the manual
CONVERTER.pdf
File converter
vid2rgb121.zip
Sample video in RGB121
cartoon.zip
' RGB121 framebuffer video player  (companion to vid2rgb121.py)
' Fast path: each frame is read straight from the file into a RAM
' buffer with MEMORY INPUT (no INPUT$/LONGSTRING loop), then BLIT
' MEMORY decodes the RLE nibbles directly onto the LIVE screen
' (no framebuffer, no FRAMEBUFFER COPY).
' .vc frame layout on disk:
'     uint32  blobLen          (little-endian)
'     uint16  width | 0x8000    \  BLIT MEMORY header
'     uint16  height            /
'     bytes   rle...            (colour<<4)|count, count 1..15
' On HDMI/USB the base display must be 640x480; MODE 2 makes it a
' 320x240, 16-colour RGB121 surface:
'     OPTION RESOLUTION 640x480[,315000]   (one-off, persists)
Option EXPLICIT
Const F_HANDLER = 1
Const T_ESC     = 27
Drive "b:"
Dim STRING vidFile = "cartoon.121"
Dim STRING audFile = ""'"sample-2.aud"   ' set to "" if the clip has no audio
Dim FLOAT  fps     = 30               ' MUST match the converter's --fps
Dim FLOAT  frameMs = 1000 / fps
Dim INTEGER vDelay = 0                ' ms A/V sync nudge
' --- per-frame RAM buffer (NOT a long string: raw integer array) -----
' Holds one compressed frame blob (header + RLE). 320x240 worst case
' is ~76 KB; 9700 ints = 77.6 KB headroom.
Dim INTEGER buf%(9700)
Dim INTEGER baddr% = Peek(VARADDR buf%())   ' frame data address for BLIT MEMORY
Dim INTEGER lenbuf%(1)                        ' 16 bytes scratch for the length
word
' --- screen: MODE 2 draws straight to the live 320x240 RGB121 display
MODE 2
CLS
Dim INTEGER blobLen, frames = 0
Open vidFile For INPUT As #F_HANDLER
If audFile <> "" Then Play WAV audFile
Pause vDelay
Timer = 0
 If Eof(#F_HANDLER) Then Exit Do
 ' --- read the 4-byte little-endian blob length straight into RAM ---
 lenbuf%(0) = 0
 Memory INPUT F_HANDLER, 4, lenbuf%()
 blobLen = lenbuf%(0)                 ' low 4 bytes = length, upper pre-zeroed
 ' --- read the whole frame blob in one go, then decode onto screen ---
 Memory INPUT F_HANDLER, blobLen, buf%()
 Blit Memory baddr%, 0, 0
 frames = frames + 1
 ' --- pace to the encode fps so audio stays in sync (drift-free) ---
 Do While Timer < frames * frameMs
 Loop
 If Asc(Inkey$) = T_ESC Then Exit Do
Loop
Close #F_HANDLER
Play STOP
Print "Played "; frames; " frames in "; Str$(Timer/1000); " s"
End
dddns
Posted: 08:27am 22 Jun 2026
I have tested this with an ILI9341 and it runs perfectly smooth. Then I created a short (true-colour) clip and used vid2rgb121.py to convert. I had no errors and the converted clip played fine as well.
Of cause the colours of a true-colour image don't look good when converted to RGB121..
Could vid2rgb121.py be changed to allow diffent colour depths (for LCD) or could there be an option that each frame is dithered before it gets appended?
Posted: 08:56am 22 Jun 2026
vid2rgb121.py already supports RGB332, this will play in mode 5 HDMI or using one of the buffered TFT drivers.
CONVERTER.pdf
cartoon.zip
'     uint16  height            /
Option EXPLICIT
Const F_HANDLER = 1
Const T_ESC     = 27
Drive "b:"
Dim STRING vidFile = "cartoon.332"
Dim INTEGER lenbuf%(1)                        ' 16 bytes scratch for the lengthword
MODE 5
CLS
Pause vDelay
Timer = 0
lenbuf%(0) = 0
Blit Memory332 baddr%, 0, 0
frames = frames + 1
Loop
Loop
Close #F_HANDLER
Play STOP
End
dddns
Posted: 09:24am 22 Jun 2026
Thank you! I will update to RC23 and then report back
dddns
Posted: 01:00pm 22 Jun 2026
Thank you for the RGB332 player. It works fine with an ILI9341 setup and RGB332-rle.
