Forum Index : Microcontroller and PC projects : 6.02.01 Manual Error?
toml_12953
Posted: 04:33am 13 May 2026
On page 197 of the 6.02.01 manual in the description of PROGMEM it says
PEEK( PROGMEM, ±offset)
PROGMEM, will return a byte in the memory allocated to the program. Note
that there is a comma after the keyword PROGMEM.
Note that 'addr%' should be an integer.
Should addr% actually say offset?
Posted: 07:57am 13 May 2026
This is going to need Peter to clarify.
