Forum Index : Microcontroller and PC projects : QR Code
BishopXXL
Posted: 08:20am 19 May 2026
Hello,
since I have already received so much information and code
from you all, I would like to start by thanking you here.
I was looking for a solution that would allow me to
tell a mobile phone what IP address belongs to the client
that logged in after activating a hotspot.
To do this, I switch on the camera and scan the QR code
displayed on the screen. Of course, a real AP would be even nicer. ;)
Anyway, here is the code—generated with Claude Opus 4.5.
I find it useful for my purposes.
I wanted to share it with you.
BishopXXL
' QR-Code Generator fuer MMBasic
' PicoMite RP2350 - Display 320x240
' Version 1 QR-Code (21x21 Module)
' Byte-Mode, Error Correction Level L
' Eingabe: IP$ = "192.168.0.122" (max 17 Zeichen)
' Ausgabe: QR-Code auf Display
Option Explicit
Option Default None
' ---- Konfiguration ----
Dim IP$ Length 32
IP$ = "192.168.110.122"  ' <-- Hier IP-Adresse eingeben
' ---- Konstanten fuer QR Version 1, Level L ----
Const QR_SIZE = 21        ' 21x21 Module
Const DATA_CODEWORDS = 19 ' Daten-Codewords
Const EC_CODEWORDS = 7    ' Fehlerkorrektur-Codewords
Const TOTAL_CODEWORDS = 26
' ---- Display-Konfiguration ----
' ST7796S im RPORTRAIT Modus: 320x480 Pixel
Const DISPLAY_W = 320
Const DISPLAY_H = 480
Const MODULE_SIZE = 10    ' Pixel pro QR-Modul (10x10 = 210x210 gesamt)
Const OFFSET_X = 10       ' Linke obere Ecke X
Const OFFSET_Y = 10       ' Linke obere Ecke Y
' ---- Arrays ----
Dim Integer QR(QR_SIZE-1, QR_SIZE-1)      ' QR Matrix (0=weiss, 1=schwarz)
Dim Integer Reserved(QR_SIZE-1, QR_SIZE-1) ' Reservierte Bereiche
Dim Integer DataBits(256)                  ' Daten-Bitstream
Dim Integer Codewords(TOTAL_CODEWORDS-1)   ' Alle Codewords
Dim Integer GF_EXP(255)                    ' Galois Field Exp Table
Dim Integer GF_LOG(255)                    ' Galois Field Log Table
Dim Integer Generator(EC_CODEWORDS)        ' Generator-Polynom
Dim Integer BitCount, ByteIndex, i, j, x, y
Dim Integer BestMask, BestPenalty, Penalty, Mask
' Hauptprogramm
Sub Main
 Print "QR-Code Generator"
 Print "IP: "; IP$
 Print
 ' Galois Field initialisieren
 InitGaloisField
 ' Generator-Polynom berechnen
 CalcGenerator
 ' Daten codieren
 EncodeData IP$
 ' Reed-Solomon Fehlerkorrektur
 CalcErrorCorrection
 ' QR-Matrix aufbauen
 InitQRMatrix
 ' Daten in Matrix einfuegen
 PlaceData
 ' Beste Maske finden und anwenden
 BestMask = FindBestMask()
 ApplyMask BestMask
 ' Format-Information einfuegen
 PlaceFormatInfo BestMask
 ' QR-Code anzeigen
 DrawQRCode
 Print "Fertig! Maske: "; BestMask
End Sub
' Galois Field GF(256) initialisieren
' Primitives Polynom: x^8 + x^4 + x^3 + x^2 + 1 = 0x11D
Sub InitGaloisField
 Local Integer x, i
 x = 1
 For i = 0 To 254
   GF_EXP(i) = x
   GF_LOG(x) = i
   x = x * 2
   If x >= 256 Then x = x Xor &H11D
 Next i
