Local Time 02:31 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : STM32H7xxx with Cherry USB and mouse failure
rrroonn
Posted: 06:40am 07 May 2026
Given the pain this problem caused me, I am posting here in the off chance that if someone else has the same issue, it can be solved.
The Cherry USB is not well adapted to USB_FS and needed two changes to make a mouse work.
Change 1: usb_hc_dwc2.c
#if 0 // TODO: AI
This fix worked:
The STM32H7 internal FS PHY requires a strict configuration that generic DWC2
drivers often break when handling Low-Speed devices. The final working state
relies on three explicit hardware overrides:
Bit-Rate Throttling: Forcing LSDEV = 1 physically throttles the hardware to
send 1.5 Mbps pulses instead of 12 Mbps.
PHY Timebase: Locking FSLSPCLKSEL to 48 MHz (Selection 1) ensures the internal
digital sampling logic remains synchronized with the H7's core USB clock domain.
Frame Boundaries: Locking HFIR to 48000 prevents the driver from
incorrectly calculating an 8ms frame. It guarantees the hardware scheduler
maintains strict 1ms periodic boundaries for the Interrupt pipe.
The Host Controller is now firing the End-of-Frame Keep-Alives and
sampling the mouse's response at the correct frequency.
Correct code in ELSE block
       if ((hprt0 & USB_OTG_HPRT_PENA) == USB_OTG_HPRT_PENA) {
           regval = USB_OTG_HOST->HFIR;
           regval &= ~USB_OTG_HFIR_FRIVL;
           regval |= dwc2_calc_frame_interval(bus) & USB_OTG_HFIR_FRIVL;
           USB_OTG_HOST->HFIR = regval;
           if (g_dwc2_hcd[bus->hcd.hcd_id].user_params.phy_type == DWC2_PHY_TYPE_PARAM_FS) {
               if ((hprt0 & USB_OTG_HPRT_PSPD) == (HPRT0_PRTSPD_LOW_SPEED << 17)) {
                   if ((USB_OTG_HOST->HCFG & USB_OTG_HCFG_FSLSPCS) != USB_OTG_HCFG_FSLSPCLKSEL_6_MHZ) {
                       regval = USB_OTG_HOST->HCFG;
                       regval &= ~USB_OTG_HCFG_FSLSPCS;
                       regval |= USB_OTG_HCFG_FSLSPCLKSEL_6_MHZ;
                       USB_OTG_HOST->HCFG = regval;
               else {
                   if ((USB_OTG_HOST->HCFG & USB_OTG_HCFG_FSLSPCS) != USB_OTG_HCFG_FSLSPCLKSEL_48_MHZ) {
                       regval |= USB_OTG_HCFG_FSLSPCLKSEL_48_MHZ;
#else
                   /* Low Speed: 6 MHz clock requires exactly 6000 ticks for a 1ms frame */
                   USB_OTG_HOST->HFIR = 6000;
               } else {
                   /* Full Speed: 48 MHz clock requires exactly 48000 ticks for a 1ms frame */
                   USB_OTG_HOST->HFIR = 48000;
           } else {
               /* Non-FS PHY fallback logic */
#endif
Change 2: same file in dwc2_chan_char_init
   /* LS device plugged to HUB */
   if ((speed == USB_SPEED_LOW) && (usbh_get_port_speed(bus, 0) != USB_SPEED_LOW)) {
       regval |= USB_OTG_HCCHAR_LSDEV;
   // TODO:  (over-ride above code)
   if (speed == USB_SPEED_LOW) {
Getting keyboards to work on the STM32H743 was not too much of a problem, but mouse was a bitch.  Anyway hope this helps someone.
And yes, I used AI to help work this out but sometimes I wonder if AI is more trouble than its worth.
Too old for bs
