Local Time 01:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DIY pinball machine in Silicon Chip
zeitfest
Posted: 04:31am 29 May 2026
YESSS !!!!
I can see a whole new SIG starting ...
Posted: 12:57pm 29 May 2026
Nice !!
I assume they majority of the hardware is from/for actual pinball machines. Hard to get that operating well and sturdy enough without experience.
zeitfest
Posted: 11:00pm 29 May 2026
Yes the old machines certainly had to be pretty robust !
Hopefully the DTP is OK.
There is an intro  on their website.
lucas1298
Posted: 12:09pm 18 Jun 2026
I purchased the pcbs and am working through them, hoping to find some other people doing this project!
Posted: 06:52am 19 Jun 2026
Hi lucas1298,
Looking at the main controller board, I expect plenty of wiring. I have repaired several (Bally) pinball machines, and with individual wiring it is already a maze to find your way. But with the ribbon cables on the SC machine (despite it being a very simple design) prepare for cable spaghetti.
Sounds like a nice project, but no, I am not going to build it. But I am very curious about your project, so please publish progress here.
zeitfest
Posted: 01:10pm 19 Jun 2026
I wonder if a html display can be used as a baseboard under the pinball
play area ? It would be good to use the pinball interface with computer
graphics displays..
Posted: 01:18pm 19 Jun 2026
zeitfest
Yes, that could be done. Problem is all the holes you need through it for the mechanical parts (flipper, bumpers, etc..)
Posted: 01:25pm 19 Jun 2026
Make the base white (or something) and project the board down onto it?
zeitfest
Posted: 09:50am 20 Jun 2026
  Mixtel90 said   project the board down onto it?
sounds a good idea
I miss the electro-mechanical side of it - lots of inertia, thuds, noise, sparks, lights flashing, smell of arcs - but that is expensive to build . Somehow sitting and pressing keyboard keys doesn't have the same atmosphere.
The wackiest device I saw had a turret [temple god] which would bring back the past few pinballs as it rotated and vomited them back into the current game - fantastic !!
Using RC servos  and so on could create some new gadgets maybe.
To my surprise there is still some slot-car racing hanging on too. I wonder if a small video camera could run in the cars and the driver could see the road FPV ?
Posted: 10:43am 20 Jun 2026
I'm not sure that it has to be *that* expensive. Apart from the cost of a 3D printer to do the clever bits. Mind you, everyone apart from me seems to have one by now. lol
You can get cheap solenoids and springs now. Mosfets to drive them are cheaper than relays and a second one can be made to remove current limit during the closing inrush - the control logic to do it is stupidly cheap.
Rollovers can be springy wire forming either a traditional contact or a vane switch (so that they are frictionless, last forever and never need adjustment).
A SMPS that can handle the solenoids can be tucked away in a corner and you might even spend £10 on it!.
I bet you pay more for the programming time to flash the strings of LEDs. :)
The most expensive stuff is the case - sheets of acrylic, probably. The base can be the traditional plywood because there's nothing better.
