Local Time 03:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Breakout game using TILEMAP
Posted: 03:26pm 11 Mar 2026
For RP2350 VGA or HDMI.
You need to use a local keyboard and set the keyboard repeat as low as possible.
This game was  written by CLAUDE 4.6 and took 10 minutes to write with 5 iterations to remove syntax and logical errors.
The obvious update would be to support a gamepad or wii controller - should also be easy enough to port to the Game*Mite and use the buttons.
Not thoroughly tested as I'm crap at games.
' BREAKOUT - A Tilemap-Based Brick Breaker
' Uses TILEMAP for the brick field and
' TILEMAP sprites for the ball and paddle.
' Procedurally generates tileset BMP.
' Controls: Left/Right arrows to move paddle
'           Space to launch ball
'           Q to quit
' Requires: MODE 2 (320x240 RGB121), SD card
OPTION EXPLICIT
OPTION BASE 0
MODE 2
' ---- Display constants ----
CONST SCR_W = 320
CONST SCR_H = 240
' ---- Tile dimensions ----
CONST TW = 16           ' tile width
CONST TH = 8            ' tile height (bricks are wide and short)
CONST TPR = 8           ' tiles per row in tileset image
' ---- Map dimensions ----
CONST COLS = 20          ' 20 cols x 16 = 320 pixels = screen width
CONST ROWS = 30          ' 30 rows x 8 = 240 pixels = screen height
' ---- Tile indices ----
CONST T_EMPTY  = 0
CONST T_RED    = 1       ' 7 points
CONST T_YELLOW = 2       ' 5 points
CONST T_GREEN  = 3       ' 3 points
CONST T_BLUE   = 4       ' 1 point
CONST T_WALL   = 5       ' indestructible border
CONST T_BALL   = 6       ' ball sprite tile
CONST T_PADDLE = 7       ' paddle segment tile
CONST T_PADL   = 8       ' paddle left end
' ---- Attribute bits ----
CONST A_BRICK = &b0001   ' breakable brick
CONST A_WALL  = &b0010   ' solid wall (unbreakable)
CONST A_SOLID = &b0011   ' anything solid
' ---- RGB121 colours ----
CONST C_BLACK  = RGB(0,0,0)
CONST C_RED    = RGB(255,0,0)
CONST C_YELLOW = RGB(255,255,0)
CONST C_GREEN  = RGB(0,255,0)
CONST C_BLUE   = RGB(0,0,255)
CONST C_WHITE  = RGB(255,255,255)
CONST C_GREY   = RGB(128,128,128)
CONST C_COBALT = RGB(0,0,255)
CONST C_CYAN   = RGB(0,255,255)
CONST C_BROWN  = RGB(255,255,0)
' ---- Game state ----
DIM score, lives, level, bricks_left
DIM ball_x!, ball_y!     ' ball position (sub-pixel float)
DIM ball_dx!, ball_dy!   ' ball velocity
DIM pad_x                ' paddle left edge (pixel)
DIM pad_w                ' paddle width in pixels
DIM launched             ' has ball been launched?
DIM k$
DIM r, c, ps
DIM new_x!, new_y!
DIM bx, by, hit_t, tcol, trow, hit_a
DIM prev_bx, prev_by, ptcol, ptrow
DIM wprev_bx, wprev_by
DIM edge_t
DIM hit_pos!, pad_centre!
' ---- Speed/difficulty ----
CONST BALL_SPEED! = 0.4
CONST PAD_SPEED = 10
CONST PAD_W_TILES = 5    ' paddle width in tiles
CONST PAD_ROW = 28       ' row where paddle sits
CONST BRICK_START_ROW = 4 ' first row of bricks
CONST BRICK_ROWS = 8     ' rows of bricks
' Setup
PRINT "Generating tileset..."