 GF_LOG(0) = -1 ' Log(0) undefiniert
End Sub
' Galois Field Multiplikation
Function GF_Mul(a As Integer, b As Integer) As Integer
 If a = 0 Or b = 0 Then
   GF_Mul = 0
 Else
   GF_Mul = GF_EXP((GF_LOG(a) + GF_LOG(b)) Mod 255)
 EndIf
End Function
' Generator-Polynom fuer 7 EC-Codewords berechnen
' g(x) = (x-a^0)(x-a^1)...(x-a^6)
Sub CalcGenerator
 Local Integer i, j, temp
 ' Start mit g(x) = 1
 For i = 0 To EC_CODEWORDS
   Generator(i) = 0
 Next i
 Generator(0) = 1
 ' Multipliziere mit (x - a^i) fuer i = 0 bis 6
 For i = 0 To EC_CODEWORDS - 1
   ' Multiplikation mit (x - a^i) = (x + a^i) in GF(256)
   For j = EC_CODEWORDS To 1 Step -1
     Generator(j) = Generator(j-1) Xor GF_Mul(Generator(j), GF_EXP(i))
   Next j
   Generator(0) = GF_Mul(Generator(0), GF_EXP(i))
 Next i
End Sub
' Daten im Byte-Mode codieren
Sub EncodeData(text$)
 Local Integer i, len, val, bit
 Local Integer bitPos
 len = Len(text$)
 If len > 17 Then
   Print "Fehler: Text zu lang (max 17 Zeichen)"
   End
 EndIf
 bitPos = 0
 ' Mode Indicator: Byte Mode = 0100
 AddBits 4, 4, bitPos
 ' Character Count (8 Bit fuer Version 1 Byte Mode)
 AddBits len, 8, bitPos
 ' Daten-Bytes
 For i = 1 To len
   val = Asc(Mid$(text$, i, 1))
   AddBits val, 8, bitPos
 Next i
 ' Terminator (max 4 Bits)
 For i = 1 To Min(4, DATA_CODEWORDS * 8 - bitPos)
   AddBits 0, 1, bitPos
 Next i
 ' Auf Byte-Grenze auffuellen
 Do While (bitPos Mod 8) <> 0
 Loop
 ' Mit Pad-Bytes auffuellen (0xEC, 0x11 alternierend)
 i = 0
 Do While bitPos < DATA_CODEWORDS * 8
   If (i Mod 2) = 0 Then
     AddBits &HEC, 8, bitPos
   Else
     AddBits &H11, 8, bitPos
   EndIf
   i = i + 1
 Loop
 BitCount = bitPos
 ' Bits zu Codewords konvertieren
 For i = 0 To DATA_CODEWORDS - 1
   Codewords(i) = 0
   For bit = 0 To 7
     If DataBits(i * 8 + bit) Then
       Codewords(i) = Codewords(i) Or (128 >> bit)
     EndIf
   Next bit
 Next i
End Sub
' Bits zum Datenstrom hinzufuegen
Sub AddBits(value As Integer, numBits As Integer, ByRef bitPos As Integer)
 Local Integer i, mask
 For i = numBits - 1 To 0 Step -1
   mask = 1 << i
   If (value And mask) Then
     DataBits(bitPos) = 1
   Else
     DataBits(bitPos) = 0
   EndIf
   bitPos = bitPos + 1
 Next i
End Sub
' Reed-Solomon Fehlerkorrektur berechnen
Sub CalcErrorCorrection
 Local Integer i, j, coef, remainder(EC_CODEWORDS-1)
 ' Initialisiere Rest mit 0
   remainder(i) = 0
 Next i
 ' Polynom-Division
   coef = Codewords(i) Xor remainder(0)
   ' Rest nach links schieben
   For j = 0 To EC_CODEWORDS - 2
     remainder(j) = remainder(j + 1)
   Next j
   remainder(EC_CODEWORDS - 1) = 0
   ' Generator * coef addieren
   For j = 0 To EC_CODEWORDS - 1
     remainder(j) = remainder(j) Xor GF_Mul(Generator(EC_CODEWORDS - 1 - j), coef)
   Next j
 Next i
 ' EC-Codewords anhaengen
   Codewords(DATA_CODEWORDS + i) = remainder(i)
 Next i
End Sub
' QR-Matrix initialisieren mit Finder Patterns etc.
