Forum Index : Microcontroller and PC projects : Micromite Question
OA47
Posted: 05:10am 02 Feb 2026
Is there a procedure to start a LED flashing (Pulse a PIN) when the program is at an INPUT prompt and restore the LED when the INPUT prompt is satisfied?
OA47
Posted: 05:57am 02 Feb 2026
Hi oa,
Write a small SUB. that toggles the  LED pin.
Just before the input statement set a time interrupt with SETTICK pointing to that SUB.
After the input, use SETTICK,0,0 to stop the blinking.
Then a PIN() = x to restore the old led state.
Edited 2026-02-02 15:59 by Volhout
OA47
Posted: 12:50am 03 Feb 2026
Volhout, unfortunately this is a very old Maximite project and according to the manual
  Quote  Interrupts can occur at any time but they are disabled during the execution of INPUT statements.
I will have to work another way.
OA47
Posted: 01:55am 03 Feb 2026
The best way around this issue is to use non blocking INPUT$() and some logic to get the input data, then you could do as Volhout suggested.  I did have a function to do that but I'm overseas and cannot find it, perhaps someone else can help.
Edited 2026-02-03 11:56 by Geoffg
Posted: 08:12am 03 Feb 2026
Hi OA47,
This could do it, the LED blinks until <ENTER> is typed on the keyboard.
'blink led while waiting for input
'prepare LED for blinking
SetPin 2,dout   'LED connected to pin 2
Pin(2)=1        'LED ON
'input routine ----------------------------------------------------------
SetTick 200,blink 'blink period = 2*200ms = 400ms
answer$=""
 If Loc(0) Then                 'are there characters in input buffer
   answer$=answer$+Input$(1,0)  'read one character from input buffer
 EndIf
Loop Until Right$(answer$,1)=Chr$(13) 'did we hit return ?
SetTick 0,0
'end input routine ------------------------------------------------------
Print answer$
Pin(2)=1        'Resore LED condition
End
Sub blink
 Pin(2)=1-Pin(2) 'toggle LED pin
End Sub
Tested on micromite MKII
Edited 2026-02-03 18:26 by Volhout
OA47
Posted: 08:55pm 03 Feb 2026
Volhout,
It looks like th version 4 MBasic does not use Loc() for keyboard
If Loc(0) Then
ERROR: Invalid File Number
From the handbook
  Quote  LOC( [#]fnbr )
For a file opened as RANDOM this will return the current position of the
read/write pointer in the file.  Note that the first byte in a file is
numbered 1.  See Appendix I for more details of random file access.
For a serial port this will return the number of bytes received and
waiting in the receive buffer to be read.
The ‘#’ character is optional.
OA47
DaveJacko
Posted: 10:01pm 03 Feb 2026
I might have a better idea ! (rare occurence)
how about using PWM to flash the led?
maybe adds 3 lines of code
Marks out of 10 anyone ?
Try swapping 2 and 3 over
OA47
Posted: 11:06pm 03 Feb 2026
DaveJacko, that is a great idea but unfortunately I only have one PWM output and currently that is wired for sound. In this situation sorry no marks out of 10.
OA47
Posted: 11:41pm 03 Feb 2026
LOC() doesn't seem necessary, just use INPUT$() or even INKEY$()
mozzie
Posted: 12:53am 04 Feb 2026
G'day OA47,
In the distant past I had a similar need, don't have access to the original but it was something like this:
' prog to flash LED waiting for input
' for MMite V4.05
option default integer
setpin 16,dout
a$=inkey$     'clear input buffer
a$=""         'clear input string
pin(16)=1     ' set led on
do
 A$=A$+inkey$
 b=b+1:pin(16)=(b/16) and 1
 pause 10
loop until right$(A$,1)=CHR$(13)
pin(16)=0     'set LED off
print A$
end
It's good to go back to the early MMbasic from time to time to be reminded just how far it has come and how much power we now have at our finger tips
You could also use the ON KEY interrupt but this is simpler.
Another option is a flashing led (eg Jaycar ZD0245)
Hope this helps and good luck.
Lyle.
Edited 2026-02-04 11:01 by mozzie
disco4now
Posted: 04:36am 04 Feb 2026
This might give some help. Was initially for MMBasic 4.5
Uses  Inkey$, concatenating the keypresses until Enter is received.
  ' wait on key press
   Do: key = Asc(Inkey$): Loop Until key
LINEEDIT on FotS
F4 H7FotSF4xGT
Posted: 06:54am 04 Feb 2026
Expanding Disco4now's code to include flashing LED:-
> SetPin 1,dout
> t=timer :Do: key = Asc(Inkey$) :if timer-t>500 then :pin(1)=not pin(1) :t=timer :endif :Loop Until key
If V4.5 doesn't like reading back a DOUT pin you will need to add a variable.
LED = Not LED : pin(1) = LED
Frank N. Furter
Posted: 07:56am 04 Feb 2026
Stupid idea: Why not use a self-blinking LED?
https://cdn-reichelt.de/documents/datenblatt/A500/LEDBL5MM~KIN.pdf
Frank
Posted: 08:30am 04 Feb 2026
Hi OA47,
I must have mis-read your question. I was under the impression you used a micromite (thread title)... but it was a maximite 1.