GenerateTileset
FLASH LOAD IMAGE 1, "breakout_tiles.bmp", O
FRAMEBUFFER CREATE
' Title Screen
TitleScreen:
FRAMEBUFFER WRITE F
CLS C_BLACK
TEXT SCR_W\2, 60, "BREAKOUT", "CM", 7, 2, C_RED
TEXT SCR_W\2, 110, "Arrow keys to move", "CM", 1, 1, C_WHITE
TEXT SCR_W\2, 130, "SPACE to launch ball", "CM", 1, 1, C_WHITE
TEXT SCR_W\2, 150, "Q to quit", "CM", 1, 1, C_GREY
TEXT SCR_W\2, 190, "Press SPACE to start", "CM", 1, 1, C_YELLOW
FRAMEBUFFER COPY F, N
DO : k$ = INKEY$ : LOOP UNTIL k$ = " " OR UCASE$(k$) = "Q"
IF UCASE$(k$) = "Q" THEN GOTO Cleanup
' New Game
score = 0
lives = 3
level = 1
NewLevel:
' Build the map
TILEMAP CLOSE
TILEMAP CREATE mapdata, 1, 1, TW, TH, TPR, COLS, ROWS
TILEMAP ATTR tileattrs, 1, 8
' Count bricks
bricks_left = 0
FOR r = BRICK_START_ROW TO BRICK_START_ROW + BRICK_ROWS - 1
 FOR c = 1 TO COLS - 2
   IF TILEMAP(TILE 1, c * TW + 1, r * TH + 1) > 0 THEN
     IF (TILEMAP(ATTR 1, TILEMAP(TILE 1, c * TW + 1, r * TH + 1)) AND A_BRICK) THEN
       bricks_left = bricks_left + 1
     END IF
   END IF
 NEXT c
NEXT r
' Create sprites: ball and paddle segments
TILEMAP SPRITE CREATE 1, 1, T_BALL, SCR_W\2, (PAD_ROW - 1) * TH
' Paddle sprites (5 segments)
pad_x = (SCR_W - PAD_W_TILES * TW) \ 2
FOR ps = 1 TO PAD_W_TILES
 TILEMAP SPRITE CREATE ps + 1, 1, T_PADDLE, pad_x + (ps - 1) * TW, PAD_ROW * TH
NEXT ps
' Reset ball
ResetBall:
launched = 0
ball_dx! = BALL_SPEED!
ball_dy! = -BALL_SPEED!
ball_x! = pad_x + (PAD_W_TILES * TW) \ 2 - TW \ 2
ball_y! = (PAD_ROW - 1) * TH
' Main Game Loop
GameLoop:
DO
 FRAMEBUFFER WRITE F
 CLS C_BLACK
 ' ---- Input ----
 k$ = INKEY$
 IF k$ = CHR$(130) THEN         ' Left arrow
   pad_x = pad_x - PAD_SPEED
   IF pad_x < TW THEN pad_x = TW
 END IF
 IF k$ = CHR$(131) THEN         ' Right arrow
   pad_x = pad_x + PAD_SPEED
   IF pad_x > SCR_W - PAD_W_TILES * TW - TW THEN pad_x = SCR_W - PAD_W_TILES * TW - TW
 END IF
 IF k$ = " " AND launched = 0 THEN launched = 1
 ' ---- Update paddle sprites ----
   TILEMAP SPRITE MOVE ps + 1, pad_x + (ps - 1) * TW, PAD_ROW * TH
 NEXT ps
 ' ---- Ball logic ----
 IF launched = 0 THEN
   ' Ball sits on paddle
 ELSE
   ' Move ball
   new_x! = ball_x! + ball_dx!
   new_y! = ball_y! + ball_dy!
   ' ---- Wall collisions ----
   ' Left wall
   IF new_x! < TW THEN
     new_x! = TW
     ball_dx! = -ball_dx!
   END IF
   ' Right wall
   IF new_x! > SCR_W - 2 * TW THEN
     new_x! = SCR_W - 2 * TW
   END IF
   ' Top wall
   IF new_y! < TH THEN
     new_y! = TH
     ball_dy! = -ball_dy!
   END IF
   ' ---- Brick collision ----
   ' Check ball centre against tilemap
   bx = INT(new_x!) + TW \ 2
   by = INT(new_y!) + TH \ 2
   hit_t = TILEMAP(TILE 1, bx, by)
   IF hit_t > 0 THEN
     hit_a = TILEMAP(ATTR 1, hit_t)
     IF (hit_a AND A_BRICK) THEN
       ' Score based on brick colour
       SELECT CASE hit_t
         CASE T_RED    : score = score + 7
         CASE T_YELLOW : score = score + 5
         CASE T_GREEN  : score = score + 3
         CASE T_BLUE   : score = score + 1
       END SELECT
       ' Remove brick
       tcol = bx \ TW
       trow = by \ TH
       TILEMAP SET 1, tcol, trow, T_EMPTY
       bricks_left = bricks_left - 1
       ' Bounce: determine which face was hit
       prev_bx = INT(ball_x!) + TW \ 2
       prev_by = INT(ball_y!) + TH \ 2
       ptcol = prev_bx \ TW
       ptrow = prev_by \ TH
       IF ptcol <> tcol THEN ball_dx! = -ball_dx!
