Local Time 02:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : AUTOSAVE CRUNCH
Gerad
Posted: 12:14pm 20 Apr 2026
Hello
“WebMite MMBasic RP2350A Edition V6.02.01”
When I try to use “AUTOSAVE CRUNCH,” I get the message “Error: Invalid syntax.” According to the WebMite/PicoMite 6.x documentation, AUTOSAVE CRUNCH is valid syntax. Does anyone have any idea why this error is occurring?
Best regards
Gerard
Posted: 12:42pm 20 Apr 2026
Bug introduced when autosave N was introduced and no-one noticed til now - will fix
PhenixRising
Posted: 01:05pm 20 Apr 2026
Is this also something that MM Replace can help with?
The way I understand it, MM Replace can pre-process the BASIC code to substitute shorter var & function names for longer ones but I don't remember seeing it discussed.
