Local Time 02:31 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Convert small 64bit signed integer into a high and low byte ?
DigitalDreams
Posted: 05:18pm 14 Apr 2026
My next challenge is to save signed integers to an I2c memory chip. They will only range from say -300 to +900 so will be saving as two bytes (high and low) as if a 16bit integer, not the incoming MMBasic 64bit.
For example -
Dim as integer Xmin,Dhi,Dlo
Xmin=-298
I2c write &h50,0,4,1,0,Dhi,Dlo
I'm already writing small positive MMBasic 64bit integers as single bytes as MMBasic converts/truncates to 8bit in the i2c command itself.
Wondering what the fastest and most efficient way would be to do this ?
Posted: 05:23pm 14 Apr 2026
bin2str$ was designed for specifically this
Edited 2026-04-15 03:23 by matherp
DigitalDreams
Posted: 05:37pm 14 Apr 2026
  matherp said  bin2str$ was designed for specifically this
I'll have a play sir....
bfwolf
Posted: 09:58pm 14 Apr 2026
A kind of "hack"  according to C, which relies on the Pico using an ARM with a little-endian format:
Dim XminAddr As integer
XminAddr = PEEK(VARADDR Xmin)
Dlo = PEEK(BYTE XminAddr)
Dhi = PEEK(BYTE (XminAddr+1))
DigitalDreams
Posted: 10:02pm 14 Apr 2026
First attempt results in "Error : Argument Count"
a$=Bin2Str$(INT16,xmin,BIG)
I2C2 write &h50,0,4,1,0,a$
Hence writing 4 bytes... '1','0','2byte string' ??
DigitalDreams
Posted: 10:04pm 14 Apr 2026
  bfwolf said  A kind of "hack"  according to C, which relies on the Pico using an ARM with a little-endian format:
Interesting 😎
Posted: 11:33pm 14 Apr 2026
  Quote  First attempt results in "Error : Argument Count"
When writing a string to a 24Cxx EEPROM the 2 address bytes need to be added to the start of the data.
So perhaps try:-
a$ = Chr$(Mem.addr>>8) + Chr$(Mem.addr And 255) + a$ 'prepend 2 byte memory address to the data
I2C2 WRITE I2C.addr, 0, Len(a$), a$   'write 2 memory address bytes + up to 32 data bytes
Pause 6  'allow time to write
Currently you are trying to write a mix of integer bytes and a string which I2C WRITE doesn't accept.
Edited 2026-04-15 11:04 by phil99
DigitalDreams
Posted: 06:07pm 15 Apr 2026
  phil99 said  Currently you are trying to write a mix of integer bytes and a string which I2C WRITE doesn't accept.
  matherp said
Done, created a 4byte string by concatenation of the 2 individual FRAM address bytes (INT8) and the 16bit signed integer data (INT16) into one string for a single I2C2 string write (adding three Bin2Str$ together).
Reading back was much simpler as the I2C read is preceeded by an I2C write that simply sets the FRAM address of the two data bytes that are then I2C read into a string in Str2Bin format.
Don't think there's a more efficient/faster way at the moment unless Peter adds the ability into I2C2write 😎...
Edited 2026-04-16 05:58 by DigitalDreams
PhenixRising
Posted: 08:37pm 15 Apr 2026
I find the
  Quote  pause 6
To be a bit offensive
Is it required?
Furthermore, I believe that in the manual, there's a paragraph that suggests the maximum speed is still 400KHz whereas elsewhere, it has been updated to 1000KHz.
Posted: 09:35pm 15 Apr 2026
  Quote  pause 6
Is it required?
Not if you are doing a single write. If writing to more than 1 32 byte page you get a garbled mess if you don't space the writes out.
It doesn't have to be a pause, you could do the writes triggered by a timer or in a tick sub.
bfwolf
Posted: 10:16pm 15 Apr 2026
I just looked at the datasheet for the Microchip 24LC512 and it says the following:
  Quote  This initiates the internal write cycle and
during this time, the 24XX512 will not generate
Acknowledge signals
I assume this behavior is common to many I2C EEPROMs?
This would mean that as long as the write cycle is still ongoing, a read command (to any address, or more precisely, to the LastWriteAddress + 1) will not be acknowledged, and this behavior can be interpreted as "busy"!
This way, a fixed (and unnecessarily long) delay could be avoided.
Regards, bfwolf.
Posted: 07:19am 16 Apr 2026
Hi bfwolf,
That is the correct way to do it, but in MMbasic that means you will need to poll in a loop until you do not an I2C error anymore. So MMBasic is busy.
So it is not better than a simple "PAUSE 6" (unless a particular fast I2C chip is ready in 4ms).
Posted: 08:42am 16 Apr 2026
It appears you can trim some time off, depending on the chip.
> d$ = "ABCDEFGHIJKLMNOPQRSTUVWXYZ012345" '32 bytes
> d$= bin2str$(uint16,48,big)+d$
> i2c2 write &H57,0,len(d$),d$ :t=timer :do :i2c2 read &H57,0,26,d$ :loop until MM.I2C=0 :t= timer-t :?t
2.379
2.372
bfwolf
Posted: 08:57am 16 Apr 2026
  Volhout said  Hi bfwolf,
I just took a quick look at some I2C EEPROM datasheets from various manufacturers (which we have archived on a server at work) and noticed the following:
Many have "WriteCycleTime = max. 5ms", but the AT24C1024, for example, has 10ms — so 6ms might even be too short!