       IF ptrow <> trow THEN ball_dy! = -ball_dy!
       IF ptcol = tcol AND ptrow = trow THEN
       END IF
     ELSEIF (hit_a AND A_WALL) THEN
       ' Bounce off wall
       wprev_bx = INT(ball_x!) + TW \ 2
       wprev_by = INT(ball_y!) + TH \ 2
       IF (wprev_bx \ TW) <> (bx \ TW) THEN ball_dx! = -ball_dx!
       IF (wprev_by \ TH) <> (by \ TH) THEN ball_dy! = -ball_dy!
       IF (wprev_bx \ TW) = (bx \ TW) AND (wprev_by \ TH) = (by \ TH) THEN
       END IF
     END IF
   END IF
   ' Also check ball edges for bricks (corners)
   ' Top edge
   edge_t = TILEMAP(TILE 1, bx, INT(new_y!))
   IF edge_t > 0 THEN
     IF (TILEMAP(ATTR 1, edge_t) AND A_BRICK) THEN
       tcol = bx \ TW
       trow = INT(new_y!) \ TH
       SELECT CASE edge_t
       END SELECT
     END IF
   END IF
   ' ---- Paddle collision ----
   IF ball_dy! > 0 THEN  ' only when moving down
     IF INT(new_y!) + TH >= PAD_ROW * TH AND INT(new_y!) + TH <= PAD_ROW * TH + TH THEN
       IF INT(new_x!) + TW > pad_x AND INT(new_x!) < pad_x + PAD_W_TILES * TW THEN
         new_y! = PAD_ROW * TH - TH
         ball_dy! = -ABS(ball_dy!)
         ' Angle based on where ball hits paddle
         hit_pos! = (new_x! + TW \ 2 - pad_x) / (PAD_W_TILES * TW)
         ' hit_pos ranges 0..1, map to angle
         ball_dx! = (hit_pos! - 0.5) * BALL_SPEED! * 2
         ' Clamp horizontal speed
         IF ABS(ball_dx!) > BALL_SPEED! * 0.9 THEN
           ball_dx! = SGN(ball_dx!) * BALL_SPEED! * 0.9
         END IF
         ' Ensure minimum horizontal movement
         IF ABS(ball_dx!) < 0.3 THEN
           ball_dx! = SGN(ball_dx!) * 0.3
           IF ball_dx! = 0 THEN ball_dx! = 0.3
         END IF
         ' Maintain total speed
         ball_dy! = -SQR(BALL_SPEED! * BALL_SPEED! - ball_dx! * ball_dx!)
       END IF
     END IF
   END IF
   ' ---- Ball lost (bottom) ----
   IF new_y! > SCR_H THEN
     lives = lives - 1
     IF lives <= 0 THEN GOTO GameOver
     GOTO ResetBall
   END IF
   ball_x! = new_x!
   ball_y! = new_y!
 END IF
 ' ---- Update ball sprite ----
 TILEMAP SPRITE MOVE 1, INT(ball_x!), INT(ball_y!)
 ' ---- Draw ----
 TILEMAP DRAW 1, F, 0, 0, 0, 0, SCR_W, SCR_H
 TILEMAP SPRITE DRAW F, 0
 ' HUD: score and lives
 TEXT 4, 1, "SCORE:" + STR$(score), "LT", 1, 1, C_WHITE
 TEXT SCR_W - 4, 1, "LIVES:" + STR$(lives), "RT", 1, 1, C_WHITE
 TEXT SCR_W \ 2, 1, "LVL:" + STR$(level), "CT", 1, 1, C_YELLOW
 ' ---- Level complete? ----
 IF bricks_left <= 0 THEN
   level = level + 1
   TILEMAP SPRITE CLOSE
   GOTO NewLevel
 END IF
LOOP
' Game Over
GameOver:
FRAMEBUFFER WRITE F
CLS C_BLACK
TEXT SCR_W\2, 80, "GAME OVER", "CM", 7, 2, C_RED
TEXT SCR_W\2, 130, "Score: " + STR$(score), "CM", 1, 2, C_WHITE
TEXT SCR_W\2, 160, "Level: " + STR$(level), "CM", 1, 1, C_YELLOW
TEXT SCR_W\2, 200, "SPACE=Play Again  Q=Quit", "CM", 1, 1, C_GREY
IF k$ = " " THEN GOTO TitleScreen
' Cleanup
Cleanup:
TILEMAP CLOSE
FRAMEBUFFER CLOSE
CLS
PRINT "Thanks for playing!"
