Forum Index : Microcontroller and PC projects : MMBasic Anywhere ESP32-S3 and ESP32 (CYD) Port
| Page 1 of 2 |
| jvanderberg Regular Member Joined: 06/05/2026 Location: United StatesPosts: 86 |
MMBasic Anywhere ESP32-S3 and ESP32 (CYD) Port A short demo: https://www.youtube.com/watch?v=zf4n1SS0AKc I’ve spent the last month porting MMBasic to the ESP32-S3 and ESP32 classic. Both target the ESP-IDF. Because the IDF brings along its own framework and an RTOS, without PSRAM things get a bit tight. Most ESP32-S3s have PSRAM though, and it works well. I’ve tested on the Freenove 2.8” LCD Capacitive touch (this is like a fancy CYD) and the Adafruit ESP32-S3 Metro. I can recommend the Freenove over just about any CYD, it’s about the same price, has much better sound, PSRAM, and better touch. The Adafruit Metro is a good general purpose dev board, but you’ll have to BYO display and sound. Both ports support VGA out, though on the ESP32 classic bit depth is pretty limited because of memory constraints. You can download these in the latest releases: https://github.com/jvanderberg/PicoMiteAllVersions/releases/tag/latest MMBasic-Anywhere-esp32-cyd-merged.bin MMBasic-Anywhere-esp32-s3-octal-merged.bin MMBasic-Anywhere-esp32-s3-quad-merged.bin The octal/quad bifurcation is unfortunate. If you don’t get PSRAM working using the ‘octal’, try the ‘quad’. Sadly this can’t be a runtime option, so I have to publish two images. |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2149 |
Darn it...ANOTHER distraction I just happen to have the 7" CYD (ESP32-8048S070) |
Tried both S3 versions which loaded and verified and then connected via terminal but: Do you have a particular loading procedure? |
Need a bit more detail. What were you trying to do? The readmes in the port directories for each have detailed flashing instructions. |
Been looking all afternoon for readmes....Really shouldn't be this hard. WTF! |
https://github.com/jvanderberg/PicoMiteAllVersions/tree/main/ports/esp32_cyd https://github.com/jvanderberg/PicoMiteAllVersions/tree/main/ports/esp32_s3 |
I expect they're in the ports directories I don't know which you want but for example there's the esp32_s3 edit: both posting, great minds LOL John Edited 2026-06-17 05:16 by JohnS |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 669 |
Wow! Very cool |
| Hawk Senior Member Joined: 15/07/2021 Location: AustraliaPosts: 159 |
Wow, this is really cool. I have loaded the EPS32 CYD build onto my FabGL board and have it outputing to a VGA screen. OPTION VGA 22, 21, 19, 18, 5, 4, 23, 15 But I can only operate in Mode 3 because it doesn't have enough memory. I need to know how to disable the WIFI. I have tried; OPTION WIFI mm_options: loaded options from raw mmslots sector Error : Syntax I also need to know how to map the pins for the PS/2 keyboard. I have tried; OPTION KEYBOARD PINS 33, 32 mm_options: loaded options from raw mmslots sector Error : Option not supported on this port I've also tried configuring the SPI bus to connect an SD card but I get the following error; OPTION SYSTEM SPI 14, 13, 2 and OPTION SYSTEM SPI 14, 12, 2 Both commands give the following result. mm_options: loaded options from raw mmslots sector Error : Invalid pin Are you able to help me with this? I don't need WIFI, but it would be great to have Mode 1 and Mode 2 Thanks, Mike Edited 2026-06-22 18:14 by Hawk |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 925 |
Try OPTION WIFI "","" |
Thanks for the suggestion. option wifi "","" Output in serial terminal: mm_options: saved options to raw mmslots sector phy_init: failed to load RF calibration data (0x1102), falling back to full calibration |
The option wifi “”,”” Should turn off WiFi. CYDs are very memory constrained. I have not tested with a fabgl board. i haven’t tested ps/2 keyboard at all for these builds and my experience is that if I haven’t tested it it’s likely broken. Do you have a recommend fabgl board I could test with? It would be nice to create a profile for it. |
These are the cheapest ones around. LilyGo FabGL Board If you're just after the pin assignments, you can check here. https://github.com/fdivitto/FabGL/blob/master/fabgl%20GPIOs%20assignment.txt |
Btw. Does your fabgl board have psram? I make the assumption these board don’t but it looks like some do. |
I've ordered a FabGL (or two), seems these are popular enough that a dedicated configuration is called for, it will also give me a test for the PS/2 drivers, and a different VGA configuration. |
From what I can see online, it has 4 or 8 MB PSRAM...I think. Edited 2026-06-24 01:10 by Hawk |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 260 |
The LilyGo FABGL board has 4 MB QSPI Flash according to https://lilygo.cc/products/fabgl-vga32 On the FABGL GitHub page, there’s an 8088 IBM PC emulator and you can run Windows 3.0 on it. |
Any progress on the FabGL compatibility? Cheers. |
Yes it’s mostly done but the memory management, even with psram is a real pain. And I need to test the other esp32 targets to make sure I didn’t break them. Thanks for checking in. |
Thanks for the update. Thanks for your effort in getting it working. I'm looking forward to giving it a try. |
| Page 1 of 2 |
