Forum Index : Microcontroller and PC projects : Change / Create ARRAY size in SUB / FUNCTION
Mark
Posted: 01:08pm 06 Apr 2026
Is it possible to change the array size that it returned or referenced in a SUB or FUNCTION?
I would like to have a FUNCTION or SUB that queries a data file looking for 0 or more matches and returns (somehow) an array with the found matches.
I've only come up with two solutions thus far. Neither is as ideal / clean as I would like.
1) Use a global array and use REDIM in the function.
2) Split the lookup logic such that it first returns the number of matches. The calling code then creates an array of the appropriate size and passes that to the second part of the lookup routine that populates that array.
Thanks,
Mark
Posted: 02:49pm 06 Apr 2026
What's your objection to "1) Use a global array and use REDIM in the function."
I use that extensively in PicoDB, especially REDIM PRESERVE on an array of structure elements before using STRUCT SORT in order to reduce the sort to the not-fixed number of elements (for instance, results of a query).
Posted: 03:06pm 06 Apr 2026
Don't you save heap by using a global array?
Mark
Posted: 06:36pm 06 Apr 2026
Rethinking the use cases, the global array should work.
Thanks,
Mark
