Forum Index : Microcontroller and PC projects : GUI mouse usage
ville56
Posted: 05:06am 20 May 2026
Hi all,
I have a question regarding the usage of the mouse with the GUI subsystem. From what I unserstand it should be possible to use a mouse with various PicoMite firmware versions. The GUI subsystem should be available as well except for the HDMI and VGA versions.
I've taken a look at the "Advanced Graphics Functions for the PicoMite Firmware" manual and found references to the mouse usage at page 25.
  Quote  X = Mouse(x,1)
Y = Mouse(y,1)
Lb = Mouse(l,1)
lasttime = Timer
Gui Cursor x,y
as well as a reference on page 22 saying
  Quote  CLICK(DOWN) Will return true if the screen is currently being clicked on using the mouse.
which fails with e.g. "ERROR : UP is not declared"
As far as I have tried it out, the mouse() functions are not implemented in this way but can be replaced with decive() functions.
The "GUI CURSOR" I did not find anywhere.
I think it would be great if the mouse usage would be integrated into the GUI subsystem or, at least, there would be a possibility to "transfer" the current coordinated of the mouse position and mouse click action (like up/down) into the GUI subsystem for further processing.  IMHO basically everything is already there, except this integration.
Or is there a way to do so which I havent found out yet or isn't documented?
Thanks,
Gerald
73 de OE1HGA, Gerald
Posted: 06:49am 20 May 2026
Hi Gerald,
The GUI subsystem is not in VGA and HDMI builds, only in microcontroller builds.
The Mouse implementation in PM is to the user to engineer in your own GUI. The only direct implementation is in the built in editor.
So you can build your own GUI, and implement the mouse in it.
There is value in this, because HDMI screen resolutions will not show beautiful GUI elements that are designed on 320x240 screens. And only very few systems actually implement the mouse.
ville56
Posted: 12:04pm 20 May 2026
Volhout,
thanks for your answer. I'm fully aware that HDMI and VGA builds do not contain the GUI subsystem. What I ment is the fact that there are builds with GUI and mouse capabilities. So I thougt there could be an easy way, besides engineering my own GUI,  to include the mouse functions into the existing GUI. But you have made it clear to me, it's not.
Gerald
