Forum Index : Microcontroller and PC projects : picomite hdmi need test program for the collors
| tenij000 Senior Member Joined: 30/05/2025 Location: NetherlandsPosts: 107 |
picomite hdmi need test program for the collors sofar i got text on the monitor like test the colors |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1579 |
somithing like This? 'no comment |
that worked :) now second thing the sdcard and the sound manual says somthing like this GP26, GP27, and GP28) but i now option sdcard then cs sck mosi miso four thingys |
Has your PicoMite board not got the OPTION settings written on the bottom of the PCB? The ones in the manual are often typical and don't relate to some boards. The SDcard can only have 1 or 4 arguments. Never 3. . Edited 2026-02-28 04:16 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
