DigitalDreams Regular Member Joined: 03/05/2025 Location: United KingdomPosts: 65
Posted: 05:41pm 07 Mar 2026
Having trouble with this command.
If x$="57+93+117"
Val(x$) returns 57 !?
Am I asking too much of val(x$) ?
Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1578
Posted: 05:50pm 07 Mar 2026
yes So it converts the numerical value within a string into a number. But it does not calculate any formulas that are within the string.'no comment
bfwolf Senior Member Joined: 03/01/2025 Location: GermanyPosts: 270
Posted: 05:58pm 07 Mar 2026
Yes, you're asking too much of `VAL(s$)`. This function (as it exists in the BASIC dialect) simply tries to find a number within a string and returns the value after the first match. It doesn't evaluate any expressions!
Try `EVAL(s$)`, which is fortunately available in MMBasic!
Will evaluate 'string$' as if it is a BASIC expression and return the result. 'string$' can be a constant, a variable or a string expression. The expression can use any operators, functions, variables, subroutines, etc that are known at the time of execution. The returned value will be an integer, float or string depending on the result of the evaluation. For example: S$ = "COS(RAD(30)) * 100" : PRINT EVAL(S$) Will display: 86.6025
Posted: 06:25pm 07 Mar 2026
Thanks !, that's the ticket. I'm about to print a truncated version of the latest user manual so none to hand...
