Local Time 03:10 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Produce wobble tones
Frank N. Furter
Posted: 10:20am 17 Mar 2026
I would like to set up a simple hearing test and need to generate wobble tones ranging from 125 Hz to 8 kHz. The frequency sweep should cover approximately 4% to 12.5% of the centre frequency, and the modulation frequency should be around 8 Hz, following a triangular waveform.
Can I achieve this using an Picomite, and if so, how?
Frank
Posted: 10:43am 17 Mar 2026
Would something like this be adequate?
do :for n=900 to 1100:play tone n,n: pause 5:next :for n=1100 to 900 step -1:play tone n,n: pause 5:next :loop
I don't have an amplifier set up at the moment so can't hear the result but it runs without error.
Edited 2026-03-17 20:47 by phil99
Posted: 10:59am 17 Mar 2026
Hi  Phil,
Your modulation frequency is 0.5Hz (200 steps @5ms x2).
Frank, is there a requirement for output ? sine wave ? square wave ?
I have a program to create a function generator, using an external resistor network as a DAC. The waveform is mathmatically calculated, so the math should be capable of calculating the desired waveform, and you "stream it" out.
The waveform is a MMbasic array, by tuning the PIO frequency you "wobble".
This (most likely, not tested) can be achieved by direct writing to the PIO frequency divider (not by re-initializing the PIO, becuase that would generate clicks).
This is the code
'test HW for sine wave generator using DMA and PIO
'there is a flaw: the DMA stops after 2^32 sine samples
'this is running in basic
bits% = 8
length% = 4096          'allows up to 16kHz full resolution
'Dim o%(length%-1)
level=2^(bits%-1)*0.9   'amplitude of sine signal
'calculate sinewave table
'calc_sin
'pack data in ring buffer
Dim pkd%
PIO make ring buffer pkd%,length%*8  'length in 32 bit fifo values
'PIO make ring buffer pkd%,length%*4  'length in 32 bit fifo values
'PIO make ring buffer pkd%,length%     'length in 8 bit fifo values
'pio pins
SetPin gp6,pio1
SetPin gp7,pio1
SetPin gp8,pio1
SetPin gp9,pio1
SetPin gp10,pio1
SetPin gp11,pio1
SetPin gp12,pio1
SetPin gp13,pio1
'pio program
PIO assemble 1,".program out"
PIO assemble 1,".line 0"
PIO assemble 1,"mov osr ,!null" 'fill osr with &hffffffff
PIO assemble 1,"out pindirs,8"  'set all associated pins (8) output
PIO assemble 1,".wrap target"
PIO assemble 1,"pull noblock"   'get data from fifo
PIO assemble 1,"out pins,8"     'write out to 7(8) pins
PIO assemble 1,"out pins,8 [1]" 'write out to 7(8) pins delay 1 --- 8bit transfers only
PIO assemble 1,".wrap"
PIO assemble 1,".end program"' list"
'pio config
f=133e6               'modify this value to tune to other frequencies
p=Pio(pinctrl 0,0,bits%,,,,gp6)
e=Pio(execctrl gp0,Pio(.wrap target),Pio(.wrap))
s=Pio(shiftctrl 0,0,0,0,0,1)
'here we do UI and create sine waves
 'input frequency
 Input "what frequency ";x
 y%=1+x/16000            'y%=number of sine cycles in one buffer
 f=x*2*length%/y%
 Print x,y%,f
 'Timer = 0
 'stop running machine
 If MM.Info(PIO TX DMA)=1 Then PIO dma tx off
 'calc_sin
 'Memory pack o%(),pkd%(),length%,32   'fill it with values from the sine wave 32 bit
 'Memory pack o%(),pkd%(),length%,8     'fill it with values from the sine wave 8 bit
 calc_sin_pkd
 'restart machine
 PIO init machine 1,0,f,p,e,s,0
 PIO dma tx 1,0,&hffffffff,pkd%(),help,,length% '32 bit transfers
 'PIO dma tx 1,0,&hffffffff,pkd%(),help,,length%/4 '8 bit transfers
Loop
End
Sub help
 'Print "stopped after ";Timer;" ms"
 PIO stop 1,0
End Sub
Sub calc_modsin
For i=0 To length%-1
 alpha=i*2*Pi/length%
 o%(i)=Int(level*(1.1+(Sin(y%*alpha))*Sin(alpha)*Sin(alpha)))
Next
End Sub
Sub calc_sin
 o%(i)=Int(level*(1.1+Sin(y%*i*2*Pi/length%)))
Next
End Sub
Sub calc_sin_pkd
'calculate sinewave table directly in pkd%()
 pkd%(i)=0
 For j=0 To 3
   pkd%(i)=pkd%(i)+(Int(level*(1.1+Sin(y%*(i*4+j)*2*Pi/length%))))<<(j*8)
 Next j
Next i
End Sub
End
Edited 2026-03-17 21:10 by Volhout
Posted: 11:09am 17 Mar 2026
I was just seeing if the concept is any good, rather than using realistic numbers.
The pause can be reduced or perhaps eliminated depending on the time Play Tone takes to change frequency.
The frequency steps could also be increased to further increase the modulation frequency.
> timer=0:for n=900 to 1100 step 3:play tone n,n: pause 1:next :for n=1100 to 900 step -3:play tone n,n: pause 1:next:? timer
136.828
8 Hz=125mS so not far off, provided it actually sounds ok.
Edited 2026-03-17 21:18 by phil99
Posted: 11:19am 17 Mar 2026
Frank,
But if you can work with a square wave, you could also direct write to the PWM divider register when the PWM is put in "symmetrical mode" using MMbasic commands.
Phils solution is even simpler....
Edited 2026-03-17 21:20 by Volhout
Frank N. Furter
Posted: 12:06pm 17 Mar 2026
Thank you very much for your suggestions! It is supposed to be a sine wave that lies within a triangular envelope.
It should sound something like this in the end: https://hearingtest.online/
This code, which is based on the code from phil99, sounds quite similar:
Play volume 100,100
For z=1 To 4
 For n=980 To 1020
  Play tone n,n
  Pause 2
 Next
 For n=1020 To 980 Step -1
  Play tone n,n
  Pause 2
 Next
Next z
Play volume 0,0
'Play stop
Pause 200
Loop
That should be 4% at 1 kHz. The problem is the 'pop' when the sound is turned off. I suppose I’ll have to take a look at that with an oscilloscope...
Frank
Posted: 12:15pm 17 Mar 2026
Hi Frank,
What version firmware are you using. I know Peter adapted the play tone command to exit with a soft silence (no plop) between 5.09.00 and 6.01.00. But maybe that is changed now the sample calculation is taken out of the HW interrupt (the problem in 60201 rc4,5,6).
Or maybe it is caused by VOLUME cutting off hard.
Edited 2026-03-17 22:17 by Volhout
Frank N. Furter
Posted: 12:34pm 17 Mar 2026
Hi Volhout,
I am currently using version V6.02.01RC2.
It seems to work better with Play tone 0,0 instead of Play volume 0,0.
I can't tell the difference between Play stop and Play volume 0,0. I hear the 'pop' in both versions.
Frank
Posted: 12:40pm 17 Mar 2026
Frank,
Don't try rc4 or newer. I posted Peter with the result.
PLAY STOP is not as good as VOLUME 0,0. Actually volume 0,0 is perfect. PLAY STOP has minimal artefacts. But both do not show large DC jumps (actually tested on 602.00rc8).
Just confirmed: 60201rc2 works identical to 60200rc8.
Edited 2026-03-17 22:54 by Volhout
