Local Time 03:32 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Testing for a particular time period
OA47
Posted: 11:48pm 22 Jan 2026
I am using many displays that are active 24/7 and would like to lower the backlight during evening hours. I have used a test to look for 07:00:00 and 19:00:00 time stamps which works OK but occasionally that time stamp is missed due to other operations of the program. I would like to test if the time is past 07:00:00 and 19:00:00 to reduce or increase the backlight. I vagally remember discussions of an EPOC command but I can't find any mention in the handbooks. Would this be the direction I should head?
OA47
Andy-g0poy
Posted: 12:02am 23 Jan 2026
EPOCH(DATETIME$)
and NOW
Print EPOCH(NOW)
Page 187
DATETIME$(n) returns the date time string fromthe epoch number n
page 185
Using the pdf manual
MMBasic BASIC Interpreter
Ver 6.01.00
Andy
Posted: 12:58am 23 Jan 2026
Time$ is a string and you can compare strings
IF TIME$ >= "07:00:00" AND TIME$ < "19:00:00" THEN
 backlight = 100
ELSE
 backlight = 20
ENDIF
Posted: 02:25am 23 Jan 2026
That is clever, easier than Epoch.
> TIME$ = "06:55" : ? TIME$ >= "07:00:00" AND TIME$ < "19:00:00"
0
> TIME$ = "07:05" : ? TIME$ >= "07:00:00" AND TIME$ < "19:00:00"
1
> TIME$ = "18:55" : ? TIME$ >= "07:00:00" AND TIME$ < "19:00:00"
1
> TIME$ = "19:05" : ? TIME$ >= "07:00:00" AND TIME$ < "19:00:00"
0
> night = 19*60*60
> day = 7*60*60
> aDay =  24*60*60
> if epoch(now) mod aDay > night then backlight 10
> if epoch(now) mod aDay > day then backlight 100
Edited 2026-01-23 12:29 by phil99
greybeard
Posted: 02:45am 23 Jan 2026
As a general guideline for programming limit or range logic I'd suggest checking for > or < as appropriate unless circumstances preclude doing so. ie not just = to.
A lot more people can program when the real world behaves as they expect their virtual world to behave. A good programmer should strive to program for when the real world is real and things don't behave in a virtual manner. ie program for the worst case, not the best case especially if your version of logic says it can't happen, it will.
OA47
Posted: 03:27am 23 Jan 2026
Thankyou all, I will use the string comparison.
OA47
PhenixRising
Posted: 09:18am 24 Jan 2026
"your version of logic" 🤣😂🤣😂
Posted: 11:23am 24 Jan 2026
This is only one of the reasons why it's difficult to properly check your own code. You *know* that a particular logic stream is correct when it will stand out like a beacon to someone else that it's wrong.  :(
PhenixRising
Posted: 06:41pm 24 Jan 2026
  Mixtel90 said  This is only one of the reasons why it's difficult to properly check your own code. You *know* that a particular logic stream is correct when it will stand out like a beacon to someone else that it's wrong.  :(
Andrew_G
Posted: 09:30am 27 Jan 2026
Hi Graeme,
You kindly gifted me some monitors and cables via Big Mick a few months back. Thanks.
Another solution to your issue is to use a Light Dependant Resistor (LDR) (e.g. Jaycar # RD3480) to measure the ambient light. I use them on "everything", especially in my sleeping quarters/my side of the bed.
With a little bit of calibration you can get three levels, bright/normal/dark, and set BACKLIGHT accordingly.
Use SETTICK to check the resistance every second and it responds well.
Happy to post more details.
Cheers,
Andrew
OA47
Posted: 01:07am 28 Jan 2026
  Quote  You kindly gifted me some monitors and cables via Big Mick a few months back. Thanks
Andrew you are very welcome. It is a bit of a pity that so much stuff had to be sent to waste but that was the way it was.
OA47