PRINT "Final score: "; score
END
' SUBROUTINES
SUB GenerateTileset
 ' Create tileset: 8 tiles per row, 2 rows = 128x16 px
 ' Tile size: 16 x 8 pixels
 LOCAL tx, ty
 CLS C_BLACK
 ' Tile 1: Red brick
 tx = 0 : ty = 0
 BOX tx, ty, TW, TH, 0, C_RED, C_RED
 BOX tx+1, ty+1, TW-2, TH-2, 1, C_WHITE
 ' Tile 2: Yellow brick
 tx = TW : ty = 0
 BOX tx, ty, TW, TH, 0, C_YELLOW, C_YELLOW
 ' Tile 3: Green brick
 tx = TW * 2 : ty = 0
 BOX tx, ty, TW, TH, 0, C_GREEN, C_GREEN
 ' Tile 4: Blue brick
 tx = TW * 3 : ty = 0
 BOX tx, ty, TW, TH, 0, C_BLUE, C_BLUE
 ' Tile 5: Wall (grey border)
 tx = TW * 4 : ty = 0
 BOX tx, ty, TW, TH, 0, C_GREY, C_GREY
 ' Tile 6: Ball (white square on black)
 tx = TW * 5 : ty = 0
 BOX tx, ty, TW, TH, 0, C_BLACK, C_BLACK
 BOX tx+TW\2-3, ty+TH\2-3, 6, 6, 0, C_WHITE, C_WHITE
 ' Tile 7: Paddle segment (cyan)
 tx = TW * 6 : ty = 0
 BOX tx, ty, TW, TH, 0, C_CYAN, C_CYAN
 ' Tile 8: Paddle left (same as paddle for now)
 tx = TW * 7 : ty = 0
 SAVE IMAGE "breakout_tiles.bmp", 0, 0, TPR * TW, TH
END SUB
' MAP DATA: 20 cols x 30 rows = 600 values
mapdata:
' Row 0: top wall
DATA 5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5
' Row 1: side walls, HUD space
DATA 5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,5
' Row 2: empty
' Row 3: empty
' Row 4: red bricks
DATA 5,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,5
' Row 5: red bricks
' Row 6: yellow bricks
DATA 5,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,5
' Row 7: yellow bricks
' Row 8: green bricks
DATA 5,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,5
' Row 9: green bricks
' Row 10: blue bricks
DATA 5,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,5
' Row 11: blue bricks
' Row 12: empty
' Row 13: empty
' Row 14: empty
' Row 15: empty
' Row 16: empty
' Row 17: empty
' Row 18: empty
' Row 19: empty
' Row 20: empty
' Row 21: empty
' Row 22: empty
' Row 23: empty
' Row 24: empty
' Row 25: empty
' Row 26: empty
' Row 27: empty
' Row 28: empty (paddle row - paddle is a sprite)
' Row 29: open bottom (ball death zone)
' TILE ATTRIBUTES (8 tile types)
tileattrs:
DATA 1      ' tile 1: red brick    - A_BRICK
DATA 1      ' tile 2: yellow brick - A_BRICK
DATA 1      ' tile 3: green brick  - A_BRICK
DATA 1      ' tile 4: blue brick   - A_BRICK
DATA 2      ' tile 5: wall         - A_WALL
DATA 0      ' tile 6: ball         - none
DATA 0      ' tile 7: paddle       - none
DATA 0      ' tile 8: paddle left  - none
dddns
Posted: 07:07pm 11 Mar 2026
Beautiful and sad at the same time. Those who are not ready to use AI can leave.
Edit:
The ball moves smoothly and the angles you can achieve are just as good as on other platforms I've played before. In my opinion, the movement of the racket needs to be improved. The speed is good, I had the patience to finish level 1 with the original settings, but on my second attempt I set the ball speed to 1.2 and the racket to 30.
Tested on the latest RC3 and ILI9341 LCD.
Edit2: Naive question, is it possible to tell this Claude to look into this for example and port it?
