Local Time 02:04 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GIT and MMEdit under Linux Mint
panky
Posted: 02:49am 13 Mar 2026
Has anyone set up it on a Linux Mint system and set MMEdit as the editor? If so, pointers?
Thanks, panky
LeoNicolas
Posted: 05:33am 13 Mar 2026
I can try it tomorrow and give you a feedback.
I've been using VSCode, that is a pretty good editor and it is multiple platform
Regarding git, just use sudo apt install git on the terminal to install it.
Talking about the terminal, take a look at Oh My Zsh
I like to use git on the terminal, but there are plenty of visual tools if you are not familiar with the git commands. VSCode has a visual interface to deal with git as well
Posted: 05:41am 13 Mar 2026
Yes, I have LMDE6 and am running MMEDIT without any issues.
Download the Linux package, unzip it somewhere.
Enter the folder, right-click on the "MMEdit" file, click PERMISSIONS tab, make sure there is a tick in the "Allow executing file as a program" check-box, click CLOSE to exit, then just double-click to run.
To put an icon on the desktop, right-click the destop, select "Create a new launcher here...", then click BROWSE, find the MMEdit file, click it, then click on OK when done.
Double-click the icon to run MMEdit.
To change the icon, right-click the new icon, select PROPERTIES, click the little icon image on the left, browse to the MMEDIT folder, select the "mme.ico" then click CLOSE, and the desktop icon will be the "Official" MMEdit one.
Posted: 06:33am 13 Mar 2026
  Quote  To put an icon on the desktop, right-click the destop, select "Create a new launcher here...",
Or
  Quote  To create desktop shortcuts,
From a command prompt run ./dtopscuts.sh
stanleyella
Posted: 03:07pm 13 Mar 2026
I installed mmedit on linux mint cinnamon. I created a folder in Home called MMEDIT and copied the zip file there and extracted it there. You get a folder called mmedit5, in it is mmedit and mmcc. run getrequired.sh. as said run dtopscuts.sh to put mmedit and mmcc shortcut icons on screen. I installed rpi version from folder ok.To get the usb to flash your mmedit code , in terminal type sudo adduser $USER dialout for usb serial,  where $USER is your username.
stan
stanleyella
Posted: 03:33pm 13 Mar 2026
bought an old laptop and installed mint on it and mmedit.
https://www.ebay.co.uk/itm/257263603179?mkevt=1&mkpid=0&emsid=e11412.m144671.l197928&mkcid
stan
stanleyella
Posted: 07:48pm 13 Mar 2026
If it's of interest I got it working on rpi trixie
and just now on rpi Ubuntu 24.04.4.LTS
Well done Jim.
Posted: 08:14pm 13 Mar 2026
Panky,
I have never used GIT with anything so no idea what would be needed to use it with MMEdit.
If there are small additions needed, I will certainly look at the idea.
stanleyella
Posted: 08:48pm 13 Mar 2026
it's what you call the computer when it falls over :)
ubunto on rpi 400 is not as fast as rpi trixie. got each on usb3 ssd.imho
