Local Time 02:04 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I asked Claude to write a win95 for rp2350b
gadgetjack
Posted: 03:51am 17 Mar 2026
pico95.zip
 It might work if someone knows how to compile it. I can build em , but c code is a bit over my head.
gadgetjack
Posted: 09:55pm 17 Mar 2026
I tried to compile on a linux laptop but get errors that are over my head. Maybe Peter will look at it and work some magic.
Posted: 10:04pm 17 Mar 2026
Is Claude not able to tell you how to compile it, or what the errors mean?
Posted: 10:56pm 17 Mar 2026
  Quote  Is Claude not able to tell you how to compile it,
As compilation is a software process that Claude should know about, see if Claude can create the compiled binary as a .uf2 file.
Edited 2026-03-18 08:58 by phil99
gadgetjack
Posted: 11:06pm 17 Mar 2026
Yeah , I thought of that too. It will NOT compile code for me , says it has no access to the compiler software. It keeps giving me the same instructions on how to compile. Sadly it never changes , same instructions.
Posted: 11:26pm 17 Mar 2026
Well there is another AI project.
Using the Pico datasheet perhaps Claude can write a compiler just for the Pico.
Should be simpler than an "all-singing-all-dancing" compiler.
Posted: 12:12am 18 Mar 2026
  gadgetjack said  Sadly it never changes , same instructions.
If you give it the/an error message and ask it what it means and how to fix it, does it not address that specific issue?
gadgetjack
Posted: 10:35pm 18 Mar 2026
I would be on all night , that many errors. Not real impressed with AI code so far. Maybe only works if you pay for it?