Edited 2026-03-12 08:04 by dddns
Posted: 10:45am 12 Mar 2026
Here is a version tuned for the Game*Mite
'           Q to quit
Option EXPLICIT
Option BASE 0
SetPin gp8,din,pullup
SetPin gp9,din,pullup
SetPin gp10,din,pullup
SetPin gp11,din,pullup
SetPin gp12,din,pullup
SetPin gp13,din,pullup
SetPin gp14,din,pullup
SetPin gp15,din,pullup
Const SCR_W = 320
Const SCR_H = 240
Const TW = 16           ' tile width
Const TH = 8            ' tile height (bricks are wide and short)
Const TPR = 8           ' tiles per row in tileset image
Const COLS = 20          ' 20 cols x 16 = 320 pixels = screen width
Const ROWS = 30          ' 30 rows x 8 = 240 pixels = screen height
Const T_EMPTY  = 0
Const T_RED    = 1       ' 7 points
Const T_YELLOW = 2       ' 5 points
Const T_GREEN  = 3       ' 3 points
Const T_BLUE   = 4       ' 1 point
Const T_WALL   = 5       ' indestructible border
Const T_BALL   = 6       ' ball sprite tile
Const T_PADDLE = 7       ' paddle segment tile
Const T_PADL   = 8       ' paddle left end
Const A_BRICK = &b0001   ' breakable brick
Const A_WALL  = &b0010   ' solid wall (unbreakable)
Const A_SOLID = &b0011   ' anything solid
Const C_BLACK  = RGB(0,0,0)
Const C_RED    = RGB(255,0,0)
Const C_YELLOW = RGB(255,255,0)
Const C_GREEN  = RGB(0,255,0)
Const C_BLUE   = RGB(0,0,255)
Const C_WHITE  = RGB(255,255,255)
Const C_GREY   = RGB(128,128,128)
Const C_COBALT = RGB(0,0,255)
Const C_CYAN   = RGB(0,255,255)
Const C_BROWN  = RGB(255,255,0)
Dim score, lives, level, bricks_left
Dim ball_x!, ball_y!     ' ball position (sub-pixel float)
Dim ball_dx!, ball_dy!   ' ball velocity
Dim pad_x                ' paddle left edge (pixel)
Dim pad_w                ' paddle width in pixels
Dim launched             ' has ball been launched?
Dim k$
Dim r, c, ps
Dim new_x!, new_y!
Dim bx, by, hit_t, tcol, trow, hit_a
Dim prev_bx, prev_by, ptcol, ptrow
Dim wprev_bx, wprev_by
Dim edge_t
Dim hit_pos!, pad_centre!
Const BALL_SPEED! = 4.0
Const PAD_SPEED = 10
Const PAD_W_TILES = 5    ' paddle width in tiles
Const PAD_ROW = 28       ' row where paddle sits
Const BRICK_START_ROW = 4 ' first row of bricks
Const BRICK_ROWS = 8     ' rows of bricks
' Setup
Print "Generating tileset..."
GenerateTileset
Flash LOAD IMAGE 1, "breakout_tiles.bmp", O
FRAMEBUFFER CREATE
' Title Screen
TitleScreen:
FRAMEBUFFER WRITE F
CLS C_BLACK
Text SCR_W\2, 60, "BREAKOUT", "CM", 7, 2, C_RED
Text SCR_W\2, 110, "Left and Right Buttons to move", "CM", 1, 1, C_WHITE
Text SCR_W\2, 130, "A to launch ball", "CM", 1, 1, C_WHITE
Text SCR_W\2, 150, "B to quit", "CM", 1, 1, C_GREY
Text SCR_W\2, 190, "Press SELECT to start", "CM", 1, 1, C_YELLOW
Do : k$ = GetPress() : Loop Until k$ = " " Or UCase$(k$) = "Q"
If UCase$(k$) = "Q" Then GoTo Cleanup
' New Game
score = 0
lives = 3
level = 1
NewLevel:
' Build the map
Tilemap CLOSE
Tilemap CREATE mapdata, 1, 1, TW, TH, TPR, COLS, ROWS
Tilemap ATTR tileattrs, 1, 8
BALL_SPEED=BALL_SPEED*1.25
' Count bricks
bricks_left = 0
For r = BRICK_START_ROW To BRICK_START_ROW + BRICK_ROWS - 1
 For c = 1 To COLS - 2
   If Tilemap(TILE 1, c * TW + 1, r * TH + 1) > 0 Then
     If (Tilemap(ATTR 1, Tilemap(TILE 1, c * TW + 1, r * TH + 1)) And A_BRICK)