Sub InitQRMatrix
 Local Integer i, j, x, y
 ' Alles auf 0 (weiss) setzen
 For y = 0 To QR_SIZE - 1
   For x = 0 To QR_SIZE - 1
     QR(x, y) = 0
     Reserved(x, y) = 0
   Next x
 Next y
 ' Finder Patterns (3 Ecken)
 DrawFinderPattern 0, 0
 DrawFinderPattern QR_SIZE - 7, 0
 DrawFinderPattern 0, QR_SIZE - 7
 ' Timing Patterns
 For i = 8 To QR_SIZE - 9
   QR(i, 6) = (i + 1) Mod 2
   Reserved(i, 6) = 1
   QR(6, i) = (i + 1) Mod 2
   Reserved(6, i) = 1
 Next i
 ' Dark Module (immer schwarz)
 QR(8, QR_SIZE - 8) = 1
 Reserved(8, QR_SIZE - 8) = 1
 ' Format-Information Bereiche reservieren
 For i = 0 To 8
   Reserved(i, 8) = 1
   Reserved(8, i) = 1
 Next i
 For i = QR_SIZE - 8 To QR_SIZE - 1
   Reserved(i, 8) = 1
 Next i
 For i = QR_SIZE - 7 To QR_SIZE - 1
   Reserved(8, i) = 1
 Next i
End Sub
' Finder Pattern zeichnen (7x7)
Sub DrawFinderPattern(px As Integer, py As Integer)
 Local Integer x, y, dx, dy
 For dy = 0 To 6
   For dx = 0 To 6
     x = px + dx
     y = py + dy
     If x >= 0 And x < QR_SIZE And y >= 0 And y < QR_SIZE Then
       ' Aeusserer Rahmen oder Kern = schwarz
       If dx = 0 Or dx = 6 Or dy = 0 Or dy = 6 Then
         QR(x, y) = 1
       ElseIf dx >= 2 And dx <= 4 And dy >= 2 And dy <= 4 Then
         QR(x, y) = 1
       Else
         QR(x, y) = 0
       EndIf
       Reserved(x, y) = 1
     EndIf
   Next dx
 Next dy
 ' Separator (weiss, 1 Pixel breit)
 For i = -1 To 7
   x = px + i
   y = py - 1
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
   y = py + 7
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
 Next i
 For i = 0 To 6
   x = px - 1
   y = py + i
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
   x = px + 7
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
 Next i
End Sub
' Daten in die Matrix platzieren
Sub PlaceData
 Local Integer bitIndex, byteIndex, bit
 Local Integer x, y, col, upward, row
 bitIndex = 0
 col = QR_SIZE - 1
 upward = 1
 Do While col >= 0
   ' Spalte 6 ueberspringen (Timing Pattern)
   If col = 6 Then col = col - 1
   For row = 0 To QR_SIZE - 1
     If upward Then
       y = QR_SIZE - 1 - row
     Else
       y = row
     EndIf
     ' Zwei Spalten pro Durchgang
     For x = col To col - 1 Step -1
       If x >= 0 And Reserved(x, y) = 0 Then
         If bitIndex < TOTAL_CODEWORDS * 8 Then
           byteIndex = bitIndex \ 8
           bit = 7 - (bitIndex Mod 8)
           If (Codewords(byteIndex) And (1 << bit)) Then
             QR(x, y) = 1
           Else
             QR(x, y) = 0
           EndIf
           bitIndex = bitIndex + 1
         EndIf
       EndIf
     Next x
   Next row
   upward = 1 - upward
   col = col - 2
 Loop
End Sub
