Local Time 02:09 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2350B Computer preassembled board form Silicon Chip
RicM
Posted: 02:40am 12 Jun 2026
Dear Members,
I have found on the above that Mode 3 in 4-bit colour is 16 colours.
Can anyone tell me the 16 colours.
RicM
Posted: 03:27am 12 Jun 2026
If this is the VGA one the colour pallet you see on the monitor is set by the resistor values. If it is the HDMI one you can map your own colours.
  Quote  MODE 3 640 x 480 x 16 colours.
Colour mapping to RGB555 palette.
This command line program should read out the valid colours from the screen buffer.
The value of M gives the primary colour, 0=blue, 1=green, 2=red and N is the level.
> mode 3
> for m=0 to 2:for n=0 to 255:c=n<<(m*8):pixel 9,9,c :if pixel(9,9)=c then:? m,n :endif:next:next
0       0
0       255
1       0
1       64
1       128
1       255
2       0
2       255
So that is black, RGB(0,0,0), RGB(0,0,255), RGB(0,64,0), RGB(0,64,255), RGB(0,128,0), RGB(0,128,255), RGB(0,255,0), RGB(0,255,255), RGB(255,0,0), etc. to RGB(255,255,255) white.
In reverse order.
white, yellow, lilac, brown, fuchsia, rust, magenta, red, cyan, green, cerulean, midgreen, cobalt, myrtle, blue and black.
To make the primaries visible on the screen:-
for m=0 to 2:for n=0 to 255:c=n<<(m*8):CLS c :if pixel(9,9)=c then:? m,n :Pause 999:endif:next:next
Or all 16.
for R=0 to 255 step 255:for G=0 to 255 step 64:for B=0 to 255 step 255:cls RGB(R,G,B):pause 555:next:next:next
Edited 2026-06-13 16:20 by phil99
