Local Time 03:49 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Why this error (PicoMite)?
Posted: 06:03pm 14 Feb 2026
> run
[47] Line SX(-24), SY(34), SX(24), SY(34), 1, cTrack
Error : Dimensions
Error doesn't occur when SX parameter is not negative.
> Line SX(0), SY(34), SX(24), SY(34), 1, cTrack
(Above command correctly draws line)
> list
Option Explicit
Option Default Float
Dim Float Scale
Dim Integer OffX, OffY
' --- Color Palette ---
Dim Integer cTrack  = RGB(255, 255, 255)
' --- Setup & Draw ---
InitScale
CLS RGB(0, 0, 0)
DrawMainline
' Keep program running to hold display
Loop
' RENDERING ENGINE
Sub InitScale
Local Float scaleX = MM.HRES / 100.0
Local Float scaleY = MM.VRES / 90.0
If scaleX < scaleY Then Scale = scaleX Else Scale = scaleY
OffX = (MM.HRES - (96 * Scale)) / 2
OffY = (MM.VRES - (72 * Scale)) / 2
End Sub
Function SX(x As Float) As Integer
SX = OffX + (x + 48) * Scale
End Function
Function SY(y As Float) As Integer
SY = OffY + (36 - y) * Scale
End Function
' GEOMETRY DRAWING
Sub DrawMainline
Line SX(-24), SY(-34), SX(24), SY(-34), 1, cTrack
Line SX(-46), SY(12), SX(-46), SY(-12), 1, cTrack
Line SX(46), SY(12),  SX(46), SY(-12), 1, cTrack
End Sub
Edited 2026-02-15 04:05 by lizby
Posted: 07:00pm 14 Feb 2026
It first assumes sx is an array and fails on the negative array index. I'll fix in the next beta