Function FindBestMask() As Integer
 Local Integer mask, penalty, bestMask, bestPenalty
 Local Integer tempQR(QR_SIZE-1, QR_SIZE-1)
 Local Integer x, y
 bestPenalty = 999999
 bestMask = 0
 ' Original QR speichern
     tempQR(x, y) = QR(x, y)
   Next x
 Next y
 For mask = 0 To 7
   ' Original wiederherstellen
       QR(x, y) = tempQR(x, y)
     Next x
   Next y
   ApplyMask mask
   penalty = CalcPenalty()
   If penalty < bestPenalty Then
     bestPenalty = penalty
     bestMask = mask
   EndIf
 Next mask
   Next x
 Next y
 FindBestMask = bestMask
End Function
' Maske anwenden
Sub ApplyMask(mask As Integer)
 Local Integer x, y, invert
     If Reserved(x, y) = 0 Then
       Select Case mask
         Case 0: invert = ((x + y) Mod 2 = 0)
         Case 1: invert = (y Mod 2 = 0)
         Case 2: invert = (x Mod 3 = 0)
         Case 3: invert = ((x + y) Mod 3 = 0)
         Case 4: invert = (((y \ 2) + (x \ 3)) Mod 2 = 0)
         Case 5: invert = (((x * y) Mod 2) + ((x * y) Mod 3) = 0)
         Case 6: invert = ((((x * y) Mod 2) + ((x * y) Mod 3)) Mod 2 = 0)
         Case 7: invert = ((((x + y) Mod 2) + ((x * y) Mod 3)) Mod 2 = 0)
       End Select
       If invert Then QR(x, y) = 1 - QR(x, y)
     EndIf
   Next x
 Next y
End Sub
' Penalty-Score berechnen (vereinfacht)
Function CalcPenalty() As Integer
 Local Integer penalty, x, y, count, last
 penalty = 0
 ' Regel 1: Zeilen mit 5+ gleichen Modulen
   count = 1
   last = QR(0, y)
   For x = 1 To QR_SIZE - 1
     If QR(x, y) = last Then
       count = count + 1
     Else
       If count >= 5 Then penalty = penalty + 3 + (count - 5)
       count = 1
       last = QR(x, y)
     EndIf
   Next x
 Next y
 ' Regel 1: Spalten mit 5+ gleichen Modulen
   count = 1
   last = QR(x, 0)
   For y = 1 To QR_SIZE - 1
       count = count + 1
     Else
       count = 1
       last = QR(x, y)
     EndIf
   Next y
 Next x
 CalcPenalty = penalty
End Function
' Format-Information platzieren
' Level L = 01, Mask Pattern = mask (3 Bit)
Sub PlaceFormatInfo(mask As Integer)
 Local Integer formatBits, i, bit
 Local Integer formatData, remainder
 Local Integer positions(14, 1)
 ' Format: 01 (Level L) + mask (3 Bit) = 5 Bit
 formatData = (&B01 << 3) Or mask
 ' BCH(15,5) Fehlerkorrektur
 remainder = formatData << 10
 For i = 14 To 10 Step -1
   If remainder And (1 << i) Then
     remainder = remainder Xor (&H537 << (i - 10))
   EndIf
 Next i
 formatBits = ((formatData << 10) Or remainder) Xor &H5412
 ' Positionen fuer Format-Bits (horizontal um Finder oben-links)
 ' Bits 0-5: Position (8,0) bis (8,5)
 ' Bit 6: Position (8,7)
 ' Bit 7: Position (8,8)
 ' Bits 8-14: Position (7,8) bis (0,8) - ABER Bit 6 ueberspringen!
