Local Time 04:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite IR TACHOMETER
OA47
Posted: 05:47am 01 Feb 2026
Just going through some of the unfinished projects and came across a handheld IR TACHO that I built many years ago. I have very simple code to run this unit but I feel it can be made much more accurate and reliable. Here is the code currently:
' IR TACHOMETER PROGRAM FOR MICROMITE
' IR LED POWERED ON
' IR RECEIVER CONNECTED TO PIN 16
' INITIALISE PINS FOR 2 LINE LCD
LCD INIT 2,3,4,5,23,24
SetPin 16,FIN            'IR RECEIVER
Dim Spin,I
LCD 1,3,"IR TACHOMETER"
LCD 2,10,"  RPM"
 Spin=0
 For I = 1 To 10
   Spin = Spin + Pin(16)
 Next I
 Print Spin/10;" Hz"
 LCD 2,1,Str$(Spin*6)
 Pause 500
 LCD 2,1,"      "
Loop
Has anyone any suggestions to improve this program?
OA47
ville56
Posted: 06:44am 01 Feb 2026
Tbh, I don't get the program logic at all...
73 de OE1HGA, Gerald
Posted: 07:06am 01 Feb 2026
  MM 5.05.05 manual said  Counting Inputs
The pins marked as COUNT can be configured as counting inputs to measure frequency, period or just count
pulses on the input.
For example, the following will print the frequency of the signal on pin 15:
> SETPIN 15, FIN
> PRINT PIN(15)
110374
In this case the frequency is 110.374 kHz.
Multiply by 60 for RPM.
The one I built uses an IR remote control receiver and the IR LED is fed with a 38kHz 50% PWM output.
This gives it a much better tolerance for high ambient light and works at a greater distance due to the narrow bandwidth, high gain and excellent AGC of the IR receiver.
Tested to 30,000 RPM.
Edited 2026-02-01 17:08 by phil99
Posted: 11:18am 01 Feb 2026
Hi OA47,
remember...
https://www.thebackshed.com/forum/ViewTopic.php?TID=16669&P=2#217359
OA47
Posted: 11:33pm 01 Feb 2026
Volhout, thankyou for bringing that to my attention. Obviously my static brain ram backup battery has faded and I have been down this road before.
OA47
Posted: 08:05am 02 Feb 2026
Hi OA,
You simply picked up again where you left of last time.
