Forum Index : Microcontroller and PC projects : ESP32 + touch
PeterB
Posted: 01:50am 20 May 2026
G'day All
To help me through this winter I bought a 5 in touch screen with ESP32-S3-WROOM chip attached. Using available documentation, I have managed to get HELLO WORLD running and that is as far as it goes. Where is the documentation that lets me draw on the 5 in screen?
Up to now I have used the PIC32MX470F with a 7 in screen so this is all a bit new to me.
I should also point out that I am 88.5 and sinking fast so please be gentle.
Peter.
RonnS
Posted: 02:08am 20 May 2026
Hello Peter, to support the ESP32 board, I can recommend the Annex Rapid Development System (Annex RDS). With it, you can quickly program your board in Basic, and many screens are also supported. You will also be able to meet a helpful fellow countryman there.
The  ESP32  isnt  Supported  by  MMBasic as far as this is concerned
PhenixRising
Posted: 07:19am 20 May 2026
I have the 7" version. Those things are really nice because they have the more resilient capacitive touch screen.
Code for pretty much anything already exists.
I experimented by writing some code in MMBasic, giving it to Google Gemini and asking it to convert to Arduino. It worked after I discovered that it was trying to use an out-of-date library.
amiga
Posted: 09:11am 20 May 2026
  PeterB said  G'day All
Peter.
Hi PeterB,
I found this interpréter ,not tested.
Basic32, seems to work like MMBasic.
https://www.basic32.com/
Have nice day ,
Posted: 09:50am 20 May 2026
  amiga said  I found this interpréter ,not tested.
Seems very crude, line-numbers and GOTOs, really horrid.  Maybe that's just the examples?
Edited 2026-05-20 19:50 by JohnS
PhenixRising
Posted: 01:07pm 20 May 2026
  JohnS said
really horrid.
Posted: 01:36pm 20 May 2026
From my own experience you have two choices:
Do everything in C++ via the Arduino IDE and associated mangled libraries
or use Annex RDS.
I never got on with either so I currently have two CYD modules sitting unused in a drawer. I have a feeling that one might be bricked, or it may be me that's too stupid and unworthy of such wonderful tech. :(
PhenixRising
Posted: 03:03pm 20 May 2026
There's Basic for Arduino (B4R)
It's a compiler and easy to get going with, especially if you use Gemini or Claude, etc.
BASIC syntax.
PeterB
Posted: 01:32am 21 May 2026
G'Day again.
Thanks for all your inputs. I did hope that the ESP32 system would be well defined and simple enough for an old bloke.
All projects start with wild enthusiasm quickly replaced by fear when the truth dawns then followed by the long uphill struggle. So shall it be this time. It's going to be a long, cold winter. But fun.
Peter
