Local Time 01:09 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is INC VAR now slower than VAR=VAR+1 with Tracecache?
PhenixRising
Posted: 10:04am 07 May 2026
OPTION EXPLICIT
OPTION DEFAULT NONE
Option Tracecache on 128
dim x as float
dim i as integer
x=1000000
timer = 0
do
 x=x/1.0001
 i=i+1
loop while x>1
print timer
In my case, this is 10ms faster than:
OPTION EXPLICIT
OPTION DEFAULT NONE
dim x as float
dim i as integer
x=1000000
timer = 0
do
 x=x/1.0001
 inc i
loop while x>1
print timer