OK, this code is tested on a CG-COLORMAX-II running MMBasic 4.5C. On the CG-ColorMax-II pin(0) is the power LED. You can of coarse change the LED_pin to any pin you like.
CG stands for Circuit Gizmo (I assume).
'blinking power led during input
'maximite MMBasic 4.5C
'------------------- defines -----------------
'define the LED status
LED_pin=0           'LED is connected to pin 0
LED=1               '1=on,0=off
Pin(LED_pin)=LED    'power led on
Blinkspeed = 100    'ON time and OFF time
'--------------------- main ------------------
' this is what you put in your main software
a$ = get_blink$()
' an alternative input statement
Print a$
EndIf
' ------------- subs and functions -----------
' returns with the string, similar to INPUT a$
Function get_blink$()
 SetTick Blinkspeed,Blink_the_LED,4        'start blinking
   get_blink$ = get_blink$ + Inkey$        'get characters
 Loop Until Right$(get_blink$,1)=Chr$(13)  'until <ENTER>
 SetTick 0,0,4 : LED=1 : Pin(LED_pin)=LED  'stop blink
End Function
' turn the LED on and off
Sub Blink_the_LED
 LED = 1 - LED
 Pin(LED_pin) = LED
End Sub
The essential change is that in your code you have to replace the
INPUT a$
with
a$ = get_blink$()
P.S. after pulling out the CG-ColorMax-II and powering it ON, I realized how much perfection was put in the Maximite. The nice colorfull MaxiMite logo that welcomes you. Very different from the cool "PICOMITE V6.02.00, Copyright...." text. The MaxiMite feels more mature, polished.
P.P.S. The MaximMIte was in storage since the first "MMBasic Programming Contest", 5 or 6 years ago. I turned it ON, and the unit immediately showed the correct time and date (except daylight saving).... another plus. Good battery.
Edited 2026-02-04 19:01 by Volhout
Posted: 03:40pm 04 Feb 2026
@Geoff,
Since my motoric memory was trained on PicoMite I cannot fail noting that between PicoMite and CMM1 the F1 and F2 functions are swapped when on commandline.
CMM1 : commandline F1 = run, F2 = save
CMM1 : in editor   F1 = save, F2 = run
PICO : F1 = save, F2 = run both commandline and in editor
OA47
Posted: 05:45am 06 Feb 2026
I have to put this one on the backburner as I have just realised that I have only 4 interrupts to use in this version of basic and they are all spoken for. It looks like a change in hardware is the most acceptable path at this stage. Thankyou all for your contributions.
OA47
mozzie
Posted: 07:34am 06 Feb 2026
G'day OA47,
If a lack of free interrupts is the only issue, perhaps the code I posted earlier is still an option.
Short Version:
setpin 16,dout
b=15          'set LED on at start
do
 A$=A$+inkey$
 pause 10
print A$
Still have not found the complete original but this was close:
SetPin 16,dout
a$=Inkey$     'clear input buffer
b=15          'set flash on at start
c=16          'slow flash rate to start
 A$=A$+Inkey$
 Text 0,0,A$
 b=b+1:Pin(16)=(b/c) And 1 'flash rate
 If b>512 Then c=8 Else c=16
 If Len(a$)>olen Then olen=Len(a$):b=b And &h1f
 If Right$(a$,1)=Chr$(&h1b) Or b>1000 Then A$="":Exit Do
 Pause 10
Loop Until Right$(A$,1)=Chr$(13)
Pin(16)=0     'set LED off
Print A$
This starts off slow flashing for 5 secs, goes fast for 5 secs unless a key is pressed or it will return with a blank string.
Might be useful for someone.
Lyle.
OA47
Posted: 12:52am 07 Feb 2026
  Quote  If a lack of free interrupts is the only issue, perhaps the code I posted earlier is still an option
Thankyou Lyle, I tested the short version and it seems to work ok. I will insert your code into the project and report back.
OA47
GoodLife
Posted: 09:41am 21 Feb 2026
Completed build of my EXPLORE 100 MicroMite with addition of SSD1963 7" LCD display
and have it running in console mode with "keyboard US" configured in Options.
How ever I only have One PS2 capable keyboard and the MicroMite Explore 100 on MMBASIC
5.04.5 does not recognize the keyboard.
Same keyboard works fine if used on my DuinoMite Mega on MMBASIC 4.04 ( CANbus firmware) .
The keyboard is a DSE ( Dick Smith Electronics) USB/PS2 Keyboard XHS239 that comes with a USB-PS2 adapter to use as a PS2 keyboard.
Are there differences between MMBASIC 5.04.5 on Micromite compared to MMBASIC 4.04 on DuinoMite Mega that would account why PS2 keyboard is not working ?
Or any pointers as to what may be the cause of same keyboard not working on MicroMite Explore 100 board ??
Thanks in anticipation . :)
Edited 2026-02-21 19:49 by GoodLife
Posted: 10:18am 21 Feb 2026
Check that you have 5v on pin 4 and Gnd. on pin 3 of the PS/2 socket. Looking at the front of the socket they are on the left and right mid level respectively.
Then check continuity from pin 5 of the socket (right of the notch at the top) to pin 83 of the PIC32 and then pin 1 (right bottom) to pin 84.
The latest MicroMitePlus firmware is V5.05.05
Make sure you are using the Plus version for the PIC32MX470.
Edited 2026-02-22 08:52 by phil99