Then
     End If
   End If
 Next c
Next r
Tilemap SPRITE CREATE 1, 1, T_BALL, SCR_W\2, (PAD_ROW - 1) * TH
For ps = 1 To PAD_W_TILES
 Tilemap SPRITE CREATE ps + 1, 1, T_PADDLE, pad_x + (ps - 1) * TW, PAD_ROW * TH
Next ps
' Reset ball
ResetBall:
launched = 0
' Main Game Loop
GameLoop:
 FRAMEBUFFER WRITE F
 CLS C_BLACK
 ' ---- Input ----
 k$ = GetPress()
 If k$ = Chr$(130) Then         ' Left arrow
   If pad_x < TW Then pad_x = TW
 End If
 If k$ = Chr$(131) Then         ' Right arrow
   If pad_x > SCR_W - PAD_W_TILES * TW - TW Then pad_x = SCR_W - PAD_W_TILES *
TW - TW
 End If
 If k$ = "L" And launched = 0 Then launched = 1
   Tilemap SPRITE MOVE ps + 1, pad_x + (ps - 1) * TW, PAD_ROW * TH
 Next ps
 If launched = 0 Then
 Else
   ' Move ball
   ' Left wall
   If new_x! < TW Then
     new_x! = TW
   End If
   ' Right wall
   If new_x! > SCR_W - 2 * TW Then
   End If
   ' Top wall
   If new_y! < TH Then
     new_y! = TH
   End If
   bx = Int(new_x!) + TW \ 2
   by = Int(new_y!) + TH \ 2
   hit_t = Tilemap(TILE 1, bx, by)
   If hit_t > 0 Then
     hit_a = Tilemap(ATTR 1, hit_t)
     If (hit_a And A_BRICK) Then
       Select Case hit_t
         Case T_RED    : score = score + 7
         Case T_YELLOW : score = score + 5
         Case T_GREEN  : score = score + 3
         Case T_BLUE   : score = score + 1
       End Select
       ' Remove brick
       tcol = bx \ TW
       trow = by \ TH
       Tilemap SET 1, tcol, trow, T_EMPTY
       prev_bx = Int(ball_x!) + TW \ 2
       prev_by = Int(ball_y!) + TH \ 2
       If ptcol <> tcol Then ball_dx! = -ball_dx!
       If ptrow <> trow Then ball_dy! = -ball_dy!
       If ptcol = tcol And ptrow = trow Then
       End If
     ElseIf (hit_a And A_WALL) Then
       ' Bounce off wall
       wprev_bx = Int(ball_x!) + TW \ 2
       wprev_by = Int(ball_y!) + TH \ 2
       If (wprev_bx \ TW) <> (bx \ TW) Then ball_dx! = -ball_dx!
       If (wprev_by \ TH) <> (by \ TH) Then ball_dy! = -ball_dy!
       If (wprev_bx \ TW) = (bx \ TW) And (wprev_by \ TH) = (by \ TH) Then
       End If
     End If
   End If
   ' Top edge
   edge_t = Tilemap(TILE 1, bx, Int(new_y!))
   If edge_t > 0 Then
     If (Tilemap(ATTR 1, edge_t) And A_BRICK) Then
       tcol = bx \ TW
       trow = Int(new_y!) \ TH
       Select Case edge_t
       End Select
     End If
   End If
   If ball_dy! > 0 Then  ' only when moving down
     If Int(new_y!) + TH >= PAD_ROW * TH And Int(new_y!) + TH <= PAD_ROW * TH +
TH Then
       If Int(new_x!) + TW > pad_x And Int(new_x!) < pad_x + PAD_W_TILES * TW T
hen
         ball_dy! = -Abs(ball_dy!)
         If Abs(ball_dx!) > BALL_SPEED! * 0.9 Then
           ball_dx! = Sgn(ball_dx!) * BALL_SPEED! * 0.9
         End If
         If Abs(ball_dx!) < 0.3 Then
           ball_dx! = Sgn(ball_dx!) * 0.3
           If ball_dx! = 0 Then ball_dx! = 0.3
         End If
         ball_dy! = -Sqr(BALL_SPEED! * BALL_SPEED! - ball_dx! * ball_dx!)
       End If
     End If
   End If
   If new_y! > SCR_H Then
     lives = lives - 1
     If lives <= 0 Then GoTo GameOver
     GoTo ResetBall
   End If
   ball_x! = new_x!
   ball_y! = new_y!
 End If
 Tilemap SPRITE MOVE 1, Int(ball_x!), Int(ball_y!)
