Local Time 02:09 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : > print mm.info(BOOT)       Error : Syntax
Andrew_G
Posted: 11:28pm 09 Jun 2026
I'm running a PicoMite (ver 5.070814) and when I
> print mm.info(BOOT)
I get "Error : Syntax"
Same with "print mm.info$(BOOT)"
If I "print mm.info(BOOT COUNT)" I get the correct number.
Any  suggestions?
Cheers,
Andrew
Posted: 12:41am 10 Jun 2026
mm.info(BOOT COUNT) came first
mm.info$(BOOT) didn't appear until a version or two later. V6.00.02 I think.
Update the firmware and you will have mm,info$(BOOT)
Andrew_G
Posted: 01:08am 10 Jun 2026
Thanks Jim (I suspected so . . .)
Not having touched my Mites for some time I have a lot of updating to do.
How is it down in Tassy today?
Andrew
Andrew_G
Posted: 02:13am 10 Jun 2026
Jim et al,
I tried to update to V6.02.01 and got the following on the MCC console:
Connected to COM7 at 115200
WebMite MMBasic RP2040 Edition V6.02.01
Copyright 2011-2026 Geoff Graham
Copyright 2016-2026 Peter Mather
[CYW43] Failed to start CYW43
It just keeps scrolling the error message.
I've tried:
- 'UPDATE FIRMWARE'
- Pressing the 'Bootsel' button
- loading an old 'Clear_flash.uf2' and then both of the above.
Any more clues?
I am very rusty so I could be doing any number of things wrong.
Cheers,
Andrew
Posted: 03:49am 10 Jun 2026
Was
  Quote  PicoMite (ver 5.070814)
Now
  Quote  WebMite MMBasic RP2040 Edition V6.02.01
Perhaps you have loaded the WebMite firmware on a standard RP2040.
V6.02.01 is the latest full release on Geoff's site but the latest release candidate is V6.03.00RC17
Edited 2026-06-10 13:50 by phil99
Andrew_G
Posted: 04:06am 10 Jun 2026
Hi Phil,
Thanks for that. The version via your link loaded no worries.
I'm absolutely sure that I had the right version but as you highlighted above I clearly didn't. AND I should have picked up the banner telling me so.
Now to reassemble my project and find the fault in my code that I need the BOOT reason for.
Cheers,
Andrew
ville56
Posted: 05:50am 10 Jun 2026
Andrew,
the bootsel button only works in conjunction with the reset button. Sequence is:
press bootsel and hold it !!!
press reset
release reset
release bootsel
this will make the pico to appear as a device in e.g. windows explorer and you can then just drag&drop the matching .uf2 file onto it.
Gerald
73 de OE1HGA, Gerald
