Local Time 00:28 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Stepper engine and motion planner
PhenixRising
Posted: 10:46am 16 Jun 2026
I wonder if it would be possible to run the motion planner independent of the stepper
engine?
The idea is to be able to use the same G-code interpreter and motion planner to simply
provide X-vector, Y-vector, Z-vector, A-vector values that automagically appear/update
in BASIC so that they can be processed by PIDs.
Industrial CNCs (Siemens, Fanuc) update their vectors at a selectable rate of 125Hz or 250Hz.
The PID takes care of the rest.