 ' Erste Kopie (um oberes linkes Finder Pattern)
 For i = 0 To 5
   bit = (formatBits >> i) And 1
   QR(8, i) = bit
 Next i
 QR(8, 7) = (formatBits >> 6) And 1
 QR(8, 8) = (formatBits >> 7) And 1
 QR(7, 8) = (formatBits >> 8) And 1
 For i = 9 To 14
   QR(14 - i, 8) = bit
 Next i
 ' Zweite Kopie (rechts und unten)
 For i = 0 To 7
   QR(QR_SIZE - 1 - i, 8) = bit
 Next i
 For i = 8 To 14
   QR(8, QR_SIZE - 15 + i) = bit
 Next i
End Sub
' QR-Code auf Display zeichnen
Sub DrawQRCode
 Local Integer x, y, px, py, qw, qh, qx, qy
 ' Display loeschen
 Cls RGB(White)
 ' Quiet Zone Berechnung
 qx = OFFSET_X - MODULE_SIZE * 2
 qy = OFFSET_Y - MODULE_SIZE * 2
 qw = QR_SIZE * MODULE_SIZE + MODULE_SIZE * 4
 qh = qw
 ' Weisser Rand (Quiet Zone)
 Box qx, qy, qw, qh, 0, RGB(White), RGB(White)
 ' QR-Module zeichnen
     px = OFFSET_X + x * MODULE_SIZE
     py = OFFSET_Y + y * MODULE_SIZE
     If QR(x, y) = 1 Then
       Box px, py, MODULE_SIZE, MODULE_SIZE, 0, RGB(Black), RGB(Black)
     Else
       Box px, py, MODULE_SIZE, MODULE_SIZE, 0, RGB(White), RGB(White)
     EndIf
   Next x
 Next y
End Sub
' Programm starten
Main
End
dddns
Posted: 09:21am 19 May 2026
Really nice, thanks!
Posted: 09:30am 19 May 2026
Thank you,
Works fine on RP2040VGA.
BishopXXL
Posted: 09:43am 19 May 2026
Hallo,
In case anyone is still interested in an extension, I'm posting Version 2 (with 25x25 modules) so that "http://" fits before the IP address—something I really could have just built in right from the start! ;)
WebMite MMBasic RP2350A Edition V6.03.00RC9
' PicoMite RP2350 - Display 320x480
' Version 2 QR-Code (25x25 Module)
' Eingabe: IP$ = "http://192.168.0.122" (max 32 Zeichen)
Option Explicit
Option Default None
Dim IP$ Length 64
'IP$ = "http://192.168.110.122"  ' <-- Hier URL eingeben
IP$ = "http://" + MM.Info$(IP ADDRESS)   ' <-- Hier URL eingeben
' ---- Konstanten fuer QR Version 2, Level L ----
Const QR_SIZE = 25        ' 25x25 Module
Const DATA_CODEWORDS = 34 ' Daten-Codewords
Const EC_CODEWORDS = 10   ' Fehlerkorrektur-Codewords
Const TOTAL_CODEWORDS = 44
Const MODULE_SIZE = 8     ' Pixel pro QR-Modul (8x8 = 200x200 gesamt)
' ---- Arrays ----
Dim Integer DataBits(300)                  ' Daten-Bitstream
' Hauptprogramm
Sub Main
 Print "IP: "; IP$
 Print
 InitGaloisField
 CalcGenerator
 ' Daten codieren
 EncodeData IP$
 CalcErrorCorrection
 InitQRMatrix
 PlaceData
 ApplyMask BestMask
 ' QR-Code anzeigen
 DrawQRCode
End Sub
Sub InitGaloisField
 Local Integer x, i
 x = 1
 For i = 0 To 254
   GF_EXP(i) = x
   GF_LOG(x) = i
   x = x * 2
 Next i
End Sub
   GF_Mul = 0
 Else
 EndIf
End Function
Sub CalcGenerator
   Generator(i) = 0
 Next i
 Generator(0) = 1
   Next j
 Next i
End Sub
 len = Len(text$)
 If len > 32 Then
   Print "Fehler: Text zu lang (max 32 Zeichen)"
   End
 EndIf
 bitPos = 0
 ' Daten-Bytes
 For i = 1 To len
 Next i
 Next i
 Loop
 i = 0
   Else
   EndIf
   i = i + 1