 ' ---- Draw ----
 Tilemap DRAW 1, F, 0, 0, 0, 0, SCR_W, SCR_H
 Tilemap SPRITE DRAW F, 0
 Text 4, 1, "SCORE:" + Str$(score), "LT", 1, 1, C_WHITE
 Text SCR_W - 4, 1, "LIVES:" + Str$(lives), "RT", 1, 1, C_WHITE
 Text SCR_W \ 2, 1, "LVL:" + Str$(level), "CT", 1, 1, C_YELLOW
 If bricks_left <= 0 Then
   level = level + 1
   Tilemap SPRITE CLOSE
   GoTo NewLevel
 End If
Loop
' Game Over
GameOver:
FRAMEBUFFER WRITE F
CLS C_BLACK
Text SCR_W\2, 80, "GAME OVER", "CM", 7, 2, C_RED
Text SCR_W\2, 130, "Score: " + Str$(score), "CM", 1, 2, C_WHITE
Text SCR_W\2, 160, "Level: " + Str$(level), "CM", 1, 1, C_YELLOW
Text SCR_W\2, 200, "SPACE=Play Again  Q=Quit", "CM", 1, 1, C_GREY
If k$ = " " Then GoTo TitleScreen
' Cleanup
Cleanup:
Tilemap CLOSE
FRAMEBUFFER CLOSE
CLS
Print "Thanks for playing!"
Print "Final score: "; score
End
' SUBROUTINES
Sub GenerateTileset
 Local tx, ty
 CLS C_BLACK
 ' Tile 1: Red brick
 tx = 0 : ty = 0
 Box tx, ty, TW, TH, 0, C_RED, C_RED
 Box tx+1, ty+1, TW-2, TH-2, 1, C_WHITE
 tx = TW : ty = 0
 Box tx, ty, TW, TH, 0, C_YELLOW, C_YELLOW
 Box tx, ty, TW, TH, 0, C_GREEN, C_GREEN
 Box tx, ty, TW, TH, 0, C_BLUE, C_BLUE
 Box tx, ty, TW, TH, 0, C_GREY, C_GREY
 Box tx, ty, TW, TH, 0, C_BLACK, C_BLACK
 Box tx+TW\2-3, ty+TH\2-3, 6, 6, 0, C_WHITE, C_WHITE
 Box tx, ty, TW, TH, 0, C_CYAN, C_CYAN
 Save IMAGE "breakout_tiles.bmp", 0, 0, TPR * TW, TH
End Sub
mapdata:
' Row 0: top wall
Data 5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5
Data 5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,5
' Row 2: empty
' Row 3: empty
' Row 4: red bricks
Data 5,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,5
' Row 5: red bricks
Data 5,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,5
Data 5,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,5
Data 5,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,5
' Row 12: empty
' Row 13: empty
' Row 14: empty
' Row 15: empty
' Row 16: empty
' Row 17: empty
' Row 18: empty
' Row 19: empty
' Row 20: empty
' Row 21: empty
' Row 22: empty
' Row 23: empty
' Row 24: empty
' Row 25: empty
' Row 26: empty
' Row 27: empty
tileattrs:
Data 1      ' tile 1: red brick    - A_BRICK
Data 1      ' tile 2: yellow brick - A_BRICK
Data 1      ' tile 3: green brick  - A_BRICK
Data 1      ' tile 4: blue brick   - A_BRICK
Data 2      ' tile 5: wall         - A_WALL
Data 0      ' tile 6: ball         - none
Data 0      ' tile 7: paddle       - none
Data 0      ' tile 8: paddle left  - none
Function GetPress() As string
 Local x% = Port(GP8,8)
 Local y%=x% Xor &HFF
   Select Case y%
     Case 2
       GetPress=Chr$(130)
     Case 8
       GetPress=Chr$(131)
     Case 64
       GetPress="Q"
     Case 128
       GetPress="L"
     Case 16
       GetPress=" "
     Case Else
     GetPress=""
   End Select
End Function
Posted: 12:02pm 12 Mar 2026
Peter,
Error in line 126, cannot change a constant.
Posted: 12:09pm 12 Mar 2026
Change line 84 to dim float, sorry pasted the wrong version
I got 1286. Level 3 get quite fast
Edited 2026-03-12 22:26 by matherp
Posted: 01:06pm 12 Mar 2026
Peter,
I had to reconstruct some lines, since in above listing they where cut off.
But after that it runs fine.
I may have to look at integration into the GM menu (i.e. at exit RUN "menu.bas" and not END) and such (select is QUIT, START to start a game).
But it is a nice game. Runs smooth.
