Local Time 02:09 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Audio sample rates and bit depth.
PhenixRising
Posted: 04:51pm 26 May 2026
Great video
The "null test" at around 21:40 is of particular interest to me although I can imagine a few audiophools screaming obscenities at their monitors
Martin H.
Posted: 05:15pm 29 May 2026
Before AI came along, we used to remove the vocals from songs to create backing tracks. As the vocals are usually positioned right in the centre of the stereo recording, they are equally loud on both sides. We’d invert one of the stereo channels and then mix it into the other channel.
'no comment
PhenixRising
Posted: 12:36pm 30 May 2026
  Martin H. said  Before AI came along, we used to remove the vocals from songs to create backing tracks. As the vocals are usually positioned right in the centre of the stereo recording, they are equally loud on both sides. We’d invert one of the stereo channels and then mix it into the other channel.
Sure, there are lots of apps like this one and they are quite amazing. Personally, I am not satisfied with the results and so I load them into a DAW (digital audio workstation) as separate tracks and replace them one at a time.
The interesting thing about the video, for me, is the fact that they demonstrate that a higher sampling rate doesn't mean "better".
I have the same beef with servo-motion-control; many years ago, it was established that a 1KHz PID sample-time was the sweet-spot and of course, AI agrees, only because it has become a belief. My real-world experiments don't agree. What puzzled me is that;
  Quote  For example, audio CDs have a sampling rate of 44100 samples/second. At 0.5 cycle/sample, the corresponding Nyquist frequency is 22050 cycles/second (Hz). Conversely, the Nyquist rate for sampling a 22050 Hz signal is 44100
However, for a closed-loop servomotor, they recommend five to ten times the bandwidth of the motor. Not the Nyquist two-times.
The definition of bandwidth is the time taken to reach ~63% of maximum velocity.
So if a 3000RPM motor can achieve 1800RPM in 0.01 seconds, it has a bandwidth of 100Hz. Therefore, "ten times the bandwidth" means a 1KHz PID sample rate.
In my world, a small motor is 1HP and it is mechanically coupled via belts or ball-screws or gear reducers to a load that has inertia/friction/stiction, etc. (mechanical LPF). So in my case and the majority of cases, the numbers are overkill. They waste processing power and I have found that lowering the sample-rate to 500Hz and 250Hz loses no performance and seems to result is easier loop tuning (only a feeling at this point).
Over the years, I have read countless publications pertaining to PID motor control but I am starting to suspect that many of these "authors" have never had actual experience with a real motor and are merely parroting/plagiarizing.
Posted: 04:27pm 30 May 2026
PID is a mathmatical calculation using proportional x, integral x, and differential x.
As such it is essentially a relation of third order. You can compare that to a electronic filter (i.e. LCL).
In a filter that results in a maximum roll off of 18dB per octave. Such is the picomite audio filter.
But real CD player filters that output 20kHz at 44.1kHz samplerate, require more than 100dB per octave, so they are not of order 3, but more like order 15. Either hardware, or multitap FIR
Similar you could work with a lower PID bandwidth if you created a PIIIIDDDD
Disadvantage is that the lower bandwidt, and increased number of taps, will slow down the step response. In analogy with the LCL filters: the group-delay will increase.
Edited 2026-05-31 04:13 by Volhout
PhenixRising
Posted: 05:25pm 02 Jun 2026
Step response is my point. In the real world it means a destroyed drive train or at best, an over current on the motor drive. Motors exist that claim a time constant of 10ms but this is free running. Now you need to couple it to an actual load...and reality sets in.
I have a publication, somewhere, quite fascinating; the required position accuracy was +/- 5 nanometres (!!!)
The total range of the piezo motor was 1mm and this was on zero friction air bearings. Theory dictates that the PID loop rate would need to be a minimum of 16KHz. In reality, it was achieved at 4KHz and increasing this rate did nothing.
Megapixels: Not too long ago, Canon reduced one of their cameras from 18MP to 12MP to achieve better image quality.
Typical marketing horse-hooey; bigger/faster is "better"
Martin H.
Posted: 07:35pm 03 Jun 2026
Here is a great example of how to use phase cancellation and how to apply it creatively
this song has no instruments in it
There's nothing better than ending the day with the perfect frequency response!
Edited 2026-06-04 05:40 by Martin H.
'no comment
PhenixRising
Posted: 02:57pm 04 Jun 2026
  Martin H. said  Here is a great example of how to use phase cancellation and how to apply it creatively
Amazing  When I get back to base, I will try it with big speakers
