Local Time 01:09 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug in MMBasic 5.07.01
joker
Posted: 06:03pm 01 May 2026
Hello,
I recently discovered a bug in MMBasic 5.07.01 on my CMM2.
I defined a funktion like this:
FUNCTION convertToHex$(a%)
  convertToHex$=<do something>
END FUNCTION
If I run this program I get this error message: "Variable Name".
The reaon for this is that Hex$ is a reserved name in MMBasic and obviously it doesn't matter that Hex$ is part of a longer name. Changing the name or choosing a different return type than String make the message disapear.
The name is perfectly acceptable for MMB4L.
Maybe you know this problem already, but I haven't found any hint in this forum.
Therefore, I would be delighted, if we could get the MMBasic 6.xx on the CMM2 soon.
Best Regards
  Matthias
disco4now
Posted: 01:22am 02 May 2026
I can duplicate on on the latest CMM2 beta version. I will add to the list.
BIN$,OCT$ and HEX$ functions are replaced by BASE$(2, BASE$(8, or BASE(16, when a program is loaded to save function tokens.
F4 H7FotSF4xGT