Finetuning:
- press SPACE to restart....(space??)
- color Grey does not exist in framebuffer land. Shows as pink.
- next version publish as ZIP (no cut off lines).
Edited 2026-03-12 23:13 by Volhout
Posted: 07:52pm 12 Mar 2026
Hi Peter,
This is the version you can integrate in Game*Mite 2350 system.
Breakout_GM.zip
P.S. and now the version that can be played on a RP2040 Game*Mite/Pico Gamer... Especially Geoff's pico gamer has a lot of units sold. But they are all RP2040...Legacy kills...
Edited 2026-03-13 05:55 by Volhout
Posted: 07:59pm 12 Mar 2026
I could add the TILEMAP command to the RP2040 - no issue, but you would lose 16Kbytes from the A: drive
Posted: 08:15pm 12 Mar 2026
Hi Peter,
Can I negotiate...Take structures out, put Tilemap in. But this is no cafetaria model I assume...
Sorry, the A: drive is to important for Game*Mite. PicoGamer has 4M/16M flash, so does not bother.
I will think about how it can be done with the feature set of the 2040. Petscii had to prepare an index file, and a binary for flash slot 3. Something along those lines can still be done. But then "the hard way = manually". But maybe that is not even needed. Maybe Sprites can be used for the blocks, and the wall...BOX'es with coordinate collision detect.
Posted: 08:42pm 12 Mar 2026
  matherp said  This game was  written by CLAUDE 4.6 and took 10 minutes to write with 5 iterations to remove syntax and logical errors.
Are you primarily using Claude online, or are you now using it on the local hardware you said several months ago that you were purchasing?
panky
Posted: 10:40pm 12 Mar 2026
Hi Peter,
Would it be possible for you to put down a few notes on how you use Claude and the sequence of steps you went through for the game above?
Cheers, Doug
Posted: 08:05am 13 Mar 2026
Peter,
I think RP2040 Breakout game is pretty simple when using SPRITE(B,#n,side) on the ball, and paint all blocks in the background (on F/N).
Now I understand how this works I'll give it a try.
Thanks for implementing the background collision detection.!!
Posted: 08:22am 13 Mar 2026
I may have found a way to include TILEMAP in the RP2040 without reducing the A: drive. Watch this space...
Posted: 08:44am 13 Mar 2026
Harm
Please try this binary with your rp2040 gamemite and breakout. You should have 16Kb more A: drive AND TILEMAP
PicoMite.zip
Posted: 10:29am 13 Mar 2026
Peter,
At work now, I can test this weekend when access to 2040-GM. Very curious how it works. What have you removed ?
Edited 2026-03-13 20:29 by Volhout
Posted: 10:44am 13 Mar 2026
Nothing
Posted: 01:08pm 13 Mar 2026
Peter,
Some dupont wires and a breadboard later...
This works on GM 2040. And indeed there is more A: drive. I have tested breakout, petscii, circle, flappy, SD card, audio (PWM). I have only tested some GM applications.
But it is in essence the microcontroller version. Other features may require additional testing (ADC's, sensors, PWM, UART, PIO, etc.). Any affected ?
Thank you,
P.S. 16k more A: drive will fit one game (15k) called Breakout.
Edited 2026-03-13 23:09 by Volhout
Posted: 02:15pm 13 Mar 2026
Harm
The change is a follows:
I'd been frustated that there was extra RAM on the Pico that I couldn't allocate to heap because increasing the heap size increases the program size which given 4 copies (program + 3 flash slots) decreases the A: drive.
In this version I've specified the program size separately from the heap size so heap size has gone up from 128K to 136K, but the maximum program size has reduced from 128K to 120K. Given the VGA versions have only ever had 104K that shouldn't be an issue.
So the firmware has increased by 16K to add the TILEMAP (actually much les than this but it has to be on 16K boundaries) but the program storage has reduced by 4 * 8k. Net change to the A: drive +16K plus 8K extra heap for arrays, framebuffers etc.
Posted: 02:49pm 13 Mar 2026
Understand.
I did not check, but I assumed you did simply decouple the size of the library/flash slots from the size of the program memory. Since library and flash slots on the VGA version are only 100k, and library/flash slot do not contain editable form of the program they can be smaller.
Edited 2026-03-14 00:50 by Volhout
Posted: 03:28pm 13 Mar 2026
  matherp said  I'd been frustated that there was extra RAM on the Pico that I couldn't allocate to heap  . . .
Does this change mean there's also more heap on the RP2350?