I converted a 1,9Mb source file and got a 7,6Mb output. Audio conversion with default parameters also worked well:
python3 vid2rgb121.py ./small.mp4 sample_rle.332 --w 320 --h 240 --fps 25 --rgb332-rle
 200 frames, 6661 KB
Done: 218 frames, 7447.3 KB -> sample_rle.332
Audio: mono 22050 Hz 8-bit -> sample_rle.aud (188 KB)
Format: RGB332 count+value RLE, MODE 5 (~2.2x vs raw). Needs the RGB332-RLE firmware decoder.
 totalFrames = 218
 vidFile = "sample_rle.332"
 audFile = "sample_rle.aud"   (PLAY WAV)
 pace frames to 25 fps so audio stays in sync (targetTime = 40.00 ms/frame)
On the Pico, the video and the colours look ok and sound works good :
RUN
Played  218 frames in 8.898157 s
> 218/8.898157
24.49945534
> option list
PicoMite MMBasic USB RP2350B Edition V6.03.00RC23
OPTION SYSTEM SPI GP2,GP3,GP0
OPTION LCD SPI GP14,GP15,GP12
OPTION SYSTEM I2C GP4,GP5
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US, 0, 0, 250, 50
OPTION PICO OFF
OPTION CPUSPEED (KHz) 384000
OPTION LCDPANEL ILI9341BUFF, LANDSCAPE,GP16,GP17,GP18,GP11
OPTION TOUCH GP13,GP19
OPTION SDCARD GP10
OPTION KEYBOARD REPEAT 250,50
OPTION AUDIO GP6,GP7', ON PWM CHANNEL 3
OPTION RTC AUTO ENABLE
OPTION DEFAULT FONT 7, 1
OPTION PSRAM PIN GP47
I couldn't get it to work with RGB332 Raw:
[57] Memory INPUT F_HANDLER, blobLen, buf%()
Error : Source array too small
The header of the Python script contains the usage but not mentioning all parameters.
With the RGB121 player it also runs with the ILI9341 standard driver.
Posted: 01:12pm 22 Jun 2026
  Quote  Error : Source array too small
That might give you a clue
In raw form for 320x240 the array needs to be 320x240+8 bytes == DIM array%((320*240)\8) assuming base 0
dddns
Posted: 01:53pm 22 Jun 2026
Not really but it's hot in Germany :))
I thought it is this line:
But no matter how big it is dimmed it gives an error. First it will complain about too less heap. With PSRAM it keeps giving this error, I tried up to irrational high values..
But this was just a report, using Raw is not necessary as RLE compression runs fine and file sizes are 3x smaller..
homa
Posted: 05:21pm 02 Jul 2026
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 4194304
OPTION KEYBOARD GR
OPTION RESOLUTION 640x480 @ 315000KHz
OPTION SDCARD GP22, GP26, GP27, GP28
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION MODBUFF ENABLE  192
OPTION PLATFORM HDMIUSB
run playrgb332rle.bas
[41] If audFile <> "" Then Play WAV audFile
Error : Not enough Heap memory
The video will play with the commentary removed!
On the CLI:
play wav "DS-BIA.aud"
works too!
But unfortunately not both at the same time!?!
I’ve been playing around with the new release some more. This is what happens after a video has finished playing:
Played  6569 frames in 298.591049 s
> list pins
[LIBRARY] Print "GP"+Str$(_q%), MM.Info(pinno "GP"+Str$(_q%)),MM.Info(pin MM.Info(pinno "GP"+Str$(_q%)))""
Error : Not enough System Heap memory
It works after the reboot!
Edited 2026-07-03 03:52 by homa
Posted: 06:11pm 02 Jul 2026
looks like you need some psram
homa
Posted: 07:59pm 02 Jul 2026
  matherp said  looks like you need some psram
Is it possible to retrofit the PSRAM on the HDMIUSB reference board using the Pico2? Otherwise, I’ll need the new version 3
Posted: 09:57pm 02 Jul 2026
No, you need one of the later boards with direct mounted RP2350B chips
