Forum Index : Microcontroller and PC projects : Editor font.
Fede
Posted: 09:48am 03 Apr 2026
The editor is very useful and I use it all the time.
Is it possible to change the font in the built-in MMBasic editor?
Font 1 is fine, but font 7 would also be suitable for comfortable working. Font 8 would be for large screens and extreme cases.
That way, I could fit more text on the screen and have longer lines.
Many thanks.
PeteCotton
Posted: 04:33pm 04 Apr 2026
Yes.
OPTION EDIT FONT SMALL
OPTION EDIT FONT NORMAL
etc.
And use it with OPTION DEFAULT MODE to set your default display resolution (for larger screens).
Edited 2026-04-05 02:34 by PeteCotton
Posted: 04:52pm 04 Apr 2026
The editor has been re-worked in the 6.02.02 beta for VGA and HDMI versions as follows:
  Quote  Editor Entry Decision Logic
When the editor is invoked, three values are sampled: the current display mode (DISPLAY_TYPE), the current font (via gui_font_width), and Option.ColourCode. The key metric is chars_per_line = HRes / gui_font_width.
Five rules, evaluated in order:
# Condition Action
1 chars_per_line ≥ 64, ColourCode = 0 No mode or font change. Tiles set to white-on-black (Mode 1 only).
2 chars_per_line ≥ 64, ColourCode = 1, mode ≠ 1 No change. Colour coding works natively in Modes 2–5.
3 chars_per_line ≥ 64, ColourCode = 1, Mode 1, font width divisible by 8 No change. Font aligns to tile boundaries so colour coding works.
4 chars_per_line ≥ 64, ColourCode = 1, Mode 1, font width NOT divisible by 8 Switch font to font1 (8×12) so tiles align. Mode stays at 1. HDMI high-res (≥1024) uses font3 (16×24) instead.
5 chars_per_line < 64 Switch to Mode 1 and font1 (8×12). HDMI high-res uses font3 (16×24).
Only rules 4 and 5 change anything. Rules 1–3 preserve the user's mode and font untouched.
After the decision block:
The framebuffer is cleared (memset WriteBuf).
If in Mode 1 without ColourCode, all tiles are forced to white-on-black so the 1-bit framebuffer is readable.
ytileheight is set to gui_font_height for tile-row calculations.
If ColourCode is on, gui_fcolour/gui_bcolour are set to white/black and the screen is cleared.
If editing program memory (cmdfile), ClearRuntime is called — which internally calls ResetDisplay and overwrites the font. The font chosen by the decision block is saved beforehand and restored immediately after.
Separator line: drawn in GUI_C_LINE (magenta) when ColourCode is on, or gui_fcolour (white) when ColourCode is off.
Editor Exit
The original mode and font (saved as oldmode/oldfont) are always restored unconditionally via ResetDisplay() + SetFont(oldfont).
The do_end() path (for program-memory editing) calls setmode() which also calls ResetDisplay(), so SetFont(oldfont) and PromptFont = oldfont are applied again after do_end() returns, before longjmp back to the prompt.
Peter63
Posted: 04:00am 05 Apr 2026
Hello, Fede
Are you using PicoCalc ?
/Peter63
Fede
Posted: 06:00am 05 Apr 2026
Thanks. Thank you so much for the information.
I don't use PicoCalc much.
I program in the VGAPicoMite that I built myself and then check if it works in PicoCalc.
I find it more convenient that way.
And while we're at it, here are a few photos.
The bad thing is that my short vacation is about to end.
Peter63
Posted: 06:22am 05 Apr 2026
  Quote  I program in the VGAPicoMite that I built myself and then check if it works in PicoCalc.
Ok, I also usually do something similar when I test things.
  Quote  Is it possible to change the font in the built-in MMBasic editor?
Have you tried so you get longer lines?
/Peter63
Posted: 06:41am 05 Apr 2026
Despite limited screen width lines can be 255 characters.
One method is to press <enter> just before the edge of the screen and continue on the next line. When the line is complete go back and delete the unwanted CR.
You won't be able to see the rest of the line but it is still there.
If you need to edit that line break it with <enter> near the RHS and the next portion appears.
And the other
  p102 said  OPTION CONTINUATION LINES ON/OFF
Enables or disables the use of continuation lines in the editor and with the LIST command.
Line continuation is indicated by a space followed by an underscore character at the end of a line.
When enabled the editor will automatically split lines as it reads them from file and add the continuation characters required.
When exiting the editor, the continuation characters are removed before saving.
While in the editor the user can create long lines by adding their own continuation characters.
This makes using a small screen as a console much easier.
Edited 2026-04-05 16:45 by phil99
Fede
Posted: 07:45pm 05 Apr 2026
  PeteCotton said  Yes.
etc.
It's a shame, but that command no longer exists.
I haven't been able to get font 7 to work in the editor.
Oh well, it's not too bad.
Thanks to everyone for the advice.
toml_12953
Posted: 08:26pm 05 Apr 2026
etc.
What version has OPTION EDIT in it? I can't find it in the 6.00.01 manual and it doesn't seem to work in 6.00.02b0, at least on a PicoCalc. Is it for VGA/HDMI only? Where can I find a manual that includes it?
Posted: 08:48pm 05 Apr 2026
  Quote  It's a shame, but that command no longer exists.
Never did - it is a CMM2 command
You don't say what version so diffiecult to give the answer. On RP2350 VGA or HDMI then
OPTION DEFAULT MODE 3
OPTION LCDPANEL CONSOLE 7
Fede
Posted: 03:33pm 06 Apr 2026
Oh, thank you so much! Almost!
Everything changes except the editor.
I'm using an RP2350 VGA version 6.0201.
Sorry for the omission.
Posted: 04:26pm 06 Apr 2026
You need the 6.02.02 beta
Fede
Posted: 06:13pm 06 Apr 2026
Ok. Thank you.
