Local Time 02:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Autoconfig
DaveC5
Posted: 07:40am 25 Apr 2026
Is it possible to alter the OPTIONs based on an external input? Not all OPTIONs, perhaps, but maybe the screen resolution i.e. a short routine that checks for an input and sets the screen resolution based on it on-the-fly.
Also, is it possible to have this running as a kind of terminate-and-stay-resident?
Be gentle ... I'm not a programmer!
Dave
Posted: 11:55am 25 Apr 2026
RESOLUTION should be set as close to the native resolution of your monitor that you can get. This can be regarded as a hardware setting that you couldn't change via an external input.
MODE lets you change the display at any time, but the number of variations is restricted by the RESOLUTION. You can certainly change MODE depending on an external input.
Most OPTIONs are used to configure MMBasic to particular hardware. As such you shouldn't ever need (or want) to change them under software control - it would be like changing the attached hardware.
DaveC5
Posted: 02:18pm 25 Apr 2026
... unless of course, you wanted to change the hardware
Posted: 02:47pm 25 Apr 2026
Oh, you can change the hardware, that's not a problem. You just can't change it unless you configure MMBasic to use it - and you can't do that while MMBasic is using it. :)
AFAIK the options indicated in the manual as "permanent" are saved to a reserved flash area. They are used to set up things like audio and display drivers, where there may not be enough RAM to have more than one that can be used. The drivers for a particular version of MMBasic are there in the firmware, but you can't switch between them as their system requirements vary.
Different versions of MMBasic are specific. e.g. there are no VGA drivers compiled into the HDMI version and vice versa. They simply aren't there.
The different HDMI resolutions differ in CPU clock speed and you can't change that while MMBasic is running, only by restarting the CPU (triggered automatically by changing the resolution).
DaveC5
Posted: 03:12pm 25 Apr 2026
Thanks Mick.
What I'm wondering then is; is it possible to run a routine *on startup* that performs a simple check on an external (something e.g. resistor value) that then invokes the OPTION RESOLUTION command, which will then reboot the Pi into the correct mode for the hardware that the (something) has identified.
Probably a daft idea, but I'm tinkering with the idea of building Peter's Palm Pico but without the display/keyboard built-in, just with a header connector to which I can plug either a small hand-sized keypad and screen for portability or a larger keyboard and screen for convenience. That way I could cart round the same core computer but configure it as a handheld, tablet(-ish) or laptop scale device.
I'm sure there would be a way of manually reconfiguring the display setting, but I thought it would be neat if the Pi just checked a resistor value or something and then automatically configured itself to whichever platform it found itself. Assuming the different formats used the same LCD chip.
Dave.
Posted: 03:26pm 25 Apr 2026
I don't think you can as I think it has to be entered at the command line.
You could try the EXECUTE command, with your program set to AUTORUN. The EXECUTE would change the CPU speed and cause it to reboot - hopefully starting your program. Unfortunately some commands are specifically blocked from being EXECUTEd and RESOLUTION could well be one of them. You couldn't call it from a routine, your program would start as from NEW.
EDIT:
On further reading, have you tried a simple OPTION RESOLUTION nn [,cpuspeed] command in your program? The system may reboot anyway, but if you use AUTORUN it should restart in the new resolution. You could VAR SAVE info before doing it to get the correct mode number or something.
ANOTHER EDIT:
Ah!... You mentioned LCD chip. There are no OPTION RESOLUTION or MODE commands, your resolution and colour depth are set by the LCD display, which is defined in the OPTION command. Once again, you could try to run that option in your program before anything writes to the display.
Edited 2026-04-26 01:44 by Mixtel90
mozzie
Posted: 03:37pm 25 Apr 2026
G'day Dave,
There is the command END cmd$ that will exit from a program and run the cmd$ string at the command prompt, just tried the following and it may do what you require:
' prog to test resolution change
if MM.HRES = 640 then End "Option Resolution 800x480"
end
If you run this with the resolution set to 640 then it will reset the resolution to 800x480
So the following may work:
'prog to set screen resolution
' setup pins etc
if (pin(gp0)=0) and (MM>HRES <> 640) then END "Option Resolution 640"
if (pin(gp0)=1) and (MM>HRES <> 800) then END "Option Resolution 800x480"
Option Autorun should restart the program again.
Hope this helps, I've learnt something new for today
Regards, Lyle.
Edited 2026-04-26 01:47 by mozzie
DaveC5
Posted: 03:43pm 25 Apr 2026
Thanks Mick and Mozzie,
That's given me something to think about.
First problem is squashing everything into something the size of a gnat's knapsack.
Dave