Sure, "PAUSE 6" is the easy way, which probably works 90% of the cases — but it can also sometimes be too short — or usually too long.
By the way, I initially thought "PAUSE 6" would pause for 6 seconds...
@phil99: Good example code shown!
Regards, bfwolf
Posted: 01:18am 17 Apr 2026
A better speed tester. This one doesn't waste time reading back a lot of bytes, 1 is all that is needed.
Print "Page write speed test for 24C32 EEPROM on I2C2"
Dim Wr$, Re$, tmp$, n%, t, I2C.addr = &H57
Print "Make future failure to write visible."
tmp$ = "Fail"
For n%= 0 To 95 Step 4
  Wr$ = Chr$(0)+Chr$(n%)+tmp$
  I2C2 write I2C.addr, 0, Len(Wr$), Wr$
  Pause 9
Next
  Print "Verify data was written"
  I2C2 write I2C.addr, 0, 2, 0, 0 : I2C2 read I2C.addr, 0, 96, Re$
  Print Re$ : Print
  Wr$ = "" : tmp$ = "" : Re$ = ""
For n% = 32 To 127 'make 3 pages of data
  Inc Wr$, Chr$(n%)
Next
Print "Test Data"
Print Wr$ : Print
For n% = 0 To 64 Step 32
  tmp$ = Mid$(Wr$,n%+1,32)
  Print tmp$
  tmp$ = Chr$(0) + Chr$(n%) + tmp$
  I2C2 write I2C.addr, 0, Len(tmp$), tmp$
  t=Timer:Do :I2C2 read I2C.addr,0,1,Re$:Loop Until MM.I2C<>1:t=Timer-t
  Print "Time to Write a Page = ";t;"mS" : Print
Next
Print
Re$ = ""
Print " Check saved data for errors."
Print Re$
If Re$ = Wr$ then Print "  Data validated" else Print "  Validation failed!"
End
A:> RUN
FailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFailFail
Test Data
!"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~
Time to Write a Page =  1.806000002mS
Time to Write a Page =  1.787999999mS
Time to Write a Page =  1.789999999mS
Data validated
A:>
So for this chip a 2mS pause is enough.
Edited 2026-04-17 13:56 by phil99
Posted: 07:38am 17 Apr 2026
You can't go shorter than what it says on the spec sheet for the chip. That's the timing that the manufacturers know will work. Some chips might be faster on test but one from the next batch might be only just within the spec figure.
Posted: 07:52am 17 Apr 2026
This line, instead of a Pause...
will let the chip take as much time as it needs but no more.
Footnote added 2026-04-17 18:44 by phil99
In view of Peters comment below perhaps this could be used instead.
t=timer :Do :I2C2 read I2C.addr,0,1,Re$:Loop Until MM.I2C<>1 Or timer-t >6
Posted: 08:29am 17 Apr 2026
  Quote  his line, instead of a Pause...
This is a bad idea. This could wait for the default I2C timer to expire (1 second) before returning depending on what the device does with the early request.
If you have a device that needs a 5mSec wait then you need to wait 5mSec. The way to do this without blocking would be a settick callback timer
Edited 2026-04-17 18:32 by matherp
Posted: 11:32am 17 Apr 2026
Good point, added a 5mS timeout to the loop and a counter to record the number of times the timeout is reached.
Then made it loop continuously to see how often this happens.
Dim Wr$, Re$, tmp$, n%, t, LC%, LT, TOut%, I2C.addr = &H57
  Inc Wr$, Chr$(n%)
Next
Print "Test Data"
Print Wr$ : Print
  Print tmp$
  t=Timer:Do :I2C2 read I2C.addr,0,1,Re$:Loop Until MM.I2C<>1 Or Timer-t>5:t=Timer-t
  If t>5 Then
    Print "*********** 5mS Timout Exceeded ************"
    Inc TOut%
  EndIf
 Next
 Print
 Re$ = ""
 Print Re$ ': Print
 If Re$ = Wr$ Then Print "  Data validated" Else Print "  Validation failed!"
 If t > LT Then LT = t
 Inc LC%
 Print "Loop Count =";LC%, "Max. Write Time =";LT, "Number of Timeouts =";TOut%
 Print  "Start again" : Print : Print
Loop
End
Time to Write a Page =  1.767999999mS
Time to Write a Page =  1.83mS
Time to Write a Page =  1.825999999mS
 Data validated
Loop count = 7574       Max. Write Time = 1.833000001    Number of Timeouts = 0
Start again
Time to Write a Page =  1.824999999mS
Time to Write a Page =  1.821mS
Time to Write a Page =  1.823000001mS
 Data validated
Loop count = 7575       Max. Write Time = 1.833000001    Number of Timeouts = 0
Start again
Edit.
A longer run.
 Data validated
Loop count = 84732      Max. Write Time = 1.833000001   Number of Timeouts = 0
Start again
Edited 2026-04-17 22:07 by phil99
DigitalDreams
Posted: 12:22pm 01 May 2026
Hi Peter
Worked well in that case yet I face a new challenge. Reading temperature and pressure data in 24-bit signed format. Three consecutive bytes (or 6 consevutive bytes for both). Bin2str$ and it's counterpart have no 24-bit options. It seems I have to do this conversion manually....