 Loop
 BitCount = bitPos
   Codewords(i) = 0
   For bit = 0 To 7
     EndIf
   Next bit
 Next i
End Sub
   mask = 1 << i
   Else
   EndIf
   bitPos = bitPos + 1
 Next i
End Sub
   remainder(i) = 0
 Next i
 ' Polynom-Division
   Next j
   Next j
 Next i
 Next i
End Sub
Sub InitQRMatrix
     QR(x, y) = 0
     Reserved(x, y) = 0
   Next x
 Next y
 ' Alignment Pattern fuer Version 2 (Position 18,18)
 DrawAlignmentPattern 18, 18
 ' Timing Patterns
   Reserved(i, 6) = 1
   Reserved(6, i) = 1
 Next i
 For i = 0 To 8
   Reserved(i, 8) = 1
   Reserved(8, i) = 1
 Next i
   Reserved(i, 8) = 1
 Next i
   Reserved(8, i) = 1
 Next i
End Sub
 For dy = 0 To 6
   For dx = 0 To 6
     x = px + dx
     y = py + dy
         QR(x, y) = 1
         QR(x, y) = 1
       Else
         QR(x, y) = 0
       EndIf
       Reserved(x, y) = 1
     EndIf
   Next dx
 Next dy
 For i = -1 To 7
   x = px + i
   y = py - 1
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
   y = py + 7
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
 Next i
 For i = 0 To 6
   x = px - 1
   y = py + i
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
   x = px + 7
     QR(x, y) = 0
     Reserved(x, y) = 1
   EndIf
 Next i
End Sub
' Alignment Pattern zeichnen (5x5) - fuer Version 2+
Sub DrawAlignmentPattern(cx As Integer, cy As Integer)
 For dy = -2 To 2
   For dx = -2 To 2
     x = cx + dx
     y = cy + dy
       ' Aeusserer Rahmen oder Zentrum = schwarz
       If dx = -2 Or dx = 2 Or dy = -2 Or dy = 2 Then
         QR(x, y) = 1
       ElseIf dx = 0 And dy = 0 Then
         QR(x, y) = 1
       Else
         QR(x, y) = 0
       EndIf
       Reserved(x, y) = 1
     EndIf
   Next dx
 Next dy
End Sub
Sub PlaceData
 bitIndex = 0
 col = QR_SIZE - 1
 upward = 1
 Do While col >= 0
     If upward Then
     Else
       y = row
     EndIf
             QR(x, y) = 1
           Else
             QR(x, y) = 0
           EndIf
         EndIf
       EndIf
     Next x
   Next row
   upward = 1 - upward
   col = col - 2
 Loop
End Sub
 Local Integer x, y
 bestMask = 0
   Next x
 Next y
 For mask = 0 To 7
     Next x
   Next y
   ApplyMask mask
     bestMask = mask
   EndIf
 Next mask
   Next x
 Next y
End Function
' Maske anwenden
       Select Case mask
       End Select
     EndIf
   Next x
 Next y
End Sub
 penalty = 0
   count = 1
   last = QR(0, y)
       count = count + 1
     Else
       count = 1
       last = QR(x, y)
     EndIf
   Next x
 Next y
   count = 1
   last = QR(x, 0)
       count = count + 1
     Else
       count = 1
       last = QR(x, y)
     EndIf
   Next y
 Next x
End Function
   EndIf
 Next i
 For i = 0 To 5
   QR(8, i) = bit
 Next i
 For i = 9 To 14
   QR(14 - i, 8) = bit
 Next i
 For i = 0 To 7
 Next i
 For i = 8 To 14
 Next i
End Sub
Sub DrawQRCode
 ' Display loeschen
 Cls RGB(White)
 qh = qw
     Else
     EndIf
   Next x
 Next y
End Sub
' Programm starten
Main
End
